Author Topic: Weather34 template(non meteobridge versions)  (Read 118628 times)
Offline Naxx
Re: HOMEWEATHERSTATION Dashboard template
« Reply #575 on: June 10, 2018, 05:06:38 AM »
CURRENT AIR QUALITY INDEX not working for me why?
http://www.pogodakielczow.com.pl/?theme=dark
Offline Ryan
« Reply #576 on: June 11, 2018, 11:09:17 PM »
So I'm trying to work through getting this set up. Never done this sort of thing before. I have a couple issues.
Where is the download that contains the mbx5-mysql-setup.pdf?
And when I am seeing the following error on the main page and a couple other places.
Warning: ini_set(): Headers already sent. You cannot change the session module's ini settings at this time in /srv/users/serverpilot/apps/pws/public/settings.php on line 83
So I was able to get rid of the error by removing "ini_set('session.use_cookies', '0')" from line 83 of the settings file!
But I would still appreciate it if someone could point me to "the download" and PDF that are reference on the setup page. https://weather34.com/homeweatherstation/guides/setupmeteobridge.html
Offline weather34
« Reply #577 on: June 12, 2018, 06:00:56 AM »
you need to contact mystic_art he maintains that version for WS1001 and provides the polish translations..
Offline Mystic_Art
« Reply #578 on: June 12, 2018, 06:03:06 AM »
Everything is ok.
I contacted with him and sended corrected version of this module
Wysłane z mojego SM-G935F przy użyciu Tapatalka
Offline weather34
« Reply #579 on: June 13, 2018, 02:29:56 AM »
hello Ryan
im sorry I tried to reply yesterday but my 3g connection kept timing out so anyway there is not a PDF that is my mistake originally there was but it is basically a replica of what you see on the web page , the pdf added an extra 1.5mb of download size so i just create a web page so i sincerely apologize for the misinformation and feel free to email me any time Im stuck at home for the foreseeable future overseeing a roof construction and decorating after fire..
on another note I had a few requests for a way of using the new wifi logger for Davis console the short answer is at the moment NO possibly with some collaboration with the developer and a few users it could be done . However a big however good old trusted Boris at meteobridge as announced is own solution to this and requires no change in template as far I am aware at the moment and has all the hallmarks of the familiar meteobridge features .
see more information about Meteobridge Nano here ... http://meteobridge.com/wiki/index.php/Meteobridge_NANO
brian ...
Offline stewart45
    • Newlands Weather Station
« Reply #580 on: June 13, 2018, 09:00:51 AM »
Meteobridge Nano looks interesting anyone know where it can be bought and how much
Offline Ryan
« Reply #581 on: June 13, 2018, 10:16:52 PM »
hello Ryan
brian ...
No worries. I will send you an email this weekend.
Offline Ryan
« Reply #582 on: June 13, 2018, 10:18:19 PM »
"Meteobridge NANO is planned to hit stores of established resellers in August 2018. Price still to be decided."
I will definitely be buying one if the price is reasonable.
Offline stewart45
« Reply #583 on: June 14, 2018, 03:43:49 AM »
Yes me to, price will be the deciding factor
Offline prestwickwx
    • Myrtle Beach - Rain or Shine
« Reply #584 on: June 14, 2018, 08:38:58 AM »
hello Ryan
brian ...
The nano looks interesting. It would eliminate the distance issues associated with the present Meteostick and do away with the Meteobridge router. Since, the Davis wireless communicates over much longer distances than the "Stick".
Chuck
Offline bettsr67
  • Just BE NICE! That's all it takes to be a decent h
    • LOBWX
« Reply #585 on: June 18, 2018, 08:41:19 PM »
Hello all,
I just put up your template on my Raspberry PIB3+ a couple of days ago. The RPI works fine PHP 7.0.27-0+deb9u1,  Linux,  Zend 3.0.0; MySQL 5.5.5-10.1.23-MariaDB-9+deb9u1; Apache2 / 2.4.25, etc. My Station is the Ambient WS1401 IP hooked up to Meteobridge all working fine as well.
I have a few of questions for you fine people.
1. In the current conditions block I want to use METAR for my area KSBP. I have the API key from CheckWX but it only will show Istanbul, Turkey? Thanks Ryan
2. In the Forecast block nothing is there and it is reading offline. I do have the API key from DarkSky entered in the easyweathersetup.php Thanks Ryan
3. Total rain fall for 2018, 25.4 inches? Where is the template getting this number from?
Here I am on the world wide PI http://bobspib3.com/pws
~Bob~
« Last Edit: June 18, 2018, 10:24:34 PM by bettsr67 »
Offline Ryan
« Reply #586 on: June 18, 2018, 08:57:08 PM »
Hello all,
~Bob~
Doing the first section of Part 2 should fix the issue with the API data not updating. Same thing happened to me. https://weather34.com/homeweatherstation/guides/setupmeteobridge.html
Offline bettsr67
    • LOBWX
« Reply #587 on: June 18, 2018, 10:28:45 PM »
Thank You Ryan that worked on Issue 1 & 2 for me. I did not have the correct directory name /mbdbfiles i had /mdbfiles.
