you are right!
I really appreciate all your help!
Here's some general info:
Model HP2550A
Hardware revision number V2.0
Firmware rvision number Pro_V1.7.6
Wifi Firmware Easyweather V1.5.2
I was trying to connect to AWEKAS via CMX as a test, since I am using the one custom server setting on the console for CMX now and not for AWEKAS anymore.
And the log file: [FYI, when it says "Data input appears to have stopped", the console is still sending data to other services (WU and ecowitt.net); ......... replace the line 2022-05-08 nn:nn:nn.nnn *** Data input appears to have stopped (once per minute) ]
2022-05-08 16:30:35.531 ========================== Cumulus MX starting ==========================
2022-05-08 16:30:35.531 Command line: "C:\Users\IHL_workstation\Downloads\CumulusMXDist3183\CumulusMX\CumulusMX.exe" -debug
2022-05-08 16:30:35.531 Cumulus MX v.3.16.1 build 3183
2022-05-08 16:30:35.531 Platform: Win32NT
2022-05-08 16:30:35.531 OS version: Microsoft Windows NT 6.2.9200.0
2022-05-08 16:30:35.547 Current culture: Deutsch (Deutschland) [de-DE]
2022-05-08 16:30:36.208 Checking required folders
2022-05-08 16:30:36.240 Reading Cumulus.ini file
2022-05-08 16:30:36.240 AvgSpdMins=10 AvgSpdTime=00:10:00
2022-05-08 16:30:36.255 Cumulus start date: Samstag, 7. Mai 2022
2022-05-08 16:30:36.318 Reading Cumulus.ini file completed
2022-05-08 16:30:36.318 Directory separator=[\] Decimal separator=[,] List separator=[;]
2022-05-08 16:30:36.318 Date separator=[.] Time separator=[:]
2022-05-08 16:30:36.318 Standard time zone name: Mitteleuropäische Zeit
2022-05-08 16:30:36.318 Daylight saving time name: Mitteleuropäische Sommerzeit
2022-05-08 16:30:36.318 Daylight saving time? True
2022-05-08 16:30:36.318 08.05.2022 16:30:36
2022-05-08 16:30:36.318 Stop second instance: No other running instances of Cumulus found
2022-05-08 16:30:36.318 No start-up delay - disabled
2022-05-08 16:30:36.318 No start-up PING
2022-05-08 16:30:36.318 Data path = data\
2022-05-08 16:30:36.380 BackupData: Creating backup folder backup\20220508163036\
2022-05-08 16:30:36.474 Created backup folder backup\20220508163036\
2022-05-08 16:30:36.474 Debug logging :enabled
2022-05-08 16:30:36.474 Data logging :enabled
2022-05-08 16:30:36.474 FTP logging :disabled
2022-05-08 16:30:36.474 Email logging :disabled
2022-05-08 16:30:36.474 Spike logging :enabled
2022-05-08 16:30:36.474 Logging interval = 1 mins
2022-05-08 16:30:36.474 Real time interval = 30 secs
2022-05-08 16:30:36.474 NoSensorCheck = 0
2022-05-08 16:30:36.490 Calculating sunrise and sunset times
2022-05-08 16:30:36.490 Sunrise: 05:25:45
2022-05-08 16:30:36.490 Sunset : 20:17:37
2022-05-08 16:30:36.490 Tomorrow sunrise: 05:24:16
2022-05-08 16:30:36.490 Tomorrow sunset : 20:18:59
2022-05-08 16:30:36.490 Tomorrow length diff: 171
2022-05-08 16:30:36.512 Station type: HTTP Ecowitt
2022-05-08 16:30:36.512 WindUnit=m/s RainUnit=mm TempUnit=°C PressureUnit=hPa
2022-05-08 16:30:36.513 YTDRain=0,000 Year=0
2022-05-08 16:30:36.513 RainDayThreshold=-1,000
2022-05-08 16:30:36.513 Roll over hour=0
2022-05-08 16:30:36.514 Offsets and Multipliers:
2022-05-08 16:30:36.514 PO=0,000 TO=0,000 HO=0 WDO=0 ITO=0,000 SO=0,000 UVO=0,000
2022-05-08 16:30:36.514 PM=1,000 WSM=1,000 WGM=1,000 TM=1,000 TM2=0,000 HM=1,000 HM2=0,000 RM=1,000 SM=1,000 UVM=1,000
