Author Topic: Weather34 template(non meteobridge versions)  (Read 119330 times)
Offline weather34
Re: HOMEWEATHERSTATION Dashboard template
« Reply #225 on: May 20, 2017, 05:56:17 AM »
cheers brian seems everything ok now love the template how do i stop cumulus uploading the index.htm file so if someone goes to http://dreamhills-2.com/weather it goes to the template and not to the cumulus basic page i know its in the cumulus somewhere
I didn't see your edit , I don't know may be ask over on the cumulus forum , I don't use it so would have no idea but I'm sure they will know here http://sandaysoft.com/forum/index.php
Brian
Offline nitrx
    • Apeldoorn-Oost The Netherlands
« Reply #226 on: May 21, 2017, 04:24:33 AM »
Go to  Settings => Web/FTP settings  and disable all the options and delete the index.htm from your server with a ftp-client.
Ron
Cumulus software
Apeldoorn NL
http://www.apeldoornmeteo.nl
several languages
Offline weather34
« Reply #227 on: May 22, 2017, 05:43:39 AM »
preview of upcoming release  see screenshot below and its basically running at https://weather34.com , may not appear for a few weeks due to ramadan starting here and I kind of disappear for a month but i have been asked many times so here is a solution that allows you to choose either pre configured modules or build your own if you are experienced in web design/code.
simply it will use easyweathersetup.php and you just select from the drop down choice in any of the the 4 positions which one you want show in a particular position. it doesn't get any easier than this
literally as example
position 1 = indoor.php
position 2 = clock.php
position 3 = earthquake.php
position 4 = alerts.php
there will be a selection of small preconfigured modules to choose from and a blank module where you can design your own using whichever code you wish.
this will expand across the whole of the temple in the future. so each module will be swappable for positions , there will be eventually 13 positions to choose and use.
brian
Offline SpringHillWeather
  • Weather Hobbyist
  • Spring Hill, Florida
    • Spring Hill
« Reply #228 on: May 25, 2017, 01:54:19 PM »
Thank you Brian for the latest update with new Design and features!
Dashboard V3.4-X4
http://nyweather.net
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
Offline weather34
« Reply #229 on: May 25, 2017, 01:59:23 PM »
Dashboard V3.4-X4
thanks
just hang in there for a few hours i will upload a updated version with a few fixes,additional things and tidied up some of the new modules , im just clarifying some additional options to work with weather display software . ive fixed the 24/12 our clock option, cleaned up the earthquake module , added some other extra modules . smarter css stripped all the stuff not needed keeps all running nicely.
just watch for the date change on the info page then it will all done as Im away for a few weeks after sunday.
glad you like it .
brian
Offline pimohdaimaoh
  • "Be aware to our nature"
    • PIMOHWEATHER
« Reply #230 on: May 26, 2017, 01:09:57 AM »
I Guess its time to update mine, Thanks in advance brian
-Mike-
  • Weather Hobbyist
    • Spring Hill
« Reply #231 on: May 26, 2017, 03:46:57 PM »
Dashboard V3.4-X4
thanks
glad you like it .
brian
Yes, the new options on the main page are very nice.
I did see the new update and upgraded to that.  Much better now, I see the clock and barometer is fixed.
As a note I have edited the WXCHARTS link from menu (WXCHARTS.php) and added my own links which is nice but I'm not sure if many know they can do this too.
http://nyweather.net/wxcharts.php
Thanks again Brian.
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
    • PIMOHWEATHER
« Reply #232 on: May 27, 2017, 12:41:46 AM »
Dashboard V3.4-X4
thanks
glad you like it .
brian
Thanks again Brian.
Hello,
many knows to add the wxcharts nut I didnt add mine since all my charts are already at the main site of mine, its ok for me not to add the charts at least Brian give it a way to us modify it if we want to link the charts, this time Bravo brian. . . bravo  =D>
Offline Bashy
  • brecklandweather.com/meteo
    • Breckland Weather
« Reply #233 on: June 01, 2017, 02:40:48 AM »
Hi, using the latest version, is it possible to use my own data for the current sky conditions please? i was able to in one of
the early versions, this one but the menu no longer works, so i added the new version here, but i believe its using WU for
the current conditions? thank you.