Offline tomipasin
« Reply #588 on: July 05, 2018, 02:25:40 PM »
Hi everybody!
I'm facing some problems with my Weather34 template to Cumulus.
All information and comunication is OK but sometimes the "feels", "Wet bulb", "humidity" and "Dewpoint" don't show information and appears aour of order, as show below:
When the correct is as follow:
Offline gand
    • Lynghuzed
« Reply #589 on: July 22, 2018, 12:18:49 PM »
Hi
I have just installed the Meteobridge/MySql version.
Is there any way to import data from WU(month/year data), before I close down my account?
gand
Offline Ryan
« Reply #590 on: July 22, 2018, 12:44:51 PM »
Hi
gand
Put the Weather History section into "Yearly Mode" then click on the Table tab. There's a download button in the top right corner of the table.
I would keep the WUnderground up and running personally. I still look at it on my phone so that I can see the graphs.
Offline gand
    • Lynghuzed
« Reply #591 on: July 26, 2018, 01:22:24 AM »
Hi
Thanks for the proposed solution.
As far as I can see, there is a difference in the data definition, so I can't import data directly from WU to HWS.
From WU:
2018-7-24,27.9,22.4,16.9,22.3,19.2,15.6,97,83,70,1014,1013,11,0,18,0.00
From Jul.txt(mbcharts):
25 Jul,28.6,19.5,23.00,18.00,0.00,0.0,0.0,0.00,1015.80,1014.70,0
Data from WU must be changed before import to HWS. I thought others had the same challenge and had found a solution. There are 2 files pertaining to this, month.txt and year.txt
Rgds
gand
Offline gand
    • Lynghuzed
« Reply #592 on: August 09, 2018, 01:29:33 AM »
Hi
In the block the max. gust is displayed, in this case 4.9m/s. The graph shows max gust at 5.6m/s and the same value is in the sql database. The station has reported 4.9m/s, so it is the correct value.
Does anyone know why the numbers are not the same?
gand
Offline weather34
« Reply #593 on: August 09, 2018, 02:09:58 AM »
good morning
please provide a url via pm or here i will take a look and see if i can replicate it locally here using your data.
brian
Offline gand
    • Lynghuzed
« Reply #594 on: August 09, 2018, 02:15:05 AM »
Hi
Thanks for the prompt response.
URL:
vsvejr.dk/pws
gand
Offline weather34
« Reply #595 on: August 09, 2018, 02:51:24 AM »
hello
ive downloaded your today data and using your realtime data file locally i can see identical to what your reporting however does this happen everyday ?
what is the meteobridge live data panel showing for max gust ?
the chart file only records and displays what is sent to the mysql from the meteobridge at that given time.
so at 01:24 this morning it recorded this
0,1:24,24.2,1011.10,0.00,0,5.6,4.5,0.00,20.90,0.00,284.00,09 Aug,2018-08-09 01:24:26,0
i have think i found thew cause it but would need to test locally for a while. if you can pm your email ? i can send you a file to test for a few days .
brian
Offline gand
    • Lynghuzed
« Reply #596 on: August 09, 2018, 05:30:31 AM »
Hi
Yes, it's same every day. The Meteobridge Live Panel also shows 4.9m/s
I'll will send a PM with my mailaddress.
Thanks again.
gand
Offline mikeym2m
    • MikeyM's Thornhurst PA Weather
« Reply #597 on: August 24, 2018, 02:41:54 PM »
As a new user of both Weather34 and the WeatherFlow station I'm having trouble with the time  in the template. Attached is a scrrenshot. Sunrise and sunset times are out of wack also. I think I have the "Longitude" set properly @ -75.6.
http://www.mikeymsweather.com/PWS
Offline weather34
« Reply #598 on: August 24, 2018, 02:45:24 PM »
hi pm easyweathersetup password you can change at a later time anytime
Offline weather34
« Reply #599 on: August 25, 2018, 12:44:32 AM »
good morning i have a good look there were just a few things not set correctly but i cant get my head why your timestamps are stuck at 19:00 but data is updating.ive sent you a pm and if you dont mind ill take another look on monday . have a nice weekend..brian