2022-05-08 16:30:36.514 Spike removal:
2022-05-08 16:30:36.514 TD=999,000 GD=999,000 WD=999,000 HD=999,000 PD=999,000 MR=999,000 MH=999,000
2022-05-08 16:30:36.514 Limits:
2022-05-08 16:30:36.514 TH=60,0 TL=-60,0 DH=40,0 PH=1090,0 PL=870,0 GH=90,000
2022-05-08 16:30:36.515 Primary AQ Sensor = Undefined
2022-05-08 16:30:36.523 Cumulus Starting
2022-05-08 16:30:36.550 HTML root path = C:\Users\IHL_workstation\Downloads\CumulusMXDist3183\CumulusMX\interface
2022-05-08 16:30:36.599 Cumulus running at:
http://localhost:8998/2022-05-08 16:30:36.601 Lock: Cumulus waiting for the lock
2022-05-08 16:30:36.601 Lock: Cumulus has lock
2022-05-08 16:30:36.601 Opening station
2022-05-08 16:30:36.616 Last update time from today.ini: 08.05.2022 16:10:00
2022-05-08 16:30:36.617 Read today file: Date = 08.05.2022, LastUpdateTime = 08.05.2022 16:10:00, Month = 5
2022-05-08 16:30:36.617 Sensor clock 00:00:00
2022-05-08 16:30:36.617 Station clock 00:00:00
2022-05-08 16:30:36.618 ET today = 0,00
2022-05-08 16:30:36.618 ReadTodayfile: Rain day start = 0
2022-05-08 16:30:36.618 ReadTodayfile: set initialiseRainCounterOnFirstData false
2022-05-08 16:30:36.626 C:\Users\IHL_workstation\Downloads\CumulusMXDist3183\CumulusMX\data\alltime.ini
2022-05-08 16:30:36.628 Alltime.ini file read
2022-05-08 16:30:36.637 MonthlyAlltime.ini file read
2022-05-08 16:30:36.643 Month.ini file read
2022-05-08 16:30:36.649 Year.ini file read
2022-05-08 16:30:36.651 LoadDayFile: Attempting to load the day file
2022-05-08 16:30:36.663 LoadDayFile: Dayfile parse = 11 ms
2022-05-08 16:30:36.663 LoadDayFile: Loaded 2 entries to recent daily data list
2022-05-08 16:30:36.665 Finding raintoday from logfile data\Mai22log.txt
2022-05-08 16:30:36.665 Expecting listsep=; decimal=,
2022-05-08 16:30:36.665 Midnight rain found in the following entry:
2022-05-08 16:30:36.666 08.05.22;00:00;14,7;81;11,5;1;2;267;0,0;23,1;995,4;23,1;24,4;57;1;14,7;14,7;0,0;0;0,00;0,00;14,9;0;0,0;267;0,0;23,1;14,9;16,7
2022-05-08 16:30:36.668 Midnight rain found, setting midnight rain count = 23,1
2022-05-08 16:30:36.669 Checking rain counter = 23,1
2022-05-08 16:30:36.669 Rain counter set to = 23,1
2022-05-08 16:30:36.670 Getting rain totals, rain season start = 1
2022-05-08 16:30:36.670 Today = 08/05/22
2022-05-08 16:30:36.671 Rainthismonth from dayfile: 0
2022-05-08 16:30:36.671 Rainthisyear from dayfile: 0
2022-05-08 16:30:36.673 Creating HTTP Station (Ecowitt)
2022-05-08 16:30:36.673 Using the default outdoor temp/hum sensor data
2022-05-08 16:30:36.673 Using the default traditional rain sensor data
2022-05-08 16:30:36.673 Creating extra sensors
2022-05-08 16:30:36.674 Lock: Station waiting for the lock
2022-05-08 16:30:36.708 855 web tags initialised
2022-05-08 16:30:36.709 Generating the daily graph data files
2022-05-08 16:30:36.741 Lock: Cumulus releasing the lock
2022-05-08 16:30:36.742 Lock: Station has the lock
2022-05-08 16:30:36.781 This Cumulus MX instance is running the latest version
2022-05-08 16:30:36.805 GetHistoricData: Starting Historic Data Process
2022-05-08 16:30:36.810 API.GetHistoricData: Get Ecowitt Historic Data
2022-05-08 16:30:36.810 API.GetHistoricData: Processing history data from 2022-05-08 16:11 to 2022-05-08 16:35...
