Hi There,
I managed to add Soil and AQI to my Gizmo for the Saratoga script.
My soil variable is called "$cSoil" and the AQI pm2.5 is called "$AQI_P2_idx", yours might be different, but add them in the script.
The two files to edit are ajax-gizmo.php and ajaxgizmo.js (note that if you change and upload the ajaxgizmo.js, you should go to your browser and clear "cached files and images" or you might not see the changes.
First in the file "ajax-gizmo.php" add function gizmo_get_AQIrange() just before function gizmo_get_UVrange( ) to display AQI quality box after your AQI value.
see ajax-gizmo-1.txt
function gizmo_get_AQIrange ( $inAQ ) {
// figure out a text value and color for UV exposure text
// 1 to 50 Good
// 51 to 100 Moderate
// 101 to 150 Poor
// 151 to 200 Unhealthy
// 201 to 300 V.Unhealthy
// 300+ Hazardous
$aq = $inAQ;
switch (TRUE) {
case ($aq == 0):
$aq = langtransstr('Good');
break;
case (($aq > 0) and ($aq < 51)):
$aq = '<span style="border: solid 1px; color: black; background-color: #A4CE6a;"> ' . langtransstr('Good') . ' </span>';
break;
case (($aq >= 51) and ($aq < 101)):
$aq = '<span style="border: solid 1px; color: black; background-color: #FBEE09;"> ' . langtransstr('Moderate') . ' </span>';
break;
case (($aq >=101 ) and ($aq < 151)):
$aq = '<span style="border: solid 1px; color: black; background-color: #FD9125;"> ' . langtransstr('Poor') . ' </span>';
break;
case (($aq >=151 ) and ($aq < 201)):
$aq = '<span style="border: solid 1px; color: #FFFFFF; background-color: #F63F37;"> ' . langtransstr('Very Unhealthy') . ' </span>';
break;
case (($aq >= 300) ):
$aq = '<span style="border: solid 1px; color: #FFFF00; background-color: #807780;"> ' . langtransstr('Hazardous') . ' </span>';
break;
} // end switch
return $aq;
} // end get_AQIrange
Next add the ajaxcontent layers to the ajax-gizmo.php. Mine are ajaxcontent9 for the soil and ajaxcontent10 for the AQI
see ajax-gizmo-2.txt
<span class="ajaxcontent8" style="display: none"><?php langtrans('UV Index'); ?>:
<span class="ajax" id="gizmouv"><?php echo $VPuv; ?></span>
<span style="color: #ffffff">
<span class="ajax" id="gizmouvword"><?php echo gizmo_get_UVrange($VPuv); ?></span>
</span>
</span>
<span class="ajaxcontent9" style="display: none"><?php langtrans('Soil Temp'); ?>:
<span class="ajax" id="gizmotemp"><?php
echo gizmo_strip_units($cSoil).$uomTemp; ?></span>
</span>
<span class="ajaxcontent10" style="display: none"><?php langtrans('Air Quality'); ?>:
<?php echo $airstr; ?>
<span class="ajax" id="gizmouvword"><?php echo gizmo_get_AQIrange($AQI_P2_idx); ?></span>
</span>
</span>
</div>
<!-- ##### end of AJAX gizmo ##### -->
Finally increase the "ajaxtotalcontent" value in ajzxgizmo.js file, I had to add 2 to make it 10.
see ajaxgizmo.txt
function ajax_get_total() {
ajaxtotalcontent = 10; // content0 .. content9 plus the UV if you have it
if (showUV) { ajaxtotalcontent++ ; } // UV display is in last content area
https://www.wraxallweather.co.uk/wxindex.phpI hope this helps, it worked for me.
Dave
ps made it more readable.
