Author Topic: New VP2 reads 0.5C lower  (Read 644 times)
Offline 4wd
    • North York Moors weather
« on: January 16, 2020, 03:25:16 AM »
My original VP2 is about ten years old and looks it, so as a birthday present I bought myself a new main unit.
At the moment they are side by side and the new one reads 0.5C lower and 4% lower humidity
That might seem reasonable sensor drift except the T/H sensor was only replaced in the old one last October!
While you wouldn't expect them to read identically this seems quite a troubling discrepancy.
The humidity difference is neither here nor there but I'm reluctant to set an upwards offset on the new one.
« Last Edit: January 16, 2020, 03:27:38 AM by 4wd »
Re: New VP2 reads 0.5C lower
« Reply #1 on: January 16, 2020, 03:49:27 AM »
I'm assuming when you replaced your sensor last you graduated from an SHT11 or 15 to a 31. With that, did you account for the -0.5C offset that is required with older VP2's when installing an SHT31?
Offline 4wd
« Reply #2 on: January 16, 2020, 04:14:29 AM »
The one I replaced with appeared the same as the previous one replaced 4 or 5 years earlier but if the offset should be 0.5 that's mighty suspicious!
« Reply #3 on: January 16, 2020, 04:25:22 AM »
Suspicious? No, it's fact. Older VP2's ISS transmitters are of a different protocol that require the offset when used with an SHT31. Yours applies.
Offline 4wd
« Reply #4 on: January 16, 2020, 04:41:22 AM »
This is the sensor would have been in from about 2014 until late last year, is it the older type?
« Reply #5 on: January 16, 2020, 04:49:43 AM »
Yes.