2022-05-08 16:30:36.811 Ecowitt URL =
https://api.ecowitt.net/api/v3/device/history?application_key=<<App-key>>&api_key=<<User-key>>&mac=C4:5B:BE:6E:64:65&start_date=2022-05-08%2016:06:00&end_date=2022-05-08%2016:30:36&temp_unitid=1&pressure_unitid=3&wind_speed_unitid=6&rainfall_unitid=12&call_back=indoor,outdoor,wind,pressure,rainfall,rainfall_piezo,solar_and_uvi,temp_and_humidity_ch1,temp_and_humidity_ch2,temp_and_humidity_ch3,temp_and_humidity_ch4,temp_and_humidity_ch5,temp_and_humidity_ch6,temp_and_humidity_ch7,temp_and_humidity_ch8,soil_ch1,soil_ch2,soil_ch3,soil_ch4,soil_ch5,soil_ch6,soil_ch7,soil_ch8,temp_ch1,temp_ch2,temp_ch3,temp_ch4,temp_ch5,temp_ch6,temp_ch7,temp_ch8,leaf_ch1,leaf_ch2,leaf_ch3,leaf_ch4,leaf_ch5,leaf_ch6,leaf_ch7,leaf_ch8,indoor_co2,co2_aqi_combo,pm25_ch1,pm25_ch2,pm25_ch3,pm25_ch4&cycle_type=5min
2022-05-08 16:30:38.655 API.GetHistoricData: Ecowitt API Historic Response code: 200
2022-05-08 16:30:38.656 API.GetHistoricData: Ecowitt API Historic Response: {"code":0,"msg":"success","time":"1652020237","data":{"outdoor":{"temperature":{"unit":"℃","list":{"1652019000":"22.5","1652019300":"22.2","1652019600":"22.0"}},"feels_like":{"unit":"℃","list":{"1652019000":"22.5","1652019300":"22.2","1652019600":"22.0"}},"app_temp":{"unit":"℃","list":{"1652019000":"23.1","1652019300":"22.5","1652019600":"22.2"}},"dew_point":{"unit":"℃","list":{"1652019000":"12.1","1652019300":"11.6","1652019600":"11.5"}},"humidity":{"unit":"%","list":{"1652019000":"52","1652019300":"51","1652019600":"52"}}},"indoor":{"temperature":{"unit":"℃","list":{"1652019000":"24.5","1652019300":"24.5","1652019600":"24.5"}},"humidity":{"unit":"%","list":{"1652019000":"55","1652019300":"55","1652019600":"55"}}},"solar_and_uvi":{"solar":{"unit":"w\/m^2","list":{"1652019000":"453.2","1652019300":"361.2","1652019600":"510.1"}},"uvi":{"unit":"","list":{"1652019000":"4","1652019300":"3","1652019600":"4"}}},"rainfall":{"rain_rate":{"unit":"mm\/hr","list":{"1652019000":"0.0","1652019300":"0.0","1652019600":"0.0"}},"daily":{"unit":"mm","list":{"1652019000":"0.0","1652019300":"0.0","1652019600":"0.0"}},"event":{"unit":"mm","list":{"1652019000":"0.0","1652019300":"0.0","1652019600":"0.0"}},"hourly":{"unit":"mm","list":{"1652019000":"0.0","1652019300":"0.0","1652019600":"0.0"}},"weekly":{"unit":"mm","list":{"1652019000":"21.8","1652019300":"21.8","1652019600":"21.8"}},"monthly":{"unit":"mm","list":{"1652019000":"23.1","1652019300":"23.1","1652019600":"23.1"}},"yearly":{"unit":"mm","list":{"1652019000":"23.1","1652019300":"23.1","1652019600":"23.1"}}},"wind":{"wind_speed":{"unit":"m\/s","list":{"1652019000":"0.1","1652019300":"0.3","1652019600":"0.3"}},"wind_gust":{"unit":"m\/s","list":{"1652019000":"1.0","1652019300":"1.0","1652019600":"1.0"}},"wind_direction":{"unit":"º","list":{"1652019000":"212","1652019300":"199","1652019600":"211"}}},"pressure":{"relative":{"unit":"hPa","list":{"1652019000":"995.5","1652019300":"995.5","1652019600":"995.6"}},"absolute":{"unit":"hPa","list":{"1652019000":"995.5","1652019300":"995.5","1652019600":"995.6"}}}}}
