Author Topic: Question about ecowittModules Meteotemplate block from iz0qwm  (Read 635 times)
Offline Daali
  • weather n00b
    • The weather in Jefferson, GA
« on: August 01, 2021, 08:49:59 PM »
I am using his lightningew and air quality blocks and they are working great!  feeding data to Meteotemplate from FOSHKplugin at the moment.  Looking through the php, it looks like it should populate since "I think" all the necessary values are there.  I am sure I am missing something as it has been the story of the day.
{"U":1627865234,"TIN":27.5,"HIN":42,"P":981.71,"UGP":981.71,"B":248,"W":0,"G":0,"S":0,"UV":0,"RR":0,"R":0,"T1":28.5,"H1":66,"PP1":10,"LT":1627845940,"L":14,"LD":10,"WBAT":"OK","T1BAT":"OK","PM1BAT":"OK","LBAT":"OK","SS":1.08,"SW":"FOSHKplugin-v0.08","UTime":1627865236,"TINTime":1627865236,"HINTime":1627865236,"PTime":1627865236,"UGPTime":1627865236,"BTime":1627865236,"WTime":1627865236,"GTime":1627865236,"STime":1627865236,"UVTime":1627865236,"RRTime":1627865236,"RTime":1627865236,"T1Time":1627865236,"H1Time":1627865236,"PP1Time":1627865236,"LTTime":1627865236,"LTime":1627865236,"LDTime":1627865236,"WBATTime":1627865236,"T1BATTime":1627865236,"PM1BATTime":1627865236,"LBATTime":1627865236,"SSTime":1627865236,"SWTime":1627865236,"T":28.5,"TMX":28.5,"TMN":28.5,"H":66,"PP0":10,"TTime":1627865166,"TMXTime":1627865166,"TMNTime":1627865166,"HTime":1627865166,"PP0Time":1627865166,"D":21.5,"DTime":1627865236,"A":32.9,"ATime":1627865236}
Question: should this block be showing data as active with the above meteotemplateLive.txt?
ps. I know the block works as I temporarily set up his ecowitt gateway, it worked like a champ and was awesome)
« Last Edit: August 01, 2021, 08:53:22 PM by Daali »
Offline davidefa
Re: Question about ecowittModules Meteotemplate block from iz0qwm
« Reply #1 on: August 02, 2021, 03:11:20 AM »
No, the ecowittModules block will work only in conjunction with the ecowitt plugin ( as it defines differently a few fields that are checked by the ecovittModules block, particularly the batteries fields should be numeric ).
If you want to use this way ( I mean: weather station->FOSHKplugin->meteotemplate ) you have to configure FOSHKplugin to forward data to the ecowitt plugin in ecowitt format
I have updated both block and plugin ( you may find them in the meteotemplate forum, in the respective subforums ) to include all ecowitt sensors and 'a few' other things ( such as virtual sensors and sensor rename ).
But the two versions are now incompatible: so if you want to install the iz0qwm ecowitt plugin you have to use his ecowittModules block ( and if you want to use my ecowitt plugin you have to use my ecowittModules block )
« Last Edit: August 02, 2021, 03:23:06 AM by davidefa »
Offline Daali
  • weather n00b
« Reply #2 on: August 02, 2021, 07:25:39 AM »
Thank you again davidfa!  can you point me to your meteotemplate work?
sorry for asking all these meteotemplate type questions here, I am waiting on forum activation over there.
Thanks again sir!
Offline davidefa
« Reply #3 on: August 02, 2021, 09:26:41 AM »
Here the plugin and the block ( last versions are always available in the meteotemplate forum )
Offline Daali
  • weather n00b
« Reply #4 on: August 02, 2021, 10:48:49 AM »
Thank you sir!  I got them installed and the block read data right away from FOSHKplugin feeding of the meteotemplateLive.txt.
I'm all activated on meteotemplate forum! so I'll start asking silly questions there =P
Thank you for your code and help!
Offline Daali
  • weather n00b
« Reply #5 on: August 02, 2021, 08:17:25 PM »
davidefa,
do you have a github page where you keep your work?
Offline davidefa
« Reply #6 on: August 03, 2021, 02:38:10 AM »
Yes, but is quite outdated ( it generally points to the meteotemplate forum )
https://github.com/davidefa/meteotemplate-repository
