Author Topic: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test  (Read 48730 times)
Offline Gyvate
Re: WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test
« Reply #350 on: April 09, 2022, 08:14:04 AM »
Why ecowitt don't talk with beta testers?  :-|
Maybe from their perspective the beta test is over as they are already shipping the GW2001/Wittboy to customers - kickstarter and others - it's already available for order on their web site.
They could still have left some message about the status in the FB group.
Offline tweatherman
« Reply #351 on: April 09, 2022, 10:15:13 AM »
Maybe I need to mention that in the last two days we had very different rainfall and wind conditions - from no wind to 77 km/h and drizzle to strong rainfall, both accompanied by changing wind conditions.
The graphs of the two stations (HP2551 and GW2001) at ecowitt.net will make that clearer.
https://www.ecowitt.net/home/index?id=27607
https://www.ecowitt.net/home/index?id=73231
Anyone experiencing more rain on WS90 piezo gauge vs manual rain gauges and or any Davis tipping bucket type? Factory calibration on all rainfall rates on my end. This is totally opposite than what I was expecting with what others are saying.
tweatherman
Another event yesterday wet snow that actually triggered the piezo gauge. Davis tipping bucket 0.04”, manual 8” 0.08” and piezo had 0.15”.
tweatherman
Offline giusCB
  • www.turismometeo.it
« Reply #352 on: April 09, 2022, 10:20:05 AM »
tweatherman
tweatherman
Is your ws90 a beta unit?
The versions on sale now have a new system on the piezo sensors that prevents triggering in high humidity condition.
Tested
www.turismometeo.it
Offline tweatherman
« Reply #353 on: April 09, 2022, 12:03:15 PM »
tweatherman
tweatherman
Tested
Yes mine is a beta unit. Thinking I may have to decrease sensitivity on offset calibration rate or just live with it?
tweatherman
Offline giusCB
« Reply #354 on: April 09, 2022, 03:24:51 PM »
just live with it if is a false triggering  :sad:
www.turismometeo.it
Offline Gyvate
« Reply #355 on: April 09, 2022, 03:29:50 PM »
calibration won't change this behaviour ... - as @giusGB said: live with it
same with snow - today the snow which had accumulated over night in the funnels of my WH65 and my WH40 has started melting and produced 16.0 mm (WH65) and 10.7 mm (WH40) - the WS90 provided 0.8 mm (where would it collect all the snow and how would it register the transformation from solid into liquid aggregate state ? It cannot.
Same with dew / condensed humidity or collected droplets. Will not show - at least not properly.
Offline giusCB
« Reply #356 on: April 09, 2022, 03:31:43 PM »
tweatherman
tweatherman
Tested
tweatherman
But... try the new firmware  [tup]
www.turismometeo.it
Offline tweatherman
« Reply #357 on: April 09, 2022, 03:47:25 PM »
tweatherman
tweatherman
Tested
tweatherman
I believe I have the latest firmware. 2.1.3 GW2000 and 1.6.4, 1.7.8 on 2551C.
tweatherman
Offline Gyvate
« Reply #358 on: April 09, 2022, 03:48:19 PM »
what @giusCB means is the new firmware 1.1.7 for the WS90
he mentioned that earlier in the thread and also provided a link for download
Offline giusCB
« Reply #359 on: April 09, 2022, 03:49:25 PM »
Yes confirm, not the gw2000
www.turismometeo.it
Offline tweatherman
« Reply #360 on: April 09, 2022, 03:55:39 PM »
I finally saw the download zip file finally in past post. I’m not familiar with how to install this as with the HP2551C. Can anyone help on how to install this firmware update?
tweatherman
Offline giusCB
« Reply #361 on: April 09, 2022, 03:57:00 PM »
tweatherman
Unzip, there is a PDF with detail instruction. Use windows 10 if possible
www.turismometeo.it
Offline Gyvate
« Reply #362 on: April 09, 2022, 04:00:14 PM »
tweatherman
it is NOT installed with the HP2551 console - it is installed with the WS90 outdoor combo array.
In the download is a file which describes what you have to do in detail and with pictures.
Offline tweatherman
« Reply #363 on: April 09, 2022, 04:52:14 PM »
tweatherman
Yes,
I figured it wasn’t done on the console.
Offline tweatherman
« Reply #364 on: April 09, 2022, 05:01:52 PM »
tweatherman
Yes,
Gyvate,
I see the zip file download but I don’t see any foot notes on installation for the WS90. Could you help me out and point me in the right direction.
