Author Topic: Rainwise Net - UPDATE  (Read 1678 times)
Offline VaJim
« on: January 05, 2013, 11:26:27 AM »
Happy New Year!
Unfortunately we missed our January 1st deadline to go live with Pro. It turns out that adding multiple station support was a bigger job than expected. The good news is its now available. This option means that if you own or manage more than one station you can now use a single email address and log in for all your stations.
The process of consolidating stations is pretty straight forward:
1. Log into the  account of the station you wish to move. Select "Unregister a station" from the menu in the settings page and follow the prompts.
2. Log into the account where you want to add the station. Go to the settings page and select "Add station". Again, simply follow the prompts.
Please note you will loose photos when you move a station. You won't loose weather data.
If you have more than one station assigned to your account you will see a drop down list on the menu. You can use this to quickly switch between stations.
NEWA users, please note that the drop down list for NEWA stations is no longer available. We will be adding a NEWA landing page with a clickable station map. For now please just create bookmarks for the stations that are of interest to you.
Graphs are here!
Along with this update we are also launching a beta of the Pro graphing feature. Click on Graph to see this preview. We are going to be adding another option that will let you create your own much larger custom graphs. This should be available shortly.
RainwiseNet Pro should be available soon now that the multiple station support is done. Our developers are working on finishing up graphs and alarms. Once that's done we should be ready to release Pro.
Wayne Burnett
Rainwise Inc.
