Author Topic: Conection to allow weatherlink.com updates fail  (Read 624 times)
Offline Eguraldia
« on: August 09, 2021, 12:31:19 PM »
Hello everybody...
Since this morning.David Vantage pro IP data logger..I cant update the bulletin of weatherlink by meteobridge.
Settings WL upload every 1 minuteEverything else  in meteobrigde working fine
I just try with with the software weatherdisplay to see if the problem is the TPlink(mr3020)and working fine
Somebody else have the same issue? :-(
« Last Edit: August 09, 2021, 06:45:16 PM by Eguraldia »
Davis Vantage Pro2 Plus 6163 (Wireless)
Meteobridge
Offline Eguraldia
Re: Conection to allow weatherlink.com updates fail
« Reply #1 on: August 09, 2021, 02:26:32 PM »
I just try again with meteobrigde and nothing change ](*,)
Weather station
Primary station
Connection TPC/IP
IP..data logger
SETTINGS WL UPLOAD(1 MINUTE)....I try change to 5 or 10 mins with the same result.....
Only Update(Just one time)If I click "SAVE"
Data logger will restart now, caused by configuration changes....
but after than..Nothing :sad:
« Last Edit: August 09, 2021, 06:49:29 PM by Eguraldia »
Meteobridge
Offline Mattk
« Reply #2 on: August 09, 2021, 05:14:07 PM »
If this was working, what else has been changed? Is this following a firmware update? If firmware update have you tried rolling back the firmware prior to any recent update which might confirm if the latest firmware is the issue?
Offline Eguraldia
« Reply #3 on: August 09, 2021, 06:28:57 PM »
Hi
With weatherdisplay I can release conection every  minute to allow weatherlink.com updates.But not working when I try do the same with meteobrigde.More than 2 years since I start to use meteobrigde in this way without problems...till yesterday
I've been using the last hours only weatherdisplay....
I hope you can understand #-o This is nothing about firmware update :roll:
Are you talking about the  firmware update by meteobridge-tl-mr3020-v1.5.bin?
please find attached  some pcs....
« Last Edit: August 09, 2021, 06:45:43 PM by Eguraldia »
Meteobridge
Offline Mattk
« Reply #4 on: August 09, 2021, 09:45:28 PM »
On the [System] tab what is the SW Version?
Offline Eguraldia
« Reply #5 on: August 10, 2021, 01:55:35 AM »
You talk about this??Not sure
To have your Meteobridge running the latest SW release, just do a reboot or power-cycle.
If the answer is yes,the last one
Version 5.2
released August 9, 2021:
Meteobridge
Offline Eguraldia
« Reply #6 on: August 10, 2021, 03:47:13 AM »
I went to meteobrigde forum and I found some else have the same issue
Somebody just post
Go to tab System => Administration
Click on the drop-down next to Version Control:
Select an older version of the meteobridge firmware
Click on Save and Apply at the bottom, then on reboot.
This will reload a previous version without this problem.
Now is working =D>
Meteobridge
Offline Mattk
« Reply #7 on: August 10, 2021, 05:47:43 AM »
As suspected this was a firmware update issue as there appeared to be similar issues with this latest firmware for the same reason.
Next question is, are you updating the firmware manually or being uploaded automatically following a reboot? From the above responses one would expect auto update is active? My recommendation is to fix the firmware version and only update if and as required. This tends to eliminate issues such as this as if it's not broken then there's no need to fix anything.
« Last Edit: August 10, 2021, 05:49:16 AM by Mattk »
Offline Eguraldia
« Reply #8 on: August 10, 2021, 05:55:07 AM »
Uploaded automatically following a reboot?Ye,just a reboot to have my Meteobridge running the latest SW release?Only I do that
Sorry but no much idea about... updating the firmware manually?,not sure about how to do that and if the auto update is active :roll:
For now version 5.1 (July 11, 2021)hopefully this issue will be fixed in a future update
« Last Edit: August 10, 2021, 06:14:08 AM by Eguraldia »
Meteobridge
Offline docbee
  • Moderator
    • smartbedded
« Reply #9 on: August 15, 2021, 08:25:04 AM »
Should be solved with just released update.
