How do you delete the total rainfall on the display? The book doesn't say anything on how to delete it and start it over.
See highlight text below.
The manual is available here:
http://www.lacrossetechnology.com/2308/manual.pdfEntering each MIN/MAX modeIn the normal display mode for e.g. the indoor temperature and
humidity, press MIN/MAX key to toggle the display between the
maximum, minimum and current records. While the maximum or
minimum values are shown press the DISPLAY key once to show the
time and date that value was received. Now press the MIN/MAX key
to toggle from the minimum and maximum readings and the time and
dates the records were received are also shown. Still in the MIN/MAX
mode (where the time and date for a value are shown), press the
DISPLAY key to move through each respective unit as follows:
• Indoor temperature (max or min with time and date)
• Indoor humidity (max or min with time and date)
• Outdoor temperature (max or min with time and date)
• Outdoor humidity (max or min with time and date)
• Outdoor wind chill (max or min with time and date)
• Outdoor dew point (max or min with time and date)
• Rainfall 24 hours (max or min with time and date)
• Rainfall 1 hour (max or min with time and date)
• Rainfall total (max only with time and date)When in any of the above modes, press the MIN/MAX key to toggle
between the maximum or minimum values of those records and their
respective time and dates will also be shown.
For the wind and pressure minimum and maximum readings, the
same would apply except that the WIND or PRESSURE keys would
be used instead of the DISPLAY KEY.
Exiting the MIN/MAX modes
If the maximum and minimum modes with times and dates are
displayed, press the PLUS (+) key twice to return the normal display
mode.
Resetting the MIN/MAX recordsWhile in the minimum or maximum mode, the time and dates are also
displayed along with the recorded values. If the MINUS (-) key is
pressed while any of these values are displayed, that particular
minimum or maximum record will be reset to current reading together
with the current time and date with the exception of the following:
The first case is Rainfall Total, which has neither maximum nor
minimum records since it will show only the total rainfall. Pressing
the MINUS (-) key will reset the rainfall total value to zero and the
time recording to current time. The second case is Rainfall 24h or 1h, which records maximum
rain count only for these respective times. Pressing the MINUS
(-) key in either of these two modes will reset the rain count to the
current rain count and time and date.
