Weather Software > Meteohub/Meteobridge
MB keeps losing contact with Loggers. **solved**
(1/1)
davidmc36:
I recently moved from TP Link to RPi for my MB platform. I was getting somewhat frequent lock-ups and figured it could use the extra memory. The TP was running 95% plus all the time.
Now on the RPi it is even worse.
It loses contact with two WiFi Loggers and one Ethernet logger.
I have to re-boot the MB.
Everything is on reserved IP and running straight to my router's WiFi and ethernet. The Mesh System is still running in the house but not used by MB or Loggers.
Below is the latest log while it is not receiving any data. Live Data Tab on MB has this message:
"Data logger momentarily cannot provide data. Please try again in a minute. If it does not show up later, please also check weather station selection on "Station" tab."
The 192.168.2.46 IP mentioned in the log is the main WiFi Logger in use.
Some of the log deleted as is was too big for message. It is just the same message over and over.
Any idea what could be causing this?
D
--- Code: ---logger (10.04.2024 07:56:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 07:57:02): message above repeats 12 times.
logger (10.04.2024 07:57:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 07:57:07): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 07:57:31): message above repeats 7 times.
logger (10.04.2024 07:57:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 07:57:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 07:58:04): message above repeats 10 times.
logger (10.04.2024 07:58:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 07:58:10): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 07:58:31): message above repeats 7 times.
logger (10.04.2024 07:58:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:10:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:10:08): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:10:34): message above repeats 8 times.
logger (10.04.2024 08:10:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:10:39): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:11:04): message above repeats 12 times.
logger (10.04.2024 08:11:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:11:09): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:11:33): message above repeats 7 times.
logger (10.04.2024 08:11:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:11:37): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:12:04): message above repeats 11 times.
logger (10.04.2024 08:12:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:12:07): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:12:35): message above repeats 7 times.
logger (10.04.2024 08:12:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:12:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:13:05): message above repeats 10 times.
logger (10.04.2024 08:13:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:13:07): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:13:34): message above repeats 7 times.
logger (10.04.2024 08:13:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:13:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:14:05): message above repeats 10 times.
logger (10.04.2024 08:14:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:14:06): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:14:35): message above repeats 7 times.
logger (10.04.2024 08:14:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:14:39): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:15:05): message above repeats 10 times.
logger (10.04.2024 08:15:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:15:10): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:15:35): message above repeats 8 times.
logger (10.04.2024 08:15:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:15:40): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:16:05): message above repeats 11 times.
logger (10.04.2024 08:16:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:16:06): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:16:31): message above repeats 7 times.
logger (10.04.2024 08:16:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:16:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:17:03): message above repeats 12 times.
logger (10.04.2024 08:17:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:17:06): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:17:33): message above repeats 8 times.
logger (10.04.2024 08:17:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:17:38): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:18:04): message above repeats 10 times.
logger (10.04.2024 08:18:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:18:11): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:18:34): message above repeats 7 times.
logger (10.04.2024 08:18:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:18:40): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:19:05): message above repeats 11 times.
logger (10.04.2024 08:19:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:19:10): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:19:35): message above repeats 8 times.
logger (10.04.2024 08:19:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:19:40): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:20:05): message above repeats 11 times.
logger (10.04.2024 08:20:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:20:10): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:20:32): message above repeats 7 times.
logger (10.04.2024 08:20:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:20:37): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:21:03): message above repeats 10 times.
logger (10.04.2024 08:21:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:21:06): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:21:32): message above repeats 10 times.
logger (10.04.2024 08:21:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:21:37): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:22:04): message above repeats 11 times.
logger (10.04.2024 08:22:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:22:09): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:22:32): message above repeats 7 times.
logger (10.04.2024 08:22:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:22:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:23:04): message above repeats 10 times.
logger (10.04.2024 08:23:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:23:08): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:23:35): message above repeats 8 times.
logger (10.04.2024 08:23:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:23:41): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:24:04): message above repeats 9 times.
logger (10.04.2024 08:24:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:24:06): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:24:33): message above repeats 8 times.
logger (10.04.2024 08:24:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:24:38): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:25:04): message above repeats 10 times.
logger (10.04.2024 08:25:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:25:08): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:25:33): message above repeats 7 times.
logger (10.04.2024 08:25:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:25:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:26:04): message above repeats 10 times.
logger (10.04.2024 08:26:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:26:07): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:26:33): message above repeats 10 times.
logger (10.04.2024 08:26:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:26:40): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:27:05): message above repeats 13 times.
logger (10.04.2024 08:27:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:27:10): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:27:32): message above repeats 6 times.
logger (10.04.2024 08:27:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:27:37): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:28:04): message above repeats 10 times.
logger (10.04.2024 08:28:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:28:07): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:28:32): message above repeats 8 times.
logger (10.04.2024 08:28:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:28:37): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:29:04): message above repeats 11 times.
logger (10.04.2024 08:29:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:29:08): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:29:34): message above repeats 8 times.
logger (10.04.2024 08:29:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:29:39): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:30:04): message above repeats 11 times.
logger (10.04.2024 08:30:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:30:09): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:30:35): message above repeats 8 times.
logger (10.04.2024 08:30:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:30:40): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:31:04): message above repeats 9 times.
logger (10.04.2024 08:31:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:31:07): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:31:32): message above repeats 10 times.
logger (10.04.2024 08:31:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:31:37): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:32:04): message above repeats 11 times.
logger (10.04.2024 08:32:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:32:07): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:32:32): message above repeats 7 times.
logger (10.04.2024 08:32:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:32:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:33:04): message above repeats 10 times.
logger (10.04.2024 08:33:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:33:08): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:33:34): message above repeats 8 times.
logger (10.04.2024 08:33:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:33:39): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:34:05): message above repeats 10 times.
logger (10.04.2024 08:34:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:34:10): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:34:34): message above repeats 7 times.
logger (10.04.2024 08:34:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:34:37): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:35:05): message above repeats 10 times.
logger (10.04.2024 08:35:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:35:07): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:35:32): message above repeats 7 times.
logger (10.04.2024 08:35:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:35:37): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:36:04): message above repeats 10 times.
logger (10.04.2024 08:36:06): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:36:07): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:36:29): message above repeats 9 times.
logger (10.04.2024 08:36:36): station 0 (Vantage), error make socket 192.168.2.46: port 22222: Invalid argument
logger (10.04.2024 08:36:36): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:36:49): message above repeats 4 times.
logger (10.04.2024 08:36:50): error while doing accept on socket 5558 (22): Invalid argument
logger (10.04.2024 08:36:55): message above repeats 98 times.
logger (10.04.2024 08:36:55): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (10.04.2024 08:36:55): message above repeats 2 times.
logger (10.04.2024 08:36:55): error while doing accept on socket 5558 (22): Invalid argument
logger (10.04.2024 08:37:00): message above repeats 95 times.
--- End code ---
docbee:
Topic is handled here: https://forum.meteohub.de/viewtopic.php?t=17924
