Author Topic: Meteobridge Pro Change Units on Live Data Tab  (Read 303 times)
Offline Robbie936
« on: May 08, 2020, 08:16:22 PM »
I understand this is not the official Meteobridge Forum but I'm not getting any answers in that forum.....
My meteobridge graphs tab shows the wind speed in km/h which is my preferred units. On the Live Data tab is is shown as metres/s. I would like to change the units on the live tab to km/h and from the wiki i understand i need to use the "convertor" kmh but I'm a bit lost where and how to do this.
Any assistance would be greatly appreciated.
Thank you
Rob
Re: Meteobridge Pro Change Units on Live Data Tab
« Reply #1 on: May 08, 2020, 09:52:37 PM »
Which Meteobridge?  My standard MB does not have graphs.
« Reply #2 on: May 08, 2020, 10:22:56 PM »
The Live Data tab units can not be changed. It displays both metric and imperial units. But as you have noticed for metric it displays m/s instead of km/h. The Converter that you mentioned from the Wiki deals with sending data from the Meteobridge in the format that you want. The Converter is not just used for sending data though as it can also be used to build rules and alerts in the units that you prefer. If you want a live view in the units that you prefer then I suggest viewing your data elsewhere than the Live Data tab...and there are numerous places to do that like setting up your own website template. There is even the weather34 template that can run inside of your Meteobridge Pro and that would accomplish what you want.
https://weather34.com/homeweatherstation/index.html
And there are also other templates if you don't like the weather34.
« Last Edit: May 09, 2020, 04:19:43 PM by galfert »
Offline Robbie936
« Reply #3 on: May 09, 2020, 02:25:24 PM »
Thank you galfert, i shall look at weather34.
