I have had the Apogee TS-100 since November 2024, and I must say that it was a good purchase. At my place I use it as a complement to passive screens, in this case the Barani Ms Pro III. At the price you could buy TS-100 is ok, and I bought in the second half of September 2024. colleagues in Poland also find it a good active shelter to compare with the best passive shields.
I'm not saying Apogee is perfect, but it gives more authoritative data than the Ms Pro III from Barani.
It is rare that the results are questionable. It is more often the Barani shelter that presents inappropriate physical quantities on the same sensors against the TS-100 and Davis FARS24H.
I plan to mount a Smart Cellino for comparison on my mast in the spring. The sensors are ready. Perhaps it will complement the measurements against the Barani Meteoshield Pro III and Apogee TS-100 and Davis FARS24H that I have.
I'm still wondering what to do with the Ms Pro III, because the humidity readings relative to the measurements in the active ones are questionable under different conditions, and this is also seen by colleagues in the country.
Here, for example, a colleague compares passive vs. active shields. He has there, in addition to SHT35, SHT35, PT100 class A and PT1000.:
https://www.ecowitt.net/home/index?id=122831We try not to use ds18b20 in our Polish climate, because it is not very precise in negative temperatures, especially when it comes to WN34D from Ecowitt, where this Dallas and its accuracy and response time is questionable. It's a lower grade sensor than PT100 and PT1000 and SHT35/45.
