Author Topic: Access W/U spikes, not caused by fan.  (Read 1220 times)
Offline HeloMech
« on: March 09, 2022, 03:06:52 PM »
I have a weird spike issue, that I believe is stemming from the Access and not the fan.  Happens at odd hours, middle of the night and it also affects the Baro pressure, which is built into the access. I have reset the Access several time and restarted my router several times, but it pops back up.  Anyone seen a similar issue?
« Last Edit: March 09, 2022, 04:01:54 PM by HeloMech »
Acurite #01075RM  5in1 W/ Access
Acurite #06016M    Color Display
Acurite #06058M    HD display
Acurite #06045M    Lightning Detector  (2)
Acurite #06002RM  Temp/Hum Sensors  (4)
Acurite #00827A1   What to Wear display  (for the camper)
Offline DoctorKnow
Re: Access W/U spikes, not caused by fan.
« Reply #1 on: March 09, 2022, 07:34:38 PM »
Appears to be a very bad signal between the Atlas and the Access. Watch your page on Wunderground. It should updated every 10 seconds rapidly.
Offline davidefa
« Reply #2 on: March 10, 2022, 03:11:04 AM »
It may be also a problem of wu ( https://www.wxforum.net/index.php?topic=43047.0 )
Offline worachj
  • Twin Cities, Minnesota
« Reply #3 on: March 10, 2022, 08:56:49 AM »
Have you check if the graphs on MyAcurite and WU match?
AcuRite Atlas
KMNSAINT173
