Author Topic: Can someone help me create a website for my Davis station?  (Read 1369 times)
« on: February 19, 2024, 11:35:12 AM »
Hi guys, i have always wanted to have my data online with graphs and stuff like my own website page just for my Davis vantage pro 2. I am currently running it with My meteobridge but I have 0 skills when it comes to putting a nice site together.
Any help will be greatly appreciated.
Re: Can someone help me create a website for my Davis station?
« Reply #1 on: February 19, 2024, 12:08:44 PM »
For meteobridge, you can have a couple of choices of pre-packaged website templates:
PWSdashboard https://pwsdashboard.com/
Saratoga https://saratoga-weather.org/wxtemplates/
both use hosting packages including PHP (V7 or V8).
Also the native Meteobridge template set from weather34 at https://download.meteobridge.com/files/Weather34.zip
However, the original documentation for setting that up on weather34.com seems to have disappeared last year.  It's possible
that Brian has stopped supporting his homeweatherstation dashboard set, so beware of using that.
Hope this helps...
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #2 on: February 19, 2024, 01:04:01 PM »
.....It's possible
Hope this helps...
Even this seems out of date.
https://github.com/lightmaster/Meteobridge-Weather34-Template
"William will be maintaining on behalf of Brian Underdown .Brian no longer wishes to contribute and does not want to stifle progress . Please use the support available via the Github issues function or via email support@baxleyweather.com"
« Reply #3 on: February 19, 2024, 01:17:03 PM »
Yes, it's out of date, as is my own GitHub for the Cumulus version.  I think the better alternatives are the two I mentoned first.. Both Wim and I continue to support those instances.
« Reply #4 on: February 19, 2024, 02:40:40 PM »
Hi guys! thanks for the reply! So can someone help me put this together? I have a few sites i saw online as to what i would like for it to look like if its possible.
I love how these graphs looks or might not this be able to be done with my setup using meteobridge.
https://lovingtonweather.com/graphs/
I created this banner on google sites but there options seem limited.
« Last Edit: February 19, 2024, 02:47:24 PM by Adrian23 »
« Reply #5 on: February 19, 2024, 03:38:26 PM »
You'll not be able to use Google Sites for your station.. AFAIK they don't support FTP/SFTP/FTPS uploads of content required by meteobridge, and current meteobridge may not support SFTP/FTPS due to an old library in the meteobridge software itself.  Boris would have to recompile to update that library.
You'll need a personal website from a hoster (Ionos, GoDaddy, etc) to use the templates I cited.
« Reply #6 on: February 19, 2024, 06:46:44 PM »
Hi guys, not much building skills so this is work in progress! Suggestions welcomed
https://sites.google.com/view/adriansweatherstationpage?usp=sharing
« Reply #7 on: February 20, 2024, 03:40:56 PM »
I think you did a very good job.
The radar guy in me though says get some software and customize it to your area. Same with the satellite data. COD is a great site but I would try to get away from using another weather site for the data.
But that's just me.
Otherwise you did fantastic for your first crack at it. [tup]
« Reply #8 on: February 20, 2024, 04:56:26 PM »
But that's just me.
I would love get a better site but sadly I don’t know how to set it up. I use a meteobridge with my Davis. I would probably pay someone to help me set up a nice looking site with customizable graphs etc. 🤷🏻‍♂️🙏🏻
« Last Edit: February 20, 2024, 04:59:45 PM by Adrian23 »
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #9 on: February 20, 2024, 05:08:44 PM »
Brian does frequent the meteobridge forums here:
https://forum.meteohub.de/viewtopic.php?t=16253
and is still doing some work occasionally on templates
Regards Simon
« Reply #11 on: February 20, 2024, 10:16:36 PM »
But that's just me.
Anyone willing to assist with putting a site together for my  station? Appreciate the comments but I have 0 knowledge with scripts and configuring a site.
« Last Edit: February 21, 2024, 09:27:32 AM by Adrian23 »
« Reply #12 on: February 20, 2024, 10:17:07 PM »
Looks good. Keep going.
