Author Topic: Close the freezer door!  (Read 818 times)
Offline Notsorusty
« on: August 19, 2019, 09:24:10 PM »
Tell Marge to close the freezer door!!!
Refreshing the page did fix this.
« Last Edit: August 19, 2019, 09:25:47 PM by Notsorusty »
Station Name: Silver Creek II
Latitude / Longitude: 41.925° N, -87.872° W
Elevation: 633
City: Franklin Park
State: IL
Hardware: Ambient Weather WS-2902D
Offline WSWeather
Re: Close the freezer door!
« Reply #1 on: August 19, 2019, 10:39:41 PM »
Heh...reminds me of this blast from the past...
Offline GreyOwl
  • Station up and running, No RH or Pressure sensors
« Reply #2 on: August 20, 2019, 08:25:17 PM »
That's not bad, check out my dew point!
https://www.wunderground.com/dashboard/pws/KNVNORTH32
CWOP: CW8399
KNVNORTH32
Weather Wizard III, wired
Homebuilt DFARS
Weather Link 5.9.0, serial version
Logitech 9000PRO Webcam
Offline awsum140
« Reply #3 on: August 20, 2019, 08:32:17 PM »
Tell me how you have 255% humidity without being 1000 feet below sea level in the ocean?  Talk about messed up math!  Must be the "new math".   ](*,)
On the plus side there's no solar radiation and the UV index is at zero, despite the blazing sun showing on your webcam and a temperature of 104F.  Whatever it is, I hope it stays in Vegas, no offense  \:D/
« Last Edit: August 20, 2019, 08:35:27 PM by awsum140 »
If it's not a Boerboel it's just a dog.
Offline GreyOwl
« Reply #4 on: August 20, 2019, 09:05:42 PM »
That is totally on WU! I have no sensors for RH and Pressure. The data comes from somewhere but not from my station!
The current humidity level is at 6% so the 104 is bearable. We used to live in SW Kansas and the summers were the same temp but 20-40% humidity which we just couldn't handle any more.
Check the comments tab on the link above for more info.
« Last Edit: August 20, 2019, 09:07:19 PM by GreyOwl »
CWOP: CW8399
KNVNORTH32
Homebuilt DFARS
Offline WSWeather
« Reply #5 on: August 20, 2019, 09:18:40 PM »
At "-32,768" something rolled over in the WU "new math".
Can we get some programmers over here, please?  :roll:
Offline awsum140
« Reply #6 on: August 21, 2019, 07:02:05 AM »
Kind of obvious they left off the program module to check for bogus, nonsensical, results in their calculations section.  Yet another new "feature" of the new WU.
