Author Topic: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test  (Read 48618 times)
Offline Autofill
Re: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test
« Reply #450 on: April 20, 2022, 08:08:26 AM »
Hi, just wondering if one of you can check something. If you have the AC/DC power pack for the wittboy, and run it only on that with no batteries installed, what does the battery indicator show?
Im currently troubleshooting with Ecowitt about this. I have a low battery indicator on when running on DC power and no installed batteries.
Ecowitt WH2320-E
Ecowitt HP2551-C (SOLD - replaced with Home Assistant Fully Kiosk FireTab HD10)
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH41 (Honeywell-based USB/Supercap modified)
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Ecowitt Wittboy running on 12VDC  solar power
Offline giusCB
  • www.turismometeo.it
« Reply #451 on: April 20, 2022, 09:16:16 AM »
new 1.1.9fw can be download here: https://drive.google.com/file/d/1dBrjOhfrJn7va4eUVSwOxgJsf8qn8UHY/view
this fw. help to fix wrong gust values
please give it a try and let us know if it works  [tup] [tup]
www.turismometeo.it
Offline rage302
« Reply #452 on: April 20, 2022, 10:06:46 AM »
I'm using just the AC/DC Power and my battery indicator shows ~0,6V LOW (in red) at nights and starts rising as soon as the UV panel produces some Power.
I will install 2 AA Batteries in the meantime since ecowitt will hopefully fix this with a firmware update.
Offline Autofill
« Reply #453 on: April 20, 2022, 10:29:46 AM »
[quote author=Autofill link=topic=43139.msg445957#msg445957
Thank you very much for confirming this behavior as this is what I'm experiencing exactly!
According to Ecowitt there is no hardware in the wittboy that can distinguish between AC/DC power or battery power, meaning definitely this would have to be a software or firmware fix.
Thank you for confirming this again at least now I know my unit is not defective and operating as designed.
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Offline Rover1822
« Reply #454 on: April 20, 2022, 10:55:54 AM »
There has to be something, at least in my thought process, as one would not want the heater activated on just battery power.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline Autofill
« Reply #455 on: April 20, 2022, 11:14:41 AM »
That is a good point you raise. Hopefully if enough people bring this to Ecowitt's attention then can resolve it sooner. Its no big deal, except having that low battery indicator warning.
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Offline tweatherman
« Reply #456 on: April 20, 2022, 05:27:30 PM »
Hi!
I’m actually pretty impressed with the temperature and humidity readings on the WS90 beta version.
It looks like the temperature value of the WS90 is more in line with reality.
With newer fw. version (1.1.9) the automatic algorithm for temperature correction was deactivated after a request by some Italian beta testers. As we know I'm banned from them so I don't have any more information. I'll ask to ecowitt what is their strategy about that.
Now with 1.1.9 I've a massive overestimate
So even with radiation compensation off in 1.0.9 is it still in that particular firmware that still compensates or is it raw sensor data?
tweatherman
Offline giusCB
« Reply #457 on: April 21, 2022, 04:23:58 AM »
Hi!
tweatherman
raw data
www.turismometeo.it
Offline giusCB
« Reply #458 on: April 21, 2022, 04:24:26 AM »
UP !
www.turismometeo.it
Offline rage302
« Reply #459 on: April 21, 2022, 09:24:46 AM »
Hi guys,
any recommendations to upgrade the ws90 to fw 1.1.9? Or is 1.1.7 good to go?
greetings rage
« Last Edit: April 21, 2022, 09:33:09 AM by rage302 »
Offline tweatherman
« Reply #460 on: April 21, 2022, 07:18:10 PM »
Hi!
tweatherman
raw data
Was hoping that was the case.
tweatherman
Offline giusCB
« Reply #461 on: April 22, 2022, 08:50:38 AM »
rain event today (17mm-h RR Max.)
ws90(1.1.9fw) 16.6mm (default gain setting)
VP2                14.0mm
Manual Gauge 13.5mm
www.turismometeo.it
Offline Arkadiusz_w
« Reply #462 on: April 22, 2022, 11:43:27 AM »
Yesterday I was able to update the WS90 to the latest software version.With the help of a forum colleague giusCB.  He stopped indicating the wind speed in the box and in the room in the absence of flow. I put it on the roof last night. This is how the measurement data looks like from 00:00 to 17:20.
WS90 and WS80 are 4-5 meters apart. WS90 is slightly higher by about 1 m. On two separate masts. The WS80 is next to the Barani MeteoWind and the WS90 is next to the WS68 Ecowitt.
The measurement results can be seen below. They are from WS90, WS80, WS68 and Barani Wind. In my opinion, the differences in measurement between ultrasonic and cup anemometers result from the measurement technology. For me, the differences between Barani Wind and WS80 rarely exceed 10 km / h. In light winds, they often report similar or analogous values. On the other hand, with increasingly stronger and especially sudden gusts of wind, the ultrasonic anemometer catches higher values. More than once Barani did not catch a short, sudden gust, while the WS80 caught it and showed values higher by about 10-17 km / h. We must remember that classic wind gauges can stop when the wind direction suddenly changes.