2022-05-08 16:30:38.935 Processing data for 08.05.2022 16:15:00
2022-05-08 16:30:38.948 Setting max gust from current value: 1,0
2022-05-08 16:30:38.970 Windrun: 0,1m/s for 5 minutes = 0,0km
2022-05-08 16:30:38.975 Writing to Month.ini file
2022-05-08 16:30:38.977 End writing to Month.ini file
2022-05-08 16:30:38.986 New all-time record: New time = 2022-05-08 16:15, new value = 16,269 "High daily windrun" prev time = 2022-05-08 16:10, prev value = 16,239
2022-05-08 16:30:38.997 New monthly record: month = 05: New time = 2022-05-08 16:15, new value = 16,269 "High daily windrun" prev time = 2022-05-08 16:10, prev value = 16,239
2022-05-08 16:30:39.004 DoLogFile: Writing log entry for 08.05.2022 16:15:00
2022-05-08 16:30:39.004 DoLogFile: max gust: 1,0
2022-05-08 16:30:39.005 DoLogFile: log entry for 08.05.2022 16:15:00 written
2022-05-08 16:30:39.010 Writing today.ini, LastUpdateTime = 08.05.2022 16:15:00 raindaystart = 0 rain counter = 23,1
2022-05-08 16:30:39.231 Processing data for 08.05.2022 16:20:00
2022-05-08 16:30:39.231 Windrun: 0,5m/s for 5 minutes = 0,1km
2022-05-08 16:30:39.232 Writing to Month.ini file
2022-05-08 16:30:39.233 End writing to Month.ini file
2022-05-08 16:30:39.237 New all-time record: New time = 2022-05-08 16:20, new value = 16,409 "High daily windrun" prev time = 2022-05-08 16:15, prev value = 16,269
2022-05-08 16:30:39.247 New monthly record: month = 05: New time = 2022-05-08 16:20, new value = 16,409 "High daily windrun" prev time = 2022-05-08 16:15, prev value = 16,269
2022-05-08 16:30:39.247 DoLogFile: Writing log entry for 08.05.2022 16:20:00
2022-05-08 16:30:39.247 DoLogFile: max gust: 1,0
2022-05-08 16:30:39.248 DoLogFile: log entry for 08.05.2022 16:20:00 written
2022-05-08 16:30:39.248 Writing today.ini, LastUpdateTime = 08.05.2022 16:20:00 raindaystart = 0 rain counter = 23,1
2022-05-08 16:30:39.350 Processing data for 08.05.2022 16:25:00
2022-05-08 16:30:39.350 Windrun: 0,4m/s for 5 minutes = 0,1km
2022-05-08 16:30:39.350 Writing to Month.ini file
2022-05-08 16:30:39.352 End writing to Month.ini file
2022-05-08 16:30:39.369 New all-time record: New time = 2022-05-08 16:25, new value = 16,537 "High daily windrun" prev time = 2022-05-08 16:20, prev value = 16,409
2022-05-08 16:30:39.378 New monthly record: month = 05: New time = 2022-05-08 16:25, new value = 16,537 "High daily windrun" prev time = 2022-05-08 16:20, prev value = 16,409
2022-05-08 16:30:39.379 DoLogFile: Writing log entry for 08.05.2022 16:25:00
2022-05-08 16:30:39.379 DoLogFile: max gust: 1,0
2022-05-08 16:30:39.380 DoLogFile: log entry for 08.05.2022 16:25:00 written
2022-05-08 16:30:39.381 Writing today.ini, LastUpdateTime = 08.05.2022 16:25:00 raindaystart = 0 rain counter = 23,1
2022-05-08 16:30:39.447 Lock: Station releasing the lock
2022-05-08 16:30:39.448 Starting HTTP Station (Ecowitt)
2022-05-08 16:30:39.455 Start Extra Sensors
2022-05-08 16:30:39.455 Start Timers
2022-05-08 16:30:39.455 Starting 1-minute timer
2022-05-08 16:30:39.456 Data logging interval = 0 (1 mins)
2022-05-08 16:30:39.456 Realtime not enabled
