Weather Software > My AcuRite smartHUB Software
Use Kevin's SmartHub Reader without bridging network adapters
<< < (2/4) > >>
BeaverMeadow:
I'm thinking to delete and re-enter the new-host entry so I can rename it correctly to Aculink and then set it to static.
Bushman:
And that is why you give it a unique name.  ;)   You will need to disconnect the device (power off), assign a static IP to it and then reattach the device.
Unless of course, checking the box turns the already in use dynamic lease into a static one.  Don't have the manual to tell you for certain.  Try that first I guess.
Bushman:
A quick Google search tells me that the second method will convert a dynamic IP to a static one.  Try it.  Of course it will have a crappy name unless you can rename it.
BeaverMeadow:
I renamed new-host to Aculink and made it static. I ran ncat -e "ncat hubapi.myacurite.com 80" -l 80 -k exactly as written in a command prompt and I get a blinking cursor. I also tried ncat with the aculink ip address but that also just gave me the blinking cursor.
Is the command prompt supposed to just blink? I think there may be some problem with ncat running properly.
I also shut off in myacurite the aculink connection to wu and then looked at the aculink webpage but there were no devices detected.
Bushman:
Does it show up in the Dlink router's IP ADDRESS DISTRIBUTION page (like in your first post)?
[#] Next page
[*] Previous page
