Author Topic: wunderground wordpress help please  (Read 1061 times)
Offline sailingandres
« on: January 04, 2025, 02:29:33 PM »
I have done a lot of basic wordpress stuff, but never shortcodes or anything.
I installed the wunderground plugin, and was hoping everything should just work.
I haven't don a widget, I tried but that doesn't weem to have any settings to alter or tell it which station, so I am equally lost with that. I haven't done any php or anything because I believe the wunderground install does it all doesn't it?
I set the weatherstation up and it feeds into wunderground and shows on the android app fine, but I get a fatal error on the page when I put this in as a shortcode on my website page.
 [wunderground location="IBEDFO167" numdays="5" layout="simple"]
I put the brackets and "" in on the website shortcode, I presume that is correct.
I also tried the word forecast instead of wunderground but the same. the O in BEDFO is an O not a zero, I checked that.
If I can just get something to show I can work from there.
If anyone can tell me what code they are using I can hopefully work from there.
I really need help for the sailing club. Thanks.
Re: wunderground wordpress help please
« Reply #1 on: January 06, 2025, 03:12:26 AM »
They told me it no longer works. I am surpised it is still available as a wordpress plugin.
Offline Ian.
    • Chatteris Weather
« Reply #2 on: January 06, 2025, 07:38:50 AM »
Mine stopped working so I simply linked to my weather stations logo banner using Anole's script downloadable from https://saratoga-weather.org/scripts-legacy.php#anole and put that on my Wordpress blog.
CWOP - DW3371
PWS - ICAMBRID16
https://www.chatteris.biz
« Reply #3 on: January 06, 2025, 09:12:02 AM »
Hi Ian,
on your website you have the current weather observations from your station, which is exactly what I am trying to do.
How did you do that please ?
Regards,
Andrew
Offline Ian.
    • Chatteris Weather
« Reply #4 on: January 07, 2025, 04:55:40 AM »
Hi Andrew,
Do you have the logo script on your site currently, if not, that's the first part as once this is working getting Wordpress to show this straightforward.
Instructions on how to download and install are within the script box, if it helps I can send you my wxgraphic folder so you can see how mine is created, (I use meteobridge rather than weather display but it works ok).
CWOP - DW3371
PWS - ICAMBRID16
« Reply #5 on: January 07, 2025, 05:17:05 AM »
Hi Ian,
I would be grateful for whatever help you can give.
I am not sure what you mean about logo script.
https://priorysc.org.uk/today-at-the-club/ is the site, but I am setting up on my own about page to test first;
https://bespokebritishboxes.co.uk/about-us/
but websites are all just simple wordpress, I haven't played with php or shortcodes or anything.
Any pointers on what I should be doing or learning about would be a great help.
Thanks.
Andrew
Offline Ian.
    • Chatteris Weather
« Reply #6 on: January 07, 2025, 06:22:05 AM »
Ok I have made some assumptions, your existing weather station which sends data to Weather Underground (IBEDFO167), is that using a computer?
If no computer, then the scripts I've been referencing are of no use, however, not as good as your own data, but you could download a weather plugin and use the nearest station available.
CWOP - DW3371
PWS - ICAMBRID16
« Reply #7 on: January 07, 2025, 07:00:24 AM »
Hi Ian,
it is an ACCUR8 station and it sends the data direct to wunderground.
We could just show weather from the location but the club seem to want to see their own data,
but maybe they will have to live with it.
Thanks for your help.
Offline Ian.
    • Chatteris Weather
« Reply #8 on: January 07, 2025, 08:54:56 AM »
You could try sending your date to Weathercloud which is supported by the ACCUR8 and then grab the image to display on a wordpress page.
I used W3 School https://www.w3schools.com/html/tryit.asp?filename=tryhtml_iframe_height_width as example for my site in the picture.
CWOP - DW3371
PWS - ICAMBRID16
