Weather Related Organizations => PWSweather / AerisWeather / WeatherForYou => Topic started by: jwreynoldson on April 03, 2019, 01:09:37 AM
Just a heads up for anyone else whose homebuilt station is real time clock challenged...
The pwsweather observation upload http GET format for "&dateutc=" now supports "now" as s ubstitute for the specific date/time (YYYY-MM-DD hh:mm:ss) format, and will date stamp the observation for you. (compatible with the Weather Underground inplementation)
Thanks, pwsweather developers. I was able to port my station (now reporting to both) simply by changing the host web address and php link.
JR PWS: BALNARR2 WU:IBALNARR2, IFLINDER3
(PS: my previous workaround was to query pwsweather before uploading and ask it what it thought the time and date was)
Oddly enough, I seem to be having an issue with this. If I use dateutc=now, calls to PWSweather.com come back with the message:
ERROR: Missing required parameter dateutc
So maybe something has changed since the OP tried this.
I've just checked, and my station which uses this option is currently reporting successfully.
Thanks for checking.
It's still not working for me but I think it just gives that error message, even though that is quite possibly not the error. I sent a dummy call with completely bogus creds and got exactly the same message.
This is a swine to debug ...
There are two choices of path to upload to PWSweather. Maybe one path accepts dateutc=now and the other doesn't?
Path choices:
/pwsupdate/pwsupdate.php?
/weatherstation/updateweatherstation.php?
Well if you include the different domains there are actually even more choices. You can see results of my testing in the following post:
https://www.wxforum.net/index.php?topic=39535.0
I'm using
successfully.
Path choices:
I'm using
successfully.
Path choices:
Yeah, I am using the same endpoint as you. I still think is authentication related.
What's even more mysterious is mention of an API key of the PWSWeather 'Dashboard Page". The language there says:
Use this unique key when posting data to the PWSWeather API from your weather station software. You can generate a new key, but you must also update the key used when posting data to the API.
But the actual API is not referenced and use of an API key is not consistent with the WU format.
