Author Topic: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test  (Read 48702 times)
Offline Autofill
Re: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test
« Reply #425 on: April 18, 2022, 03:43:08 PM »
does anybody know what FW version the Non-beta version for the Wittboy is? i.e. the once that just got shipped a couple of weeks ago for the backers. Is is the latest 1.1.7? thanks
Ecowitt WH2320-E
Ecowitt HP2551-C (SOLD - replaced with Home Assistant Fully Kiosk FireTab HD10)
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH41 (Honeywell-based USB/Supercap modified)
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Ecowitt Wittboy running on 12VDC  solar power
Offline KC5JIM
    • KC5JIM Weather
« Reply #426 on: April 18, 2022, 04:31:38 PM »
I had to update mine to 1.1.7 with the WS90_Upgrade_v1.1.7_Tool_Kit  found here: https://www.wxforum.net/index.php?topic=43139.msg445460#msg445460
Offline Gyvate
« Reply #427 on: April 18, 2022, 05:36:49 PM »
yes, it's V.1.1.7 and it applies to both hardware revisions: beta release (Rev1) and kickstarter release (Rev2).
Offline olicat
    • FOSHKplugin
« Reply #428 on: April 18, 2022, 06:15:25 PM »
Hi!
At least my WS90 was delivered with v1.09 - I also manually updated to v1.17.
The existing firmware version can be checked via EAR (provided the GW2000 firmware is v2.1.4). An update is then suggested there if necessary.
Oliver
Offline Autofill
« Reply #429 on: April 18, 2022, 06:19:53 PM »
thanks and good to know!
I just flashed 1.1.7 (without knowing what version it had before) and it went well.
Cheers
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Offline hiljo
    • Weerstation Hattem
« Reply #430 on: April 19, 2022, 02:29:37 AM »
The GW2000 and the WS90 are now published on the Ecowitt webshop, without a price and quantity, so not able to order it (yet):
GW2000: https://www.ecowitt.com/shop/goodsDetail/178
WS90: https://www.ecowitt.com/shop/goodsDetail/249
Ecowitt HP2550C v1.9.3
2x GW2000 v3.1.1
WittBoy WS90 v1.3.8
Smart Sensors (WFC01 & AC1100) beta tester
3x WH31, WH32, WH40, WH41, WH57
WN34L, 2x WH51, WN35, WN34D
Dutch translator for Ecowitt.
https://www.weerstationhattem.nl/
Offline hiljo
« Reply #431 on: April 19, 2022, 02:50:04 AM »
Also a new combination will be available with the new announced HP2560 display and the WS90. See Ecowitt.com:
https://www.ecowitt.com/shop/goodsDetail/251 (WS90+HP2560 = HP2564)
2x GW2000 v3.1.1
WittBoy WS90 v1.3.8
Offline giusCB
  • www.turismometeo.it
« Reply #432 on: April 19, 2022, 04:25:59 AM »
new V.1.1.9 fw. with " new pattern gauging algorithm " for wind speed is in testing.
i'll upload it when i'm sure it works ok.
www.turismometeo.it
Online Rover1822
« Reply #433 on: April 19, 2022, 10:45:30 AM »
First day of decent rain with the Kickstarter Wittboy
.72" (18.3mm)  Wittboy WS 90
.72" (18.3mm)  WH40 - 1
.65" (16.5mm)  WH40 - 2 (Checked unit after, was dirty)
.82" (20.8mm)  WH65
.69" (17.5mm)  Manual gauge
I'm not upset with the values for this 1 incident
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline Autofill
« Reply #434 on: April 19, 2022, 11:32:01 AM »
here's night #2 for the Wittboy. This was a test for the transition of temperature to heating zone. During the day, the temperature was at +11oC, then over night, the temperature dropped to +1oC. At around 2 am, that's when the temperature went below +5oC and you can see the Wittboys heater turn on with the dips in current from my off-grid battery current draw.
Ok, I'm very happy with the how the heater function works (important for clold climates such as mine). It would be intersting to see how well this works when temps get to -40oC next winter!
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Offline giusCB
« Reply #435 on: April 19, 2022, 12:29:37 PM »
have you noticed a rise in temperature? I'm afraid it might affect the TH
www.turismometeo.it
Offline giusCB
« Reply #436 on: April 19, 2022, 12:35:20 PM »
.82" (20.8mm)  WH65
the wh65 overestimate by default of +25% , you can set and offset ( 0.847 )
www.turismometeo.it
Online Rover1822
« Reply #437 on: April 19, 2022, 12:44:13 PM »
Yes, I know, I have volumes of data on the WH65, WH40s , I prefer to not calibrate it. (just me)
It doesn't report to anything public of note. You can probably find it on one of my Ecowitt sites, but eh...
