Author Topic: 19125!!!!!!  (Read 3988 times)
Offline offroadjosh
  • Davis Vp2 Wireless- VWS 14 P90 Serial Data logger
  • Montana Firefighter
    • My Website=)
19125!!!!!!
« on: February 11, 2009, 01:45:53 AM »
uh vws is at 19125 for my database records!!! it says 20,000 max is this a bad thing...???
josh
Josh Patten
Davis VP2 Wireless -May 2008
VWS 14.00P90\WL 5.9.9/Plus others!
Skywarn trained
CoCoRaHS member
Smith Valley Fire Dept Firefighter:)
http://josh.northwestwx.com/station/usa.htm
CWOP-DW0711
Kestrel 2000 hand held anemometer
Cocorahs 4in rain gauge
Custom co
Offline mackbig
Re: 19125!!!!!!
« Reply #1 on: February 11, 2009, 07:08:03 AM »
DO NOT attempt to "fix" it or you will unleash big problems.
just let it ride... no issues.   It self trims as it goes....
Andrew
josh
Offline offroadjosh
    • My Website=)
Re: 19125!!!!!!
« Reply #2 on: February 11, 2009, 10:29:34 AM »
haha ok thanks! i wont touch it then=)
Josh
Josh Patten
Skywarn trained
CoCoRaHS member
CWOP-DW0711
Custom co
Offline Anthony
  • Moderator
    • Anthony's Weather
Re: 19125!!!!!!
« Reply #3 on: February 11, 2009, 01:22:52 PM »
macbig, Your banner is taking a long time to load. And is causing the pages that you post on to lag.
Anthony
WB8YUE
Offline mackbig
Re: 19125!!!!!!
« Reply #4 on: February 11, 2009, 01:52:23 PM »
Must have been a temp issue with Godaddy or something else.  I cant recreate, and have not made any changes...
Andrew
Offline Weather Display
Re: 19125!!!!!!
« Reply #5 on: February 11, 2009, 02:01:30 PM »
when it self trims, is that data that is trimmed off then still available in a date stamped file or similar?
Brian
info@weather-display.com
Offline mackbig
Re: 19125!!!!!!
« Reply #6 on: February 11, 2009, 02:20:52 PM »
Yes, it is still available in the exact same format..... There are several db's being updated at the same time.  You always have access to the exact same data held in the "trimmed" db by looking at the one for your particular year.
So if you are updating every 20 minutes, assuming you started your db on Jan 1 you would hit 20K records on day 277.  On day 360 you could just open your 2009dbase.csv to see what happened on Jan 2nd....  But it would not be in your "running" dbase.csv file.   you can also access the daily/monthly etc BIN files for daily details.
Andrew
Re: 19125!!!!!!
« Reply #7 on: February 11, 2009, 04:04:50 PM »
thanks for the explanation
I always wondered how that all worked :)
Brian
Offline Anthony
  • Moderator
    • Anthony's Weather
Re: 19125!!!!!!
« Reply #8 on: February 12, 2009, 08:20:59 AM »
Banner loading fine today. As you said. Must have been a GD issue at the time.
Anthony
WB8YUE