« Last Edit: April 22, 2022, 11:51:30 AM by Arkadiusz_w »
Ecowitt WS90 1.3.8, WS80 1.2.5, Ecowitt WS68, Ecowitt WH31EP/WH32EP, WH40, WH57, WN34L, WH51, WN34D, HP2560_C, HP2550_C, GW1100, GW2000. Davis Vantage Pro 2, Davis Vue, Davis 6313, Hongyuv WDS2E
Barani Meteoshield Pro II, III, Davis FARS 24H
Offline Gyvate
« Reply #463 on: April 22, 2022, 11:54:38 AM »
Not only this, cup anemometers by design only capture wind two-dimensionally (horizontally) while ultrasonic anemometers capture three-dimensionally and can catch tensors/vectors of the airflow in the third dimension which escape the cup anemometers' capturing. Simplified: cup = horizontal airflow; ultrasonic = horizontal plus vertical airflow.
Offline giusCB
« Reply #464 on: April 22, 2022, 12:05:11 PM »
They use a particular method to record the <gust> value, I'm near to find what is the problem.
The difference will be always present, but never over 15-20kmh in same location
www.turismometeo.it
Offline giusCB
« Reply #465 on: April 22, 2022, 12:20:11 PM »
Thanks for your work  [tup] [tup]
www.turismometeo.it
Offline Arkadiusz_w
Offline Rover1822
« Reply #467 on: April 22, 2022, 12:52:07 PM »
I would think they are, within limits as there is an aperture on the WS90 so you can't get the full range, like upwards, downwards, but angles of those. I don't have a WS80.
The quick shift due to turbulence/direction change yes I'm sure they can handle.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline giusCB
« Reply #468 on: April 23, 2022, 11:44:38 AM »
this is a comparison during a windy day between ws68 and ws90 before and after the new beta fw. 1.1.9
The graph are the difference from reference (in this case the ws68, who always had good reliable data compared to other anemometers)
before
after
from a constant overestimate by (about) 15 km h (up to 32 km h) to a (about) 2 kmh  :lol: ( without any offset )
we've just some random peaks but the improvement is evident...all suggestions are well accepted  [tup]
« Last Edit: April 23, 2022, 11:50:55 AM by giusCB »
www.turismometeo.it
Offline Autofill
« Reply #469 on: April 23, 2022, 02:25:16 PM »
thanks for improving the product algorithm. Question I have is should I upgrade my firmware to 1.1.9 from 1.1.7?
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Offline Autofill
« Reply #470 on: April 23, 2022, 02:31:19 PM »
Just wanted to follow up, Ecowitt cofirmed this behaviour that with no battereies installed in the Wittboy and running on AC/DC power only, it will always indicate "low battery". Since the unit is operating as designed, its not clear if they are going to issue a "fix" for this, since its not broken.....i guess im OK with this...I mean I could put battereies in it, but don't need to :)
My Wittboy (and other accessories including a supercap modified WH41) is actualy running off my off-grid solar system using a regulated 12VDC, fused  power supply https://www.wxforum.net/index.php?topic=43135.msg439334 and  12V 100 amp h heated Lithium battery, with 500 W solar system. I basically cut the wire at wittboy powerpack the end and connected via fitted terminal connector to the power supply. This is way better then having to have 50 ft wire from my house to my shed in the winters which can last many months.
« Last Edit: April 24, 2022, 11:18:36 AM by Autofill »
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Offline Arkadiusz_w
« Reply #471 on: April 23, 2022, 03:50:34 PM »
It may be useful for some to know how Barani MeteoWind calculates, among others, gusts of wind. Today my WS80 measured a maximum of 19.4 km / h, WS80 after software update 18.4 km / h, WS68, 13 km / h, while Barani Meteowind 17.4 km / h.
It is clearly visible that the wind gusts are lower after the WS90 update compared to the WS80 and are more similar to the MeteoWind Barani.
https://www.baranidesign.com/iot-wind-open-message-format
Below are charts of the 4 wind gauges today
Barani I see that he lost one frame at 20:10. Something's not working well for this LoRaWAN
Offline tweatherman
« Reply #472 on: April 23, 2022, 08:25:26 PM »
How are the temperatures with the latest firmware update? V 1.0.9 are right on with raw data settings.
tweatherman
Offline hiljo
    • Weerstation Hattem
« Reply #473 on: April 24, 2022, 04:45:09 AM »
I have the first version of the Beta WS90 unit and the GW2000. I noticed today that the cap voltage is reported in the custom upload having a value of 3.3:
  'stationtype' => 'GW2000A_V2.1.4',
  'ws90cap_volt' => '3.3',
  'ws90_ver' => '119',
Is this normal? Did Ecowitt used a fixed value maybe so there wont be a low battery message for the cap?
Ecowitt HP2550C v1.9.3
2x GW2000 v3.1.1
WittBoy WS90 v1.3.8
Smart Sensors (WFC01 & AC1100) beta tester
3x WH31, WH32, WH40, WH41, WH57
WN34L, 2x WH51, WN35, WN34D
Dutch translator for Ecowitt.
https://www.weerstationhattem.nl/
Offline Autofill
« Reply #474 on: April 24, 2022, 11:01:18 AM »
For the release version, my supercap voltage fluctuates. It goes up to 5.3V during the day in the sun, and then overnight, it drops slowly to about 4.8V (or something like that), then goes back up to 5.3V when charged again.
« Last Edit: April 24, 2022, 11:11:43 AM by Autofill »
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
