On the left is my old Fine Offset weather station. In the background is my new Ecowitt weather station. Not visible here are
1. House from which photo was taken (with zoom on camera)
2. Trees on left and right
The old weather station is in a less than ideal location as it's not well above the house and it
tends to show the wind coming from only one direction (which is
mostly true because of local topography, but not always). It's still in operation, uploading data via WeeWX to my site and to some online services. I plan to cut over all that to the new station in due course.
I don't have a perfect location for the sensors and with the old station I traded off ease of replacing batteries and cleaning rain gauge, plus convenience of using existing vegetable patch pole, against trying for something that might better show a bit more variety in wind direction.
The new station has rechargeable batteries and a solar cell, so should not need as much maintenance, and I have positioned it higher up (the property is on a slope) where it's clear of the house. It's about 3m clear of the ground. As can be seen there's one tree close to it, but in a direction the wind pretty much never comes from. The other trees, further away, are deciduous -- much less dense -- and less likely to affect wind direction readings. Already I see much greater variability in wind direction.
To facilitate maintenance I put the new station on a pole that is sunk into a 6 inch deep block of wood, 3 inches square, in a metal fence post spike. If I loosen a couple of bolts I can slide the 8ft pole out. Yesterday, during gusts of up to 40km/hr, it was shaking a bit at the top. I think the pole is too long and insufficiently rigid in this setup so I'm going to have to redo this.
At the moment I can't see the level indicator on top of the unit -- I need a step ladder (or a periscope
Meanwhile, I'm wondering
1. How much does vibration really matter?
2. Ditto having the instruments
precisely level?
I assume that both matter most for accurate rain gauge readings but am curious just how critical these are.