Kind regards
Bashy
Offline weather34
« Reply #234 on: June 01, 2017, 05:38:02 AM »
hello
can you please send me a copy of your old currentconditions (email) i cant remember what the code was , i do recall doing something a while ago.
if you can send it via email as I am on a limited internet via phone and forum access at times is slow, not a forum problem! my problem.
saturday i have an update to issue so i can add it into that and you can download saturday morning the download date will reflect it has been updated.
https://weather34.com/homeweatherstation/
few changes nothing major just removed some of the translated terms as it is getting tedious having to design around different word length phrases in other languages . see screenshot to see the minor changes .improved earthquake layout minor visual improvements for those who monitor.further weatherflow hardware lightning implementation now records, yearly total for chart display ,daily lightning running totals.
brian
Offline kokos1405
« Reply #235 on: June 01, 2017, 05:42:36 AM »
Hallo Brian.
I have updated to the latest version and I have problem with rain stats only. It shows them like inches.
Could you check it?
https://meteotimb.eu/tablet
Sent from my iPhone using Tapatalk Pro
Offline weather34
« Reply #236 on: June 01, 2017, 05:56:03 AM »
hello
will be fixed for saturday i know what the issue is .
question where are you your coordinates 24.7687 35.070782  greece or egypt ?
i only ask i was on KOS yesterday 36.7938692 26.57619
« Last Edit: June 01, 2017, 05:57:34 AM by weatherist34 »
Offline kokos1405
« Reply #237 on: June 01, 2017, 06:22:13 AM »
It's Greece at South Crete.
Offline Bashy
    • Breckland Weather
« Reply #238 on: June 01, 2017, 12:52:11 PM »
Thanks Brian, i have emailed you, no rush but i will remind you at Xmas should the need arise ;) :D
Kind regards
Bashy
Offline nitrx
« Reply #239 on: June 02, 2017, 11:40:13 AM »
hello
Hi Brian when I chose for Imeperial Units instead Numeric I get a higher firedanger risk , I assume these percentages must be the same ?.. url - http://apeldoornmeteo.nl/pws/index.php?lang=en
Thanks Ron
Ron
Cumulus software
Apeldoorn NL
several languages
Offline weather34
« Reply #240 on: June 02, 2017, 01:33:43 PM »
NEW VERSION 3.4-X4 (FRIDAY 2ND JUNE 2017)
  - FIXED issue with rain charts conversion
  - Fixed firerisk showing more than 100%
  - Added new easyweathersetup option for weather display users to use current weather icon and description the clientraw.txt file
  - New SVG icons for weather display users using the current icon from clientraw.txt
  - Top modules cleaned up layouts and better earthquake layout
  - Trend barometer/temperature values moved and removed translations due to phrases vary in length and create havoc with design layout
  - FULL UPDATE IS REQUIRED DUE TO NEW OPTIONS IN EASYWEATHERSETUP.PHP
brian..
« Last Edit: June 02, 2017, 02:03:03 PM by weatherist34 »
Offline weather34
« Reply #241 on: June 02, 2017, 01:54:35 PM »
hello
Thanks Ron
Sorry Ron
I missed this if you don't mind will have a look at it next week .
Brian
Offline nitrx
« Reply #242 on: June 02, 2017, 01:56:47 PM »
NO problemen Brian I ll update tot the later version first
Ron
Cumulus software
Apeldoorn NL
several languages
Offline dolfs
« Reply #243 on: June 02, 2017, 06:37:34 PM »
Some feedback on the June 2 version, although most of it is more general:
  • In the temp panel, for all except the trend temperature, the degree symbol is immediately to the right of the value, but for the trend there is a space in between.
  • The <div> with class "temptrend" is not centered under the red temp gauge circle. Looks a little odd.