I am more interested in informing myself on the weather, testing some , than really pushing my data out to other sites
Figure a buyer of any of these units, maybe with exception for those that read this forum, don't calibrate anything.
« Last Edit: April 19, 2022, 12:50:36 PM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline Autofill
« Reply #438 on: April 19, 2022, 12:52:00 PM »
Excellent question. Here is the reported temperature from the same time frame.
it does seem to have a small effect on the temperature, between 0.1 to 0.4 oC.
Ecowitt WH2320-E
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Online Rover1822
« Reply #439 on: April 19, 2022, 12:59:51 PM »
I think the question was, and I'm not that smart or missed it, how do you determine what the firmware version is on the device?
So what firmware did the kickstarter , ok lets call them production version ship with?
I am confused by the you saying the Beta version shipped with 1.1.7 as well
I mean for those that are just now receiving their production versions, do they need to upgrade their firmware to 1.1.7, or did it ship that way. for the Betas, yeah , you got yours before the firmware upgrade
« Last Edit: April 19, 2022, 01:03:41 PM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline giusCB
« Reply #440 on: April 19, 2022, 01:01:26 PM »
try this https://ear.phantasoft.de/
www.turismometeo.it
Online Rover1822
« Reply #441 on: April 19, 2022, 01:05:40 PM »
hehehe, yeah I should, thanks Oliver :)
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Online Rover1822
« Reply #442 on: April 19, 2022, 03:08:29 PM »
Oliver,
Have you seen an instance where the firmware version of the WS90 is reported ?
Edit: I don't believe this data is available from the custom server upload. I might look at the SDR data , but I have to switch radios to do that.
Yes I did look at the ear data, maybe I missed it
« Last Edit: April 19, 2022, 03:22:34 PM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline tweatherman
« Reply #443 on: April 19, 2022, 05:07:34 PM »
Oliver,
It’s toward the bottom of the report so to speak and it’s there.
tweatherman
Offline olicat
    • FOSHKplugin
« Reply #444 on: April 19, 2022, 05:09:24 PM »
Hi!
It is. At least with version v2.1.4 again.
The corresponding key is "ws90_ver":
ws90_ver   117
And there was also a reminder for a possible update seen:
There's a newer firmware V117 available for the WS90 (current: V109)- please check the MANUAL & SOFTWARE section on Ecowitt homepage for the WS90 and follow the instructions for the firmware update described there.
So with firmware v2.1.4 this key is send via custom server again (missed in v2.1.2 and v2.1.3).
Oliver
Offline tweatherman
« Reply #445 on: April 19, 2022, 05:11:20 PM »
Hi!
ws90_ver   117
Oliver
Thanks for the clarification Oliver.
tweatherman
Offline tweatherman
« Reply #446 on: April 19, 2022, 05:21:56 PM »
I’m actually pretty impressed with the temperature and humidity readings on the WS90 beta version.
tweatherman
Offline olicat
    • FOSHKplugin
« Reply #447 on: April 19, 2022, 05:47:43 PM »
Hi!
I agree.
The indoor T/H responds much faster (while opening a window). And the outdoor seems to be better shielded.
Have a look to my comparison - the WH31-D is a standard WH31 in a Davis 7714 passive (but massive) radiation shield:
https://snapshots.raintank.io/dashboard/snapshot/zcUUayqqgSU4XoGJRJOoy6Icvz2iEU4q
It looks like the temperature value of the WS90 is more in line with reality.
I am not yet really satisfied with the wind data. The wind direction is very fidgety and the wind speed and gusts seem to me to be much too high.
The SR seems to be a bit too high.
With the rain it is such a thing. I have already seen comparable values here with the WH65. But the next day - with a light drizzle - no rain at all was detected by the WS90. At least the WH65 showed some rain. But I still lack real comparative data.
Oliver
Offline giusCB
« Reply #448 on: April 20, 2022, 05:21:35 AM »
Hi!
With newer fw. version (1.1.9) the automatic algorithm for temperature correction was deactivated after a request by some Italian beta testers. As we know I'm banned from them so I don't have any more information. I'll ask to ecowitt what is their strategy about that.
Now with 1.1.9 I've a massive overestimate
www.turismometeo.it
Online Rover1822
« Reply #449 on: April 20, 2022, 07:54:04 AM »
Thanks Oliver.
found the firmware version, funny how I missed it .
So the unit shipped with 1.1.7
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
