Author Topic: Ftp Issues with ImageSalsa  (Read 4708 times)
Offline PSJohn
    • DesertWeather.com
« on: September 19, 2008, 03:17:38 AM »
I'm receiving a 500 error and can't figure out how to get around it. I have tried portforwarding port 21 and can't get it to work.
Any ideas?
I've attached a screen shot below.
John Slama
Palm Springs, California
Davis Vantage Pro 2, FARS
Offline DataCrunchTech
  • Data Crunch Technologies
  • Moderator
  • Developer of ImageSalsa and MovieSalsa
    • ImageSalsa Web Cam Software
Re: Ftp Issues with ImageSalsa
« Reply #1 on: September 19, 2008, 10:43:50 PM »
If you go to a command prompt: Start/Run/Cmd.exe and run ftp.exe, does it work OK?  That will help explain if it is a port issue.
If you haven't used ftp.exe before, you will need to run:
cd -- to change to a directory where a test image resides (i.e. if you have an image in c:\program files\imagesalsa\images, type 'cd "c:\program files\imagesalsa\images" ') -- no single quotes, just the double quotes since there is a space in program files
ftp www.desertweather.com
[your username]
[your password]
cd -- to change to a directory (i.e. 'cd html' or 'cd images')
ls -- to list the directory contents
put localfilename -- to put a file named localfilename to the current directory on the server
bye -- to exit
Jason
support@datacrunchtech.com
www.imagesalsa.com
Home of ImageSalsa and MovieSalsa
Offline PSJohn
    • DesertWeather.com
« Reply #2 on: September 20, 2008, 06:19:48 PM »
Didn't work, got the same error: "I won't open a connection to 192.168.1.101 (only to  66.74.54.148)
I have disabled my software firewall. Tried port forwarding port 21 in my router (but doesn't passive FTP randomize ports? I tried unchecking passive anyways and it still didn't work)
Any other ideas?
John Slama
Offline EKB
  • If a million people belive a stupid thing.......
    • ReynoldsWX
« Reply #3 on: September 20, 2008, 06:46:37 PM »
How about a few more details.  Describe what you are trying to do.
Where is your ImageSalsa machine relative to your ftp server?  Same network or on a remote network?
If you have tried to use command-line ftp to connect from your ImageSalsa machine to your ftp server, and it did not work, then you are probably not looking at a problem with ImageSalsa.
EKB
KGAREY01, CW2647, Davis VPII Plus, Boltek Storm Tracker, Astrogenic Nextstorm, StrikeStar Network,
Assorted Weather Cameras, 1 wife, 3 kids, no dogs, lots of Cats....
Offline PSJohn
    • DesertWeather.com
« Reply #4 on: September 20, 2008, 11:11:52 PM »
ImageSalsa is on my local machine behind a router and I'm trying to FTP to my webhost. I'm trying to use Imagesalsa's FTP Push feature to upload an image.
After the help by DataCruchTech I do realize that this is not ImageSalsa's fault.
John Slama
