Here is a picture, or attempt at least, to show the 10 pin plug. The socket is secured by a screw thread, not a simple quarter turn and lock on the socket.
I looked at the links from EA1EF, and could not find a manufacturer's data sheet showing the correct pin identification or numbering. The way I numbered them is explained below and is almost certainly NOT the official pin number. I don't know if my antivirus software blocked a couple of .pdf downloads or why I couldn't find the official pin designations.
The picture shows the plug as seen if the top of the SR50a is at the top of the picture, and the little index is at the top, too. There is another index at the right side, about the 5 o'clock position.
The top two pins are numbered in my scheme, as 1 to the left and 2 to the right. I then dropped down to the next row, with three pins, and again starting at the left assigned 3,4,5.
The next row of three pins is 6,7,8
Finally the last row of two pins is 9, 10.
While there may have been some other molded in markings that I just couldn't illuminate to take a picture, there is one pin, number 7 in my scheme, with a "10" being shown, so I'm pretty sure the official pin numbering is far different, but for my purposes I am telling you what is connected to the pins
IN MY SCHEME:
Pin 1, Black wire, Ground on the terminal strip
Pin 2 Green Wire, SDI-12/RS232 Tx wire on the terminal strip
Pin 3, Red wire, +12v on the terminal strip
Pin 5, White wire, RS232 Rx on the terminal strip
Pin 8, Clear wire/shield, Shield on the terminal strip.
Here is my attempt at labelling the pins as I assigned numbers
1 2
3 4 5
6 7 8
9 10
Note in the picture there appears to be '10' molded into the plastic at the base of the pin, so I am hoping someone can find a professional drawing with the real pin designations on them.
Also, I found a cable assembly as pointed out in the previous links on this subject, but the socket and a cable premade costs about $170, which is too rich for my blood and is about three times what I spend for the SR50a.
Digikey has what looks like to be the right socket to wire up, but I cannot get the pictures to download, and that socket is about $20.
