Miscellaneous Debris => Tech Corner => Topic started by: steviebaby59 on October 07, 2021, 12:00:10 PM
Can anyone explain to me what I'm doing wrong. I had to replace the hard drive in my PC about a month ago. Ever since, all I get is old FOUS and set upper wind flow warning after each forecast. I have changed my settings in the WISXMATE several times to no avail.
Have you run a 'manual' WxSimate run? If so, does it show any errors? Also, do you have the appropriate boxes checked for GFS and NAM FOUS in the WxSimate dialog box?
Steve
When I run manual, everything is fine. No errors. What would be causing the difference?
