Author Topic: Java Problem  (Read 2772 times)
Java Problem
« on: September 12, 2006, 03:43:07 PM »
Anytime I access a web page (including my own) that uses Java my pc takes forever to open it up.  Even when it does open up it very slow and clunky. I have plenty of memory, 1024MB and a 1gig proc.  Also have a 128MB video card. I can use MS Virtual Machine fine as long as I use IE but I would rather use Firefox. Can't seem to find any help on Sun's page. Most help is  for developers. Anyone have any idea's?
Offline ncpilot
    • Monkey Junction Weather
Java Problem
« Reply #1 on: September 12, 2006, 04:16:08 PM »
I was having that problem on my work computer--I just hate it when I try to surf the web at work and it's slow!!  :lol:
So... what seemed to help, and it may be totally irrelevant, I deleted all temporary files at:
c:\documents and settings\"my user id"\local settings\temporary internet files\content.IE5\...
then there are 4 folders on my machine, and I deleted all the files in those folders.
Perked my machine right up...
Marc
Wilmington, NC
"Monkey Junction Weather"
Davis VP2 wireless, WeatherLink
Offline talbert1952
    • http://tobaccovilleweather.com
Java Problem
« Reply #2 on: September 12, 2006, 05:37:14 PM »
If you haven't done it already you should go to java.com and get the latest version of the jre. There is a bug in earlier versions that can cause slow performance, system hangs and other problems. I haven't had any java problems with IE or Firefox since I upgraded.
Tom
W4SNA
IRLP 4069 - Echolink W4SNA-R
http://tobaccovilleweather.com/
Hardware: Davis 6153 wireless VP2 with 24 hr fan aspirated radiation shield, WMR968, Boltek Stormtracker PCI,
  Hamtronics R139, stacked Woodhouse 6X6 beams on Yaesu G-5500 az/el rotator
Software: Weatherlink, VWS, Image Salsa, Lightning/2000, GRLevel3 with Allison House data feed, WxtoImg
Java Problem
« Reply #3 on: September 13, 2006, 01:30:29 PM »
Tom I checked but I have the latest version. Even tried some of what  pilot said but no help:(
Offline talbert1952
Java Problem
« Reply #4 on: September 14, 2006, 06:58:02 PM »
By default JRE starts the Java console at startup which really slows things down. Poke around in the Java Control Panel for an option that says "Do not start console". If it isn't selected, select it. You can always change it back later.
You might also want to go to http://java.sun.com/javase/downloads/ea.jsp and get Java SE 6 Beta 2 JRE. I have been running it for a while with no problems. It seems to be a bit faster than Java 5. Don't forget to turn off the console.
Tom
W4SNA
