....well I wanted to give you all an update (yeah it's me again). Yesterday I thought my 2810 (2) had met its match. The anny was down for the count and not coming back after repeated resets, factory resets, etc. While on life support I decided to go back to ground zero and bring all the sensors back in the house and basically start over. Removed all batteries, waited 10-15 minutes and tried again. This time everything came back on line including the anny. I then proceeded to move all the sensors back to where they were. All was fine, and then the anny started to feel ill. After about an hour the anny shut down. After giving it some thought I decided to move the thermo sensor closer to the anny. The anny is at one end of my yard up about 10-11' above the ground (mast/fence). As soon as I positioned the thermo within about 10-15' of the anny (left rain gauge on deck railing) the whole system came back. I like where the anny is located and do have the flexibility of moving the thermo around. So this is starting to sound more like a close in reception problem. It's now been 24 hours (16 days from original install) and the icons are as strong as I've ever seen them. No drop outs.
Still not 100% sure the anny doesn't have the infamous water leak, but as is well. I'll keep an eye on it. As soon as we get a 'mild' above 40f weekend, I'll tweak/position the weather shelter I have the thermo resting in. I did notice the rain gauge is off, but after what I've been through that problem can wait for another day. Did like what DanS did with his rain gauge mod. Just need to figure out if that's something I can do.
FYI....if any of you are thinking about returning your 2810 to Lacrosse for repair,…don’t. I called last night about my anny problem and they told me they are out of parts and not to send it to them (I pay) until the end of Feb. Parts are due early March. Yikes….mine will go back to Costco before I get in that line.
That’s all for now. Hope your WS-2810 is well.
