I am looking for software that will work with my Accurite weather station. PC Connect no longer works with Vista so I am need of another software program so I can continue to feed my data to weather underground. Thanks
Nothing has changed with the wunderground protocol. Assuming not being able to talk to myAcurite doesn't bork the software completely, older PC Connect software should still be able to transmit to wunderground.
If the older software is completely broken, you might try putting a trivial web server (port 80) on your Vista machine. That way references to hubapi.myacurite.com will loop back to the web server and it might be enough to satisfy the software that the old myAcurite server still exists.
Worth a shot if you can't upgrade from Vista to at least 7.
