Author Topic: Favorite GRLevel3 Settings?  (Read 23564 times)
Offline WeatherBeacon
  • Chief
    • http://www.wxbeacon.com
« on: August 31, 2007, 11:29:22 PM »
Friends:
We've had a very quiet spring and summer in my area, but in the past two weeks we've have some doozies of storms with heavy downpours, strong gust fronts, and nearby tornadoes.
Do I understand correctly that most of you use GRLevel3 rather than GRLevel2?
Second, I downloaded the trial version of GR3. It has so many settings and options that I feel like I'm in over my head -- too much to learn in too little time. So I'm wondering if you'd please kindly tell me what some of your favorite radar settings are.
Finally, it isn't a subscription service, right? (I see some references to AllisonHouse, but GR3 doesn't rely on subscribing to AH, does it?)
Thanks much!
Regards,
Kevin...
Mae govannen!
Re: Favorite GRLevel3 Settings?
« Reply #1 on: August 31, 2007, 11:42:05 PM »
I use GRLevel3, even though our climate doesn't have thunder storms nearby (maybe once or twice a year).  The radar images are amazing (I tend to use the CR248 images on my site).
No, AllisonHouse feeds aren't required as GRLevel3 can get NEXRAD data directly from the NWS...  however, the feeds provide other things that are highly useful.  In particular, the USPLN lightning feed overlays on the radar and is great to help set ranging/calibration on Boltek/Nexstorm setups.
I subscribe to the $10/mo feed set (with a 1year deal for $100).
I'm sure Tom at Carterlake can help here.. he's very active on the GR3 forum and runs the GRLevel3 (unofficial, but highly useful) FAQ.
Best regards,
Ken
Offline carterlake
    • CarterLake.org
« Reply #2 on: September 01, 2007, 08:06:56 AM »
Hi Kevin,
I use GRLevel3. Level 2 is more for the met experts out there. (You do not need to buy anything for Level 3 data ... it is free and readily available... but Level 2 data will cost you some money unless you can find a free source.)
All I use is GRLevel3 without a subscription to anything.
GrLevel3 is actually pretty easy to use... you have a LOT of options but really, I mostly only use the radar image (I like BR248) and the base velocity images (to see where the tornadic activity is).
There's actually a copy of the FAQ available to the public on http://www.grlevelxstuff.com/board/index.php?topic=13.0
They also have some excellent flash videos on how to do things.
Most stuff is pretty simple though...
Go under site and setup your default radar location.
Download a background from:
http://www.myweatherstations.com/grsmaps.shtml
-or-
http://www.allisonhouse.com/grlevelx/maps/
How to use background images:
1) Right click on the image you want and do a "Save Target as..." and save file to your computer
2) Extract the .zip file. Inside are two files: a text file and an image file
3) You'll want to put the image file some place safe (may we suggest the GRLevelx folder)
4) Open the text file in a text editor like Notepad. It contains some numbers that you'll need in a minute.
5) With GRLevelX open, go under GIS... Settings... Background
6) This opens another window. Click the ... under Background Bitmap to select the BMP file you downloaded
7) Under Longitude From and To, Latitude From and To, copy the numbers provided from the text file
8) Hit OK and your background should appear
Go under products and turn on storm attributes and warnings (now your right hand buttons are lit up).
And that's about it... you're ready to play.
It took maybe a day of playing around to learn this and that... having an FAQ does help... and grlevelxstuff.com has become an excellent resource.
Davis VP2 6153; Weather Display (LIVE w/ Ajax); Quickcam for Notebooks Pro; Boltek w/ Nexstorm; GRLevel3; live NOAA Radio
« Reply #3 on: September 01, 2007, 09:54:43 AM »
If you use the free NOAA feed for your level 3 data you can go back I think as far as 2 days to get past data. With Allinsonhouse I think you are only limited to about 30 images but I not quite sure about that.
Offline carterlake
    • CarterLake.org
« Reply #4 on: September 01, 2007, 05:22:46 PM »
Quote from: "ocala"
NOAA actually has an archive of data going back to .... 1995? but it takes a bit of effort to load the data.
  • Chief
« Reply #5 on: September 01, 2007, 05:55:29 PM »
Thanks much, guys! Your responses have been very helpful.
I already have a map from myweatherstations.com for my mesomap that I could use with GR3 (although I might want another map that is zoomed in a bit more).
Please keep the suggestions coming!
One thing I'm confused on is --- which of GR3's radar images are the most telling for storms and rotation? I'm seeing these radar options: BR1, BR2, BR3, BV1, (no BV2), BV3, SRV1, SRV2,  SRV3,  SRV4, SW32 (among others). Some of those look similar (in that they show greens and reds), yet they appear very different. If I were trying to see rotation or a hook echo, which radar image is best suited for that? I expect it would be one of the SRV maps, but which one(s)?
One afternoon last week when we had a lot of severe storms in the area, one of the TV meteorologists showed a radar image and said, "It looks like we're seeing rotation here." I had GR3 running and went straight to that area and couldn't see anything that looked like possible rotation. I figured I was looking at the wrong map, so I flipped through several other GR3 images and still couldn't see anything that looked suspicious.
Thanks much!
Regards,
Kevin...
Mae govannen!
« Reply #6 on: September 01, 2007, 09:28:29 PM »
Kevin BR1 is what you want to use to look at the storms. BR2-5 is the angle of the radar. Where as BR1 is the lowest and BR5 is the highest. If you use the highest angle the radar will overshoot the storms and you won't see much.
As for BV and SRV go with SRV. Base Velocity will show the rotation but it doesn't take into account the storms motion. SRV stands for Storm Releative Velocity and does take into account the storms motion. Check this link for a good description.
http://okfirst.ocs.ou.edu/train/materials/Tstorms/srvelmeso.gif
I don't use that radar program but the one I use has something called TVS which stands for Tornadic Vortex Signature. This can be overlayed on the Base Reflectivity map to show you where the radar is picking up rotation. It's  a upside down triangle. When it pops up just go to your SRV map and you should be able to see the rotation. I assume that GR3 has this but you may want to check with someone that uses the program.
  • Chief
« Reply #7 on: September 01, 2007, 09:31:56 PM »
Great! Thanks a lot, Ocala!
Regards,
Kevin...
Mae govannen!
Offline aifan27
    • http://www.newtownweather.com
« Reply #8 on: September 01, 2007, 11:14:21 PM »
Kevin,
You can go here to see the flash tutorials that Tom mentioned earlier.
  • Chief
« Reply #9 on: September 09, 2007, 12:26:38 AM »
I'm missing something, folks.
I went to the above link, clicked the "Tutorials" button, but only ads pop up. What am I missing?
Regards,
Kevin...
Mae govannen!
Offline carterlake
    • CarterLake.org
« Reply #10 on: September 09, 2007, 12:19:27 PM »
Quote from: "WeatherBeacon"
Regards,
Kevin...
You have to register (it's free) to see any content on the site.
  • Chief
« Reply #11 on: September 09, 2007, 10:41:06 PM »
Quote from: "carterlake"
Regards,
Kevin...
Ah ha! :oops:  Makes sense. Thanks!
Kevin...
Mae govannen!
