Author Topic: Paging Carterlake, Paging Carterlake.......  (Read 3856 times)
Offline WeatherHost
« on: May 12, 2007, 04:02:18 PM »
Two questions on your Severe Weather Alert script.
Could it be configured to play a .wav file when alerts are detected?  A different .wav file for each level of alert?
Can it be run locally on a PC or server rather than on a website?
Offline carterlake
    • CarterLake.org
Re: Paging Carterlake, Paging Carterlake.......
« Reply #1 on: May 12, 2007, 06:32:40 PM »
Oops... I wasn't logged in... so I wasn't seeing new posts...
You can program it to display any HTML you like... like HTML which plays a wav file. Yes.
The script is in PHP... so it behaves like PHP (server based, executed when the page loads).
I think what you're looking for is either a NOAA weather radio (mine works great!) or Interwarn.
Personally, I'd go with the radio.
Davis VP2 6153; Weather Display (LIVE w/ Ajax); Quickcam for Notebooks Pro; Boltek w/ Nexstorm; GRLevel3; live NOAA Radio
Offline kray1000
  • Purveyor of wry
« Reply #2 on: May 12, 2007, 07:50:19 PM »
Quote from: "WeatherHost"
I do something similar.  If the output for the script is a warning, I play my Weather Underground NOAA weather stream.
Something like...
if ($warning == '1') {
  $playradio = '1';
... you would then just need to add code to play the stream (like the embed tag in html)
Offline WeatherHost
« Reply #3 on: May 13, 2007, 12:37:44 AM »
Nope.  Got one of those also, but reception is flaky and warnings are sometimes delayed somewhat behind web based warnings.
Something like...
I don't know diddly 'bout no scriptin', so how would that look for a .wav file?  And do I need to run some local version of PHP?