2022-05-08 16:30:39.456 Wundlist count is zero
2022-05-08 16:30:39.456 Windylist count is zero
2022-05-08 16:30:39.457 MySqlList is Empty
2022-05-08 16:30:39.458 Normal running
2022-05-08 16:30:43.036 WS Connect From : 127.0.0.1
2022-05-08 16:31:00.269 Writing to Month.ini file
2022-05-08 16:31:00.269 End writing to Month.ini file
2022-05-08 16:31:00.285 New all-time record: New time = 2022-05-08 16:31, new value = 16,562 "High daily windrun" prev time = 2022-05-08 16:25, prev value = 16,537
2022-05-08 16:31:00.296 New monthly record: month = 05: New time = 2022-05-08 16:31, new value = 16,562 "High daily windrun" prev time = 2022-05-08 16:25, prev value = 16,537
2022-05-08 16:31:00.340 DoLogFile: Writing log entry for 08.05.2022 16:31:00
2022-05-08 16:31:00.340 DoLogFile: max gust: 1,0
2022-05-08 16:31:00.340 DoLogFile: log entry for 08.05.2022 16:31:00 written
2022-05-08 16:31:00.340 Writing today.ini, LastUpdateTime = 08.05.2022 16:31:00 raindaystart = 0 rain counter = 23,1
2022-05-08 16:31:00.356 AWEKAS: URL =
http://data.awekas.at/eingabe_pruefung.php?indoortemp=24.5&indoorhumidity=55&output=json&val=IHLweatherstation01;<password>;08.05.2022;16:31;22.0;52;995.6;0.0;1.5;205;;;;en;-1;3.6;510.0;4.0;;1.33;;0.0;Cum_3.16.1;;;0.0;19.6;23.8;13.5;;23.8;13.5;;23.8;0;;88;45;;88;45;;88;0.0;;997.0;995.0;;997.0;995.0;;997.0;;;10.5;;;10.5;;;10.5;;;25.9;;;25.9;;;25.9;;;;0.0;23.1;23.1;;0.0;;0.0;;0.0;;681.0;;;;;6.0;;;;;;;;;;;;;;;;;;;;;
2022-05-08 16:31:00.442 AWEKAS Response code = OK
2022-05-08 16:31:00.442 AWEKAS: Response text = {
"status": 2,
"authentication": 1,
"minuploadtime": 15,
"error":
"count": 0,
"time": 0,
"date": 0,
"temp": 0,
"hum": 0,
"airp": 0,
"rain": 0,
"rainrate": 0,
"wind": 0,
"gust": 0,
"snow": 0,
"solar": 0,
"uv": 0,
"bightness": 0,
"suntime": 0,
"indoortemp": 0,
"indoorhumidity": 0,
"aqpm1": 0,
"aqpm2.5": 0,
"aqpm10": 0,
"soilmoisture1": 0,
"soilmoisture2": 0,
"soilmoisture3": 0,
"soilmoisture4": 0,
"soiltemp1": 0,
"soiltemp2": 0,
"soiltemp3": 0,
"soiltemp4": 0,
"leafwetness1": 0,
"leafwetness2": 0,
"warning": 0
"disabled":
"temp": 0,
"hum": 0,
"airp": 0,
"rain": 0,
"rainrate": 0,
"wind": 0,
"snow": 0,
"solar": 0,
"uv": 0,
"indoortemp": 0,
"indoorhum": 0,
"aqpm": 0,
"soilmoisture1": "1",
"soilmoisture2": "1",
"soilmoisture3": "1",
"soilmoisture4": "1",
"soiltemp1": "1",
"soiltemp2": "1",
"soiltemp3": "1",
"soiltemp4": "1",
"leafwetness1": "1",
"leafwetness2": "1",
"report": 0
2022-05-08 16:31:00.451 AWEKAS: Data stored OK
2022-05-08 16:32:00.375 *** Data input appears to have stopped
2022-05-08 16:33:00.476 *** Data input appears to have stopped
2022-05-08 16:34:00.255 *** Data input appears to have stopped
2022-05-08 16:35:00.072 *** Data input appears to have stopped
2022-05-08 16:36:00.327 *** Data input appears to have stopped
2022-05-08 16:37:00.112 *** Data input appears to have stopped
2022-05-08 16:38:00.369 *** Data input appears to have stopped
2022-05-08 16:39:00.065 *** Data input appears to have stopped
2022-05-08 16:40:00.254 *** Data input appears to have stopped
2022-05-08 16:59:00.006 *** Data input appears to have stopped