I did notice a typo in the menu on the left:
Should "Lighting" read " Lightning" ?
Hi, thanks fíxed!
Offline weather34
« Reply #13 on: February 22, 2024, 01:08:10 AM »
Hope this helps...
Hello Ken and all , thanks graham for highlighting this..
Im alive and kicking albeit less time doing website stuff . the template is  updated when required and once a year gets a full makeover with a new layout option and other implemented ideas suggested by end users . Generally updates coincide with PHP revision releases though these are just small updates. tends to go very quiet during my warmer months(Istanbul 6-7 months without a drop of rain  :-( ) with a burst of activity as winter kicks in( currently we get about 2 months of winter  :shock:)  .
The current Weather34 Aurora MKII version supports 10 layouts (all selectable on the fly and a apple watch layout ).
is compliant  with PHP 8.3.xxx revisions which are installed locally on an old mac 2010 mini converted to a server .
I used to use XAMPP but often the requirement of PHP revisions updates lagged way behind so I now just install a compiled PHP release direct not a user  friendly method but necessary to keep ahead.. https://www.php.net/downloads.php
The template only supports Meteobridge there is no compatibility with Cumulus or other computer type of software.
all support and updates come via https://forum.meteohub.de/viewtopic.php?t=16253 where you can download the master or follow the simple updates .
Support is there but somewhat limited 99% of issues raised get resolved within a few days (this is mostly time differences as I only allocate a short time which is mostly 6am in the morning whilst I have my pint of coffee ! ) , I also often take time to respond which is mostly digesting the issue or request and respond with a proper answer.
so there we are alive and kicking albeit limited .
so examples of current revision use the menu to have a look at the various layouts there is something that generally suits .
https://whaleybridge-weather.com/weather34-2024-layout-3.php
https://singaporeweather.info/weather34-2024-layout-3.php
have a good day ...brian
« Last Edit: February 22, 2024, 01:23:54 AM by weather34 »
« Reply #14 on: February 22, 2024, 11:25:59 AM »
Hope this helps...
Hi Brian, i love this Template! I sent you a PM.
Offline weather34
« Reply #15 on: February 22, 2024, 12:38:14 PM »
good evening got your message i will give you a positive response over the weekend ..in short no problem we can set it up and it really is a install and forget just let it run 24/7  and no need to offer money its a free template only cost is your time giving me some basic info  ..
have a nice day ..brian
« Reply #16 on: February 22, 2024, 12:56:29 PM »
Hi Brian, That's Fantastic!! I just sent you another PM with my personal info. Thanks so much for doing this looking forward to seeing my data!
« Last Edit: February 22, 2024, 02:52:26 PM by Adrian23 »
« Reply #17 on: February 23, 2024, 04:10:18 PM »
Hi Brian, i have already bought my domain and hosting service sent you a pm. Thanks so much again!
Offline gateway2capecod
    • West Wareham, Ma Weather
« Reply #18 on: February 23, 2024, 05:08:22 PM »
hello Adrian....
I got your email message but looks like you are doing ok on your own with some excellent help from other's in the forum here.
just want to know who did you go with for your hosting and Domain?
OK  Have a Great Day and dont be afraid to learn.
...Chris   www.gateway2capecod.net
« Reply #19 on: February 23, 2024, 05:17:04 PM »
hello Adrian....
Hi Chris, thanks for your comment! went with ICDSoft they seem very reliable also great customer service.
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #20 on: February 24, 2024, 02:16:38 AM »
They were very patient and helpful to get some details right when I was setting up.
« Reply #21 on: February 28, 2024, 11:51:50 AM »
Question for you guys being in South Florida we often have tornadoes, severe weather and hurricanes will the weather34 template show these alerts? I notice there are alerts being displayed on the top right corner.
« Reply #22 on: April 18, 2024, 08:50:52 PM »
Hi guys still looking for someone interested in helping me create a website for my VP2 using Ken’s template. I can provide info to my host or whatever is needed. Please reach out to me if interested. Would greatly appreciate it.
« Last Edit: April 18, 2024, 09:03:26 PM by Adrian23 »
