Author Topic: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test  (Read 48706 times)
Offline Gyvate
Re: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test
« Reply #500 on: May 02, 2022, 05:48:40 PM »
I think this table could be added to the 'must read post' ( for example you could add a column to par.9 table )
done - it became a new, more verbose table  ;)
Offline giusCB
  • www.turismometeo.it
« Reply #501 on: May 03, 2022, 04:37:42 AM »
rain event with 20.2mm-h RR
witt 1.6 (stock gain settings)
vp2 1.2
man. 1
rain expected in next coming days, i'll try new gain setting ...
yesterday's tot. rain (RR max 28mm-h)
witt 17.4mm (gain at 0.9, 0.85, 0.8, 0.75, 0.7)
vp2 14.0mm
man 15mm
i'll try with lower "gain" setting
www.turismometeo.it
Offline giusCB
« Reply #502 on: May 03, 2022, 07:24:58 AM »
This is how the radiation shield perform after someone decided to turn off the algorithm of radiation compensation
And this is a comparison with a vp2 who has one of the worst shield, i can imagine with a professional one like Barani ...  :lol: :lol:
www.turismometeo.it
Offline giusCB
« Reply #503 on: May 03, 2022, 01:12:02 PM »
rain event today (RR max 13mm-h)
witt 1.0mm (gain 0,7-0,7-0,65-0,6-0,6)
VP2 1.2mm
Man 1mm
www.turismometeo.it
Offline giusCB
« Reply #504 on: May 06, 2022, 04:20:58 AM »
VP2 1.2mm
Man 1mm
another event (max 2mm-h)
witt 2.6mm (gain 0,7-0,7-0,65-0,6-0,6)
VP2 1.6
Man 1.5
this rain gauge is impossible to understand...  ](*,)
www.turismometeo.it
Offline mauro63
« Reply #505 on: May 07, 2022, 08:36:25 AM »
The decision to eliminate from the firmware the temperature correction based not on solar radiation but on the calculation of the energy balance was taken after careful considerations and its basis of disappointing results by an algorithm which, due to the complexity of the data to be processed, has not shown to perform the task adequately.
It was therefore decided, and I admit that I am the author, to remove this function, whoever wants an approximate datum keeps the station as it is, and whoever wants an accurate datum will install a wh32 inserted in a quality solar radiation shield, this for the moment.
EDIT
I forgot to add that we are working on alternative solutions that allow us to improve and reduce radiative errors, keeping the data clean and free from software corrections.
M.
« Last Edit: May 07, 2022, 08:51:28 AM by mauro63 »
Offline tweatherman
« Reply #506 on: May 07, 2022, 12:26:53 PM »
VP2 1.2mm
Man 1mm
VP2 1.6
Man 1.5
I thought the latest firmware for WS90 took care of rain and wind gust issues? I never heard back on the temperature after the radiation adjustment.
tweatherman
Offline tweatherman
« Reply #507 on: May 07, 2022, 12:35:14 PM »
EDIT
M.
I’m very pleased with my raw temperature data running v1.0.9 on WS90. The other data fields like rain and wind gusts are little to be discredited.
tweatherman
Offline Aircub
    • Twinfirs Broadstone
« Reply #508 on: May 07, 2022, 12:51:27 PM »
How can I tell what firmware my Wittboy is on.
I can only find GW2000A_V2.1.4
Offline olicat
    • FOSHKplugin
« Reply #509 on: May 07, 2022, 12:58:52 PM »
Hi!
The existing firmware version can be checked via EAR (provided the GW2000 firmware is v2.1.4). An update is then suggested there if necessary.
Oliver
Offline wsNoordbergum
    • wsNoordbergum
« Reply #510 on: May 07, 2022, 02:02:41 PM »
I have version ws90_ver 117
Temperature is pretty much inline with my Davis maybe a bit lower
Wind is slightly higher readings especially gusts but hey no cups on the WS90
Humidity differs 6%
Rain gain is to be determined, not much rain lately
Today 1 mm on Davis and 1.7 on WS90 with no gain set
Rate was 9.6 mm/h I set gain now to 0.7 for the rain rate below 10mm/h
Below 4 mm/h I set it to 0.8
Rain rate on my Davis was 30.6 mm/h maximum
So the rain rate maximum on the WS90 was much lower!
