Weather Software => Cumulus => Topic started by: jeffgod on April 29, 2012, 02:49:57 PM
Title: Rainfall total incorrect
Post by: jeffgod on April 29, 2012, 02:49:57 PM
My computer did a restart and now rainfall total has added 0.49" to the total, which is incorrect. I know I have seen how to fix this problem somewhere on here. I tried to do a search for the answer but I came away with nothing. Any ideas?
Title: Re: Rainfall total incorrect
Post by: neondesert on April 29, 2012, 03:15:26 PM
If the total was added today you should be able to use the rain today editor.
Click on Edit then Today's rain to open.
If it happened on another day, then edit the total in dayfile.txt.  You can use
the built in editor for this as well.  Click on Edit then Dayfile.txt.
Also, if you have an incorrect "yesterday" rainfall amount you will need to fix
this manually in today.ini located in the data directory.  Make sure you stop Cumulus if you need to do this.
Hope this helps.
Post by: jeffgod on April 29, 2012, 03:20:31 PM
Yes, this does help, neon desert, thank you. I will have to wait until it stops raining.
Post by: jeffgod on April 29, 2012, 03:42:27 PM
I have got it all corrected, neon desert, thank you once again.
