Author Topic: Atlas thermometer connection socket  (Read 682 times)
Offline İbhlln
  • Acurite Atlas
« on: September 11, 2019, 04:09:55 AM »
You can see Atlas's thermometer connection under the panel, too ?is it affected by rain?
Offline nincehelser
Re: Atlas thermometer connection socket
« Reply #1 on: September 11, 2019, 08:58:47 AM »
Is this what you are referring to inside the pagoda?
If so, it keeps it well shielded from rain.
Offline İbhlln
  • Acurite Atlas
« Reply #2 on: September 11, 2019, 09:44:07 AM »
Where the socket stays when you connect
How can I see your connection
« Last Edit: September 11, 2019, 09:55:17 AM by İbhlln »
Offline nincehelser
« Reply #3 on: September 11, 2019, 11:42:08 AM »
That socket plugs into a jumper that runs to the circuit board in the electronics bay.
That socket is there so that you can easily service or replace the temp/humidity module if needed.
I don't have a picture of the jumper connection, but here is where it ultimately ends up in the electronics bay.  It's the connection labeled "TEMP."
Offline İbhlln
  • Acurite Atlas
« Reply #4 on: September 11, 2019, 12:14:38 PM »
Under padoga socket it looks wet from the rain
Padoga altındaki soket kavşağının yerini gördünüz mü
Just inside the shutters
Offline nincehelser
« Reply #5 on: September 11, 2019, 12:48:39 PM »
I doubt that will be any issue.
The plastic connectors cover and separate the conductors pretty well.