Now wait until next rain event
WS 90 installed on a temporary location, after I'm satisfied with the performance it will be on a permanent location
I also compare data of my Davis with the Ecowitt with my meteobridge Nano SD it is easy to define graphs and display them
« Last Edit: May 07, 2022, 02:05:01 PM by wsNoordbergum »
Davis Vantage Pro 2 UV/Solar
Meteobridge nano SD
Ecowitt WS90 WH40 WH31 WH57 GW2000 HP2550_c
CumulusMX/raspberry Pi 4b
Offline tweatherman
« Reply #511 on: May 07, 2022, 05:41:07 PM »
Humidity differs 6%
Humidity lower than the Davis?
tweatherman
Offline lantana
    • Kilcunda PWS
« Reply #512 on: May 08, 2022, 08:33:51 AM »
I can understand a gain like 1.0 or 0.7, but what does 7-0 or 65-0 mean?
Offline Gyvate
« Reply #513 on: May 08, 2022, 08:51:08 AM »
you have to understand that the poster lives in Europe where (beyond Malta, UK, and Ireland) the decimal point is comma  :idea:
what he meant to say is (out of the 5 different gain settings):
gain 1: 0.7
gain  2: 0.7
gain 3: 0.65
gain 4: 0.6
gain 5: 0.6
or short 0.7 - 0.7 - 0.65 - 0.6 - 0.6 (replacing the comma by a point  8-))
    • wsNoordbergum
« Reply #514 on: May 08, 2022, 01:26:39 PM »
Yes , but changed it now back to 0 because the difference has decreased
My Davis is now at 65% and Ecowitt 70 with the calibration of +6%
See if it is accurate now
Meteobridge nano SD
Offline Gyvate
« Reply #515 on: May 10, 2022, 11:58:35 AM »
by the way - the power supply cable of the WS90 can be put inside the pole (provided you use a hollow one).
E.g. in order to protect against solar radiation.
Don't forget the cap nut (on the picture it is still inside the pole)  8-)
« Last Edit: May 10, 2022, 12:07:55 PM by Gyvate »
Offline waiukuweather
« Reply #516 on: May 10, 2022, 03:10:59 PM »
does that snow melt heater increase the outdoor temperature reading in the station itself when in use?
Offline Gyvate
« Reply #517 on: May 10, 2022, 03:20:36 PM »
couldn't test it yet with the WS90 - the WS80 creates some ups and downs - there is a thread about this https://www.wxforum.net/index.php?topic=40977.50
- and with the WS90 the power supply is for the whole outdoor sensor, not only for the heater. For the WS80 it is heater for the ultrasonic element only
Offline giusCB
« Reply #518 on: May 12, 2022, 10:21:34 AM »
last event RR Max 79mm-h
man 7.5mm
witt  7.4mm
vp2  7.8mm
all gain set to 0.55
please, try this settings and let us know if it work (valid for kickstarter units only)  [tup]
www.turismometeo.it
    • wsNoordbergum
« Reply #519 on: May 12, 2022, 11:31:17 AM »
Yesterday some rain, 4mm on the Davis
Had the gain set to 0.6 (all) and rainrate was approximately 4mm/h
Ended up with 3.2 on the ecowitt
Now set gains to 0.68 see what this does
Meteobridge nano SD
Offline giusCB
« Reply #520 on: May 12, 2022, 11:41:35 AM »
the station are side by side ? Do you have a manual rain gauge as reference ?
www.turismometeo.it
    • wsNoordbergum
« Reply #521 on: May 12, 2022, 11:52:39 AM »
Approximately 1m apart I do not have a manual rain gauge
Davis rain gauge is version with single spoon
Meteobridge nano SD
Offline giusCB
« Reply #522 on: May 12, 2022, 02:41:03 PM »
without a manual as reference is impossible to understand which one is correct or not
www.turismometeo.it
Offline tweatherman
« Reply #523 on: May 12, 2022, 11:58:57 PM »
man 7.5mm
witt  7.4mm
vp2  7.8mm
What firmware version on WS90 with the offsets?
tweatherman
    • wsNoordbergum
« Reply #524 on: May 13, 2022, 12:39:29 AM »
Manual rain gauge is coming soon to be sure
Meteobridge nano SD
