So far I am impressed. The sensor seems more sensitive and less laggy than the traditional windcups which is not a surprise I guess.
There are a lot of comments that the traditional weakness of ultrasonic is strong winds and rain to distort the readings. So far I have not had any heavy weather here to gauge that issue as I have barely seen any rain since installing the sensor for test.
I am not sure how many other folks outside of Hong Kong are testing although I know Mauro in Italy has been testing and has been happy so far.
I can confirm,
my ws80 has a very good performance about wind against my Davis vp2, more sensitive, lower threshold, higher gusts
My wind test could not be very accurate, my vp2 wind sensor, and also, ws80 sensor is near the ground, at about 2,5 mt height
About temperature, obviously, the performance is not good at the same, there's a little overestimation during the day, with good solar radiation and low wind, little against my passive vp2 but more high against the ecowitt wh31 sensor inside Barani Meteoshield Standard, and more higher than my Meteoshield pro, but I think it's normal due the little dimensions of ws80 solar radiation shield and his poor quality
Obviously, we have an underestimation during night hours with sky clear, also due to the ws80 solar radiation screen quality.
the ecowitt products are very good for me, gw1000+ws80+wh40+wh31 in a good solar radiation shield and you have a very good system
Sorry for my poor English
Mauro
