Thanks for the work
However, if somebody wants to use it whose Ecowitt (clone) console is not defined as station #2 in Meteobridge, it will not show any results.
The last 4 lines of the metachart will need to be adapted to the current situation of the user
the original says:
data1 lgt2!0dist-avg=mi1,00+0,00.1
data2 lgt2!0total-sum=1,00+0,00.1
data3 lgt2!0dist-min=mi1,00+0,00.1
data4 lgt2!0dist-max=mi1,00+0,00.1
but if you use your Ecowitt station (HP2553, GW1003 etc) as your only station, the last for lines will have to be
data1 lgt0!0dist-avg=mi1,00+0,00.1
data2 lgt0!0total-sum=1,00+0,00.1
data3 lgt0!0dist-min=mi1,00+0,00.1
data4 lgt0!0dist-max=mi1,00+0,00.1
When I ran the chart over a bigger period, it showed only the past few months (as my station #2 was added only two months ago with no earlier history). Many if not most people will just only run their main station (station #0).
