Author Topic: Regional Mesonet Map NWWN - not showing stations  (Read 342 times)
Offline n7dq
    • Island Drive Weather
« on: March 17, 2024, 08:44:06 PM »
I've been working to get NWWN Mesonet Map working, I've got the current release.
It looks like the script  mesonet-map-inc.php is ending early when I do debug=true.
I pretty sure I did something wrong in the configuration but need some guidance to work to a solution.
https://www.n7dq.com/weather/wxmesonetmap.php
Thanks in advance.
Mike
Re: Regional Mesonet Map NWWN - not showing stations
« Reply #1 on: March 17, 2024, 09:06:04 PM »
For some unknown reason, the needed script mesonet-map-json.php is has a 500-Server Error return instead of the expected JSON file.
Change mesonet-map-json.php from
<?php
at the top to be
<?php
error_reporting(E_ALL);
ini_set('display_errors','1');
so we can see what the issue may be.
No stations will be shown without having that script fully working.
Offline n7dq
« Reply #2 on: March 17, 2024, 09:13:49 PM »
Here is the message I got back after the change:
Fatal error: Uncaught Error: Call to undefined function locale_get_default() in /var/www/html/weather/mesonet-map-common.php:921 Stack trace: #0 /var/www/html/weather/mesonet-map-json.php(117): new_strftime() #1 {main} thrown in /var/www/html/weather/mesonet-map-common.php on line 921
Where would this function be defined?
Mike
« Reply #3 on: March 17, 2024, 09:20:08 PM »
Ahh... that's a PHP issue.  The locale_get_default() function is built-in to PHP when PHP is compiled with --enable-intl
Ask your hoster to include the INTL functions in your PHP.
Offline n7dq
« Reply #4 on: March 17, 2024, 09:44:35 PM »
That would be me. Should be easy to figure out.
Just need get added on the Lightsail instance.
Thank you for all the help.
Mike
Offline n7dq
« Reply #5 on: March 18, 2024, 10:06:22 AM »
I installed php-intl on ubuntu 22.04 LTS and this solved the problem without any other changes.
Mike
« Reply #6 on: March 18, 2024, 10:08:25 AM »
Great!  Glad you got it sorted out.
