Author Topic: Fall/Winter '18/'19  (Read 36126 times)
Re: Fall/Winter '18/'19
« Reply #51 on: October 04, 2018, 03:56:18 PM »
Spearfish South Dakota holds the fastest change.
Wiki:
World record temperature change
Spearfish holds the world record for the fastest recorded temperature change. On January 22, 1943 at about 7:30 a.m. MST, the temperature in Spearfish was −4°F (−20°C). The Chinook wind picked up speed rapidly, and two minutes later (7:32 a.m.) the temperature was +45 °F (+7 °C) above zero. The 49 °F or 27 °C rise in two minutes set a world record that still holds. By 9:00 a.m., the temperature had risen to 54 °F (12 °C). Suddenly, the chinook died down and the temperature tumbled back to −4 °F or −20 °C. The 58 °F or 32.2 °C drop took only 27 minutes. The sudden change in temperatures caused glass windows to crack and windshields to instantly frost over.
Offline WeatherHost
« Reply #52 on: October 04, 2018, 05:55:16 PM »
Tied the Record of 90.  Record tomorrow is 89 which is also the forecast high.
« Reply #53 on: October 04, 2018, 08:34:43 PM »
Tweet I sent out
https://twitter.com/RMSWeather/status/1047822747689279488
We had a 40 degree drop yesterday.
or
« Last Edit: October 04, 2018, 08:44:19 PM by chief-david »
Offline DRoberts
« Reply #54 on: October 04, 2018, 09:10:38 PM »
Reply to 54 degree temperature range at my station. That is quite a range, isn't it? I am using a Davis VP2 FA and the location is very country. No pavement near it, only grass.
Most range I have ever experienced. (I don't live near Spearfish, SD.  :-)
Here is a graphic from our NWS office in Hastings, NE. This office has the climatological records closest to me, but they are about 90 miles away. Nevertheless, it sort of backs up my observations of 95 for a high and 41 for the morning low.  Our high today was 44, after yesterday's high of 95 that is quite a range also.
Thought it might be interesting.
« Reply #55 on: October 04, 2018, 09:25:44 PM »
High in Valentine today was 39°.   :roll:
Gets little better Tomorrow except for night HS FB game forecast, Wouldn't be there except for cousins grandson is playing.
: Friday Night
 A 40 percent chance of rain before 1am. Patchy frost after 3am. Otherwise, partly cloudy, with a low around 31. North northwest wind 5 to 15 mph, with gusts as high as 20 mph.
« Reply #57 on: October 05, 2018, 12:29:08 PM »
I can count on one hand the number of times I've seen 100% chance of rain in 4 years.
Offline WeatherHost
« Reply #58 on: October 05, 2018, 12:33:01 PM »
I've seen it fairly often for Day 1, 2 or sometimes 3, not for Day 4.
Offline WeatherHost
« Reply #59 on: October 05, 2018, 07:06:12 PM »
RECORD EVENT REPORT
NATIONAL WEATHER SERVICE PADUCAH KY
0431 PM CDT FRI OCT 05 2018
...RECORD HIGH TEMPERATURE SET AT PADUCAH KY...
 A RECORD HIGH TEMPERATURE OF 91 DEGREES WAS SET AT PADUCAH KY TODAY.
THIS BREAKS THE OLD RECORD OF 89 SET IN 1998.
Third day in a row.
« Reply #60 on: October 06, 2018, 02:49:47 AM »
Got to 89 here on Friday.  OKC TV weatherman thinks we're finished with 80s until next spring.  I wouldn't want to guarantee that since November of 2017 had a couple of days with 82.
Offline WeatherHost
« Reply #61 on: October 07, 2018, 04:47:29 PM »
Needing A/C in October due to multiple days of 90+ has to be some kind of level of criminal insanity.
The reds are records for the date:
« Last Edit: October 07, 2018, 04:53:20 PM by WeatherHost »
Offline SkellyCA
« Reply #62 on: October 07, 2018, 05:15:13 PM »
It's windy here in the SF East Bay. WE are under a severe fire warning because of said wind. It's blowing the smoke down from the fires up north. I'm getting a pretty good dose of smoke. I almost forgot there were still burning
If you're not living on the edge, you're taking up to much room.
Offline SWX
« Reply #63 on: October 07, 2018, 09:19:30 PM »
This thread reminds me of how uninteresting the weather is here (outside of storms), we rarely see such large temperature swings, a 30 degree swing would be noteworthy, I couldn’t imagine a 50+ degree swing.
“Only” 80 today, which is warm for October, but hardly a record.
Wunderground / PWS Weather
Ambient Weather WS-2902A
Ambient WeatherBridge
Ecowitt GW1000
Ecowitt WH31
Ecowitt WH41
Ecowitt WH51 x 2
Ecowitt WH57
Ecowitt WS68
« Reply #64 on: October 07, 2018, 09:33:14 PM »
Lot's of snow likely in forecast nothing heavy so put the snow stake out today.
« Reply #65 on: October 08, 2018, 03:58:26 AM »
Here, there has been a flood watch that started early Sunday morning lasting through Tuesday evening.  A cold front going back and forth helps explain the wet situation.  I'm on the warm side as of Monday morning.  Have picked up .77", so far.  Where it's really been getting soaked is well to the south and west of me.
Flood watch in dark green:
Offline WeatherHost
« Reply #66 on: October 08, 2018, 05:26:45 AM »
Yuk.
Changing back to Fall this week though with highs in the 60s forecast for the weekend.
« Reply #67 on: October 08, 2018, 08:08:27 PM »
A radar look at how the rain is training from west OKC to near the Kansas border as of Monday evening. As much as 2 to 3 inches an hour.
« Reply #68 on: October 08, 2018, 08:14:21 PM »
Winter Weather Advisory out.  Little early for some. 4" depth ground temperature still in 40's so will be short lived and just a taste of what's coming.
« Reply #69 on: October 09, 2018, 01:58:40 PM »
So much for fall. Not positive but this may be 1st WS Warning issued anywhere in lower 48 this fall.
Offline Jasiu
    • LexMAWeather
« Reply #70 on: October 09, 2018, 06:34:07 PM »
I know I've seen at least one in MT. Maybe this was it:
https://unofficialnetworks.com/2018/10/02/noaa-winter-storm-warning-for-montana-18-22%e2%80%b3-of-snow-above-6500ft/
Maybe you are first at lower altitude.  :grin:
https://lexmaweather.info
« Reply #71 on: October 09, 2018, 08:46:14 PM »
Missed that one.
« Reply #72 on: October 09, 2018, 11:21:45 PM »
If not straight winds, EF0 and EF1 tornadoes did damage in parts of the OKC metro area on Tuesday morning as pictured below.  When the line arrived here, wind gusted up to 31 mph.  With 2.35" fallen, this rainy period is on its way out now as the cold front passes by and will stay passed this time.
Meanwhile, Tropical Storm Sergio is expected to impact Oklahoma and north Texas weather this weekend.
« Last Edit: October 09, 2018, 11:25:07 PM by Bunty »
« Reply #73 on: October 09, 2018, 11:59:00 PM »
Don't usually see straight line winds put cars on their roof tops.
« Reply #74 on: October 10, 2018, 05:24:59 AM »
Rare for sure but a small car and 100-130 mph downburst can toss them around easily.