Offline Gyvate
« Reply #365 on: April 09, 2022, 05:14:19 PM »
when you unzip the file there will be a pdf document included which describes the whole procedure
when you unzip/extract the files, it proposes a directory WS90 Upgrade(v1.1.7) Tool Kit
when you unpack/unzip/extract the files there, you will find the following content:
the WS90 Firmware Upgrade help file.pdf contains the description
the readme.txt and version.txt you can ignore - they belong to the upgrade tool
« Last Edit: April 09, 2022, 05:16:33 PM by Gyvate »
Offline KC5JIM
    • KC5JIM Weather
« Reply #366 on: April 09, 2022, 05:14:51 PM »
Inside the zip file a pdf document titled "WS90 Firmware upgrade Help File.pdf" that has instructions and pictures to walk you through the update.
Offline tweatherman
« Reply #367 on: April 09, 2022, 05:30:03 PM »
Thanks a bunch to both of you.
Offline Arkadiusz_w
« Reply #368 on: April 10, 2022, 02:27:17 AM »
Is it possible to upload this update from a computer with windows 10. It shows me some errors with the STM32 driver. I downloaded from the manufacturer's website and it is not possible to upload the update. How does it look like with you?
Ecowitt WS90 1.3.8, WS80 1.2.5, Ecowitt WS68, Ecowitt WH31EP/WH32EP, WH40, WH57, WN34L, WH51, WN34D, HP2560_C, HP2550_C, GW1100, GW2000. Davis Vantage Pro 2, Davis Vue, Davis 6313, Hongyuv WDS2E
Barani Meteoshield Pro II, III, Davis FARS 24H
Offline Gyvate
« Reply #369 on: April 10, 2022, 02:55:44 AM »
I'm going to try my luck today. I had done this before with my WS80 and there was no issue with Windows 10. The driver shouldn't need to be extra downloaded. It is included in the Zip archive.
Offline olicat
    • FOSHKplugin
« Reply #370 on: April 10, 2022, 03:07:00 AM »
Hi!
For me, it was no problem yesterday under Windows 10. However, I did not have to install the driver separately. Either this was already done by the installation routine. Or I already had the driver from other projects.
Oliver
Offline Arkadiusz_w
« Reply #371 on: April 10, 2022, 03:13:11 AM »
It's weird. I installed the standard software and still had an STM32 driver error. I had information that there are no compatible drivers for this device.
Offline olicat
    • FOSHKplugin
« Reply #372 on: April 10, 2022, 03:31:51 AM »
Hi!
Ok, then Ecowitt has changed the behaviour with v2.1.3.
The keys are still included in the current version. It is possible that one have to activate the sending of these additional keys first - for example via a debug switch.
Or these keys are only sent to ecowitt.net and no longer via custom server.
In fact, various keys - including the key ws90_ver which indicates the version number of the WS90 firmware - are sent to ecowitt.net, but since firmware v2.1.1 no longer via custom server.
This is a pity - so unfortunately the version number check for the WS90 via EAR no longer works.
My enquiry to Ecowitt as to whether this is an oversight or whether these keys are deliberately sent exclusively to ecowitt.net is still unanswered.
I'll get back to you when I know more.
Oliver
Offline Gyvate
« Reply #373 on: April 10, 2022, 04:05:59 AM »
kurczę  ;)
let's see: krok po kroku
1. you unpack the zip file into the WS90 Upgrade(v1.1.7) Tool Kit directory
2. you install DfuSe_Demo_V3.0.6_Setup.exe
3. you go to C:\Program Files (x86)\STMicroelectronics\Software\DfuSe v3.0.6\Bin\Driver\Win10
4. you start dpinst_amd64.exe (as your Win10 installation is most likely a 64-bit installation)
after the installation completed you should see in the Device Manager under USB Devices (last entry of the device tree) the sub-entry "STM Device in DFU mode"
5. you go to C:\Program Files (x86)\STMicroelectronics\Software\DfuSe v3.0.6\Bin and start DfuSeDemo.exe
6. the driver should be shown in the firmware update interface on the top left
7. connect the USB cable with your PC and press the reset button (don't confuse it with the CAL button  8-))
8. continue following the instruction in the PDF file
good luck
Offline Gyvate
« Reply #374 on: April 10, 2022, 06:18:54 AM »
new fw. upgrade https://foue.omnicamp1.com/link/624e3f9dd342a10020629a28/624e3f831761c6001e15ff02/60fe8857b211cd7ebb5ab8f2?signature=cc59e01b718a79b294b6eb140c6806da238a53bc37431e1702d7b4c1fede9d56
Anyone installed this firmware already? And what are the experiences? I'm a bit wary because it doesn't seem to be officially released  :???:
The update is mostly for beta units like yours.
says who ? And what is it supposed to do ?
Ecowitt responded regarding the firmware WS90 V.1.1.7:
"It is not features enhancement, but the rain detection pattern improvement, and this is not noticeable to ordinary users, but it will improve rain measurement accuracy. "
I'd consider the enhancement of the rain pattern detection as an enhancement of the haptic rain measurement feature, but so be it ...  \:D/
