Author Topic: Mag Mount for Temp Sensor?  (Read 1818 times)
Offline LTCSZ
    • Hedgehog Alley
« on: May 11, 2011, 04:24:53 PM »
A friend with a motorhome has just purchased an AW-1090 station...He asked me if he could use a juryriggeed magnetic mount for his temp/humidity sensor so that he could move it around on his motorhome depending on how he was parked at the time...I want to appear to be intelligent and informed (?)...Will he have any problems with a mag mount (interference, etc?) Thanks,
Steve
Steve
Retired Lieutenant Colonel, USA
Garden City, KS, USA
    • Weatherelement Moline IL
Re: Mag Mount for Temp Sensor?
« Reply #1 on: May 11, 2011, 04:51:26 PM »
The magnet shouldn't affect the sensor.
OTOH, ensure the roof or wherever he wants to stick it is steel. Our moho roof has an aluminum skin over thin plywood, and the walls are fiberglas. I had to screw down a steel plate for the sat phone mag mount antenna.
It's hard to get a decent outdoor temp reading anywhere on a motorhome for several hours after stopping. It takes a while for all the engine and exhaust heat to dissipate.
Maybe a suction cup would be better.
« Last Edit: May 11, 2011, 04:54:49 PM by SLOweather »
Offline DanS
  • Chiang Mai weather
    • ThaiWx
« Reply #2 on: May 11, 2011, 07:12:02 PM »
My folks did the same thing with their motor home when they had it. As SLOweather mentioned, it can take a while to get good readings as the RV cools but after you get in position you can place the sensor the farthest point up wind to avoid the heat radiated.
Offline LTCSZ
    • Hedgehog Alley
« Reply #3 on: May 11, 2011, 08:23:34 PM »
Thanks for the info...My friend liked the suction cup idea...We'll see how it works tomorrow...
Steve
Steve
Offline xykotik
  • DonkeyTailWX DW6891
  • I'll deal with it tomorrow
    • DonkeyTail Weather
« Reply #4 on: August 26, 2011, 12:55:44 PM »
I know this is an old thread, but for what it's worth, I used velcro and it worked well, but it was always attached somewhere it wouldn't fall if the adhesive let go.