2022-05-08 17:00:00.234 Hour changed: 17
2022-05-08 17:00:00.234 Calculating sunrise and sunset times
2022-05-08 17:00:00.234 Sunrise: 05:25:45
2022-05-08 17:00:00.234 Sunset : 20:17:37
2022-05-08 17:00:00.234 Tomorrow sunrise: 05:24:16
2022-05-08 17:00:00.234 Tomorrow sunset : 20:18:59
2022-05-08 17:00:00.234 Tomorrow length diff: 171
2022-05-08 17:00:00.234 *** Data input appears to have stopped
2022-05-08 17:01:00.010 *** Data input appears to have stopped
2022-05-08 17:02:00.282 *** Data input appears to have stopped
2022-05-08 17:02:40.921 WS Client Disconnected
2022-05-08 17:05:01.556 *** Data input appears to have stopped
2022-05-08 17:06:00.338 *** Data input appears to have stopped
2022-05-08 17:58:00.125 *** Data input appears to have stopped
2022-05-08 17:59:00.077 *** Data input appears to have stopped
2022-05-08 18:00:00.022 Hour changed: 18
2022-05-08 18:00:00.022 Calculating sunrise and sunset times
2022-05-08 18:00:00.023 Sunrise: 05:25:45
2022-05-08 18:00:00.023 Sunset : 20:17:37
2022-05-08 18:00:00.023 Tomorrow sunrise: 05:24:16
2022-05-08 18:00:00.023 Tomorrow sunset : 20:18:59
2022-05-08 18:00:00.023 Tomorrow length diff: 171
2022-05-08 18:00:00.024 *** Data input appears to have stopped
2022-05-08 18:01:00.479 *** Data input appears to have stopped
2022-05-08 18:21:00.327 *** Data input appears to have stopped
2022-05-08 18:22:00.072 *** Data input appears to have stopped
2022-05-08 18:23:00.339 *** Data input appears to have stopped
2022-05-08 21:28:21.911 Hour changed: 21
2022-05-08 21:28:21.911 Calculating sunrise and sunset times
2022-05-08 21:28:21.911 Sunrise: 05:25:45
2022-05-08 21:28:21.911 Sunset : 20:17:37
2022-05-08 21:28:21.911 Tomorrow sunrise: 05:24:16
2022-05-08 21:28:21.911 Tomorrow sunset : 20:18:59
2022-05-08 21:28:21.911 Tomorrow length diff: 171
2022-05-08 21:28:21.911 *** Data input appears to have stopped
2022-05-08 21:28:52.976 Exiting system due to external: Ctrl-C
2022-05-08 21:28:53.128 Cumulus closing
2022-05-08 21:28:53.128 Stopping timers
2022-05-08 21:28:53.167 Stopping extra sensors...
2022-05-08 21:28:53.167 Extra sensors stopped
2022-05-08 21:28:53.167 Stopping station...
2022-05-08 21:28:53.229 HTTP Station (Ecowitt) Stopped
2022-05-08 21:28:53.229 Station stopped
2022-05-08 21:28:53.229 Writing today.ini file
2022-05-08 21:28:53.613 Completed writing today.ini file
2022-05-08 21:28:53.613 Station shutdown complete
2022-05-08 21:28:54.115 Cumulus has shutdown
2022-05-08 21:28:54.115 Exiting system due to external: Ctrl-C
2022-05-08 21:28:54.117 Cumulus closing
2022-05-08 21:28:54.118 Stopping timers
2022-05-08 21:28:54.118 Stopping extra sensors...
2022-05-08 21:28:54.118 Extra sensors stopped
2022-05-08 21:28:54.118 Stopping station...
2022-05-08 21:28:54.118 HTTP Station (Ecowitt) Stopped
2022-05-08 21:28:54.118 Station stopped
2022-05-08 21:28:54.118 Writing today.ini file
2022-05-08 21:28:54.119 Completed writing today.ini file
2022-05-08 21:28:54.119 Station shutdown complete
2022-05-08 21:28:54.240 Releasing Mutex
2022-05-08 21:28:54.625 Cumulus has shutdown
