Author Topic: v6.0 - Unable to edit hourly rain values. **solved**  (Read 2281 times)
Offline monymony
    • Cecil County Maryland Weather
« on: November 26, 2024, 08:03:57 AM »
Had to make an manual adjustment to my rain totals and when I went to ADMINISTRATION > EDIT HOUR DATA and then to the current hour (7:00) I would make my adjustment and get the confirmation the update was successful.  Then when I would refresh the page the edited value would just show 0.00in.  Tried a couple times and even did two system reboots and the update would not be saved.
Reverted to v5.9 and was able to make the change without a problem.  The attachment shows where I was trying to edit.
System Info (after reverting to v5.9):
Platform:   Raspberry Pi 4 Model B
RAM:   3895 MB total, 3772 MB free (3% used)
Storage:   WD SLC, 7.1 GB total, 7.0 GB free (1% used, 224.4 yrs)
SW Version:   Meteobridge 5.9 (May 26 2024, build 3388), FW 1.4
« Last Edit: December 20, 2024, 08:31:04 AM by docbee »
Davis VP2 using WeatherCat v3.11
WU: KMDELKTO10 -  CWOP: EW3643 - CoCoRaHS: MD-CC-16
Offline docbee
  • Moderator
    • smartbedded
Re: v6.0 - Unable to edit hourly rain values
« Reply #1 on: December 02, 2024, 05:28:39 PM »
No Problem with 6.0 here. When you click on the value you can enter a new value. When you click onto the timestamp the entry is erased.
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
« Reply #2 on: December 02, 2024, 07:31:43 PM »
If the hour that you are trying to edit has not expired, you can't edit it.
ie: you must wait until after 7 to edit the 6 to 7 time frame.
Offline monymony
« Reply #3 on: December 11, 2024, 09:19:47 AM »
Interesting... I will update to the latest version and try things again now knowing a bit more about the behavior.  Thanks for info.
UPDATE: Confirmed working - waiting until the next hour to edit resolved the issue.  Now running v6.1.
« Last Edit: December 12, 2024, 07:56:34 AM by monymony »
