Weather Software > My AcuRite smartHUB Software
Can't get Kevin's SW to work
K9LEG:
Still not working.
WonderWX:
Is the SmartHub successfully posting to MyAcurite when you have it connected to the laptop's Ethernet connection?
If not, bridging may not be working correctly. You could try doing Internet Connection Sharing instead.
If data is getting posted to MyAcurite, then data is getting thru the bridged network but something with kevin's program or its dependencies isn't working properly. You could try running Wireshark to see more details.
DoctorKnow:
You want to select the second network device, the "Realtek PCIe GBE" adapter, then bridge the ethernet to the WiFI.
[*] Previous page
