I have a weather station on the roof of a condo building in Punta Mita MX. Here is the data on Weather Underground
https://www.wunderground.com/dashboard/pws/IVALLE160I installed it new in March 2022. So its been up there for a little over a year. I am normally in California and today I looked at the data for the first time in a while and it seems to be going off at or near 5AM everyday now and comes back sometime in the morning, often not until close to Noon.
My first thought was it needs new CR123A battery but I called Davis and they said those batteries should last longer than 1 year. The battery being bad does seem to fit the pattern but I am wondering why it takes so long to come back online once the sun is up.
The station is on the roof of Building 1 and connects wirelessly to the console which is located in the main office which is directly across from Building 1. There is good line-of-sight from the roof of the condo building down to the office building. The setup has worked fine except when power goes off because the we lose wifi. The data is uploaded with wifilogger. Below is a plot of the data from April. It was working fine until about April 23. I will be going down there in a about a week so I can trouble shoot further but I thought in the meantime, I would post this and see what others think. It's not WU because I also have the data going to Weather Cloud and PWS Weather. The console uses the wifi in the main office so there is no reason why that would go off at every day at 5AM. If they were turning off their wifi, they'd do that when they go home at 5PM. Any other ideas? When I am down there, I can see if the data is getting to the console in the early morning. If not, that pretty much indicates an ISS power problem. I am taking new batteries down but wondering what others here think.