  • The temp trend icon in front of the Temp and Humidity line in the top panel for (i) Indoor is not aligned with the text. It is too low.
  • For all other gauge panels, the circular gauge is in the center, with text to the left and right. For me in this new temp panel, the gauge is off-center to the left, and all text is to the right. Perhaps "Feels" and "Wet Bulb" should be on the left, and Hum/Dew on the right for a more symmetric and pleasing look.
  • For barometer trend you use different up/down icons than for temperature. For barometer they are circles with arrows inside, for temp there are no circles.
  • For the pressure units you line up at the baseline for trend, but not for the current temp, where "inHg" is displayed as a super script to the current pressure.
  • Min/Max pressures are laid out in a little odd way. First of all, Max is in the top-left of the panel, Min is in the bottom right. I think they should be both on the top, or both on one side. You both on top for wind, for example. As I look around more I see something similar happening for Moon Rise/Set and Sun Rise/Set. For these two I think it would make more sense to have them "together", and I would have a personal preference for having on above the other.
  • Due to choice of fonts, when watching the clock "tick" overtime the seconds transitions from/to a value of "1" at the seconds position, the whole time strings shifts left/right. This is somewhat visually disturbing as it happens every 10 seconds.
  • You seem to have generally adopted layout where there is a space between a value and its units, yet for temperature you leave out the space that would otherwise have been (I think) between the degree symbol and the F/C. You also have no space separating the units in "Cloudbase" in the current conditions panel.
  • Moon time and dates are displayed in "bold" yet sun rise/set and daylight values are not.
  • Daylight/darkness values are displayed value on top, label on bottom, but all other examples are the other way around (e.g. moon rise/set).
  • Your recent versions all have had the same label (currently V3.4-X4). I suggest changing the label in each release to avoid confusion.
All of this is meant in a constructive manner; I love your work.
--dolf
Ambient WS-1400-IP + MeteoBridge
Offline Bashy
    • Breckland Weather
« Reply #244 on: June 03, 2017, 01:34:48 AM »
brian..
Own current conditions are working great, thank you ever so much Brian :)
I should also add that in mobile mode, its fantastic
« Last Edit: June 03, 2017, 01:55:04 AM by Bashy »
Kind regards
Bashy
Offline weather34
« Reply #245 on: June 03, 2017, 05:51:38 AM »
NEW VERSION 3.4-X4 (SATURDAY 3RD JUNE 2017)
  - Purely a beta file added for weather display clientrawextra.txt users, this file currentconditionswd.php includes weather forecast description read from clientrawextra.txt. to use rename currentconditionswd.php to currentconditions.php
  - Weather Display users only Added minor fix to remove underscore and / from clientraw.txt weather description
for Dolf i will look at some of the ideas in due course however !
« Last Edit: June 03, 2017, 06:01:21 AM by weatherist34 »
Offline Bashy
    • Breckland Weather
« Reply #246 on: June 03, 2017, 06:37:18 AM »
I will have a look at that once the sun has gone in, thanks Brian
Kind regards
Bashy
Offline Bashy
    • Breckland Weather
« Reply #247 on: June 03, 2017, 01:30:50 PM »
Hi Brian, adapted you wee beta and the Sunny/Dry change, working great as seen here, i made a slight change to the wording above the
station forecast as that reflects it more, thanks again :)
Kind regards
Bashy
Offline weather34
« Reply #248 on: June 03, 2017, 02:37:02 PM »
ok no problem ive added on your description , i wasn't sure what length of time it was covering , also added the option to select the optional file within the easysetup , reduces the error chance .
download was updated also with some additional weather display clientraw weather icons .
Offline Bashy
    • Breckland Weather
« Reply #249 on: June 03, 2017, 02:38:15 PM »
Thanks Brian, I will grab that in the morning :)
PS, what's the best way to upgrade?
« Last Edit: June 03, 2017, 02:42:16 PM by Bashy »
Kind regards
Bashy
