Weather Software => Cumulus => Topic started by: kg4ooz on June 24, 2021, 11:24:58 PM
I am as new to Cumulus as I can be and am in need of help. I installed CumulusMX on a Raspberry pi 3B+ using a ethernet logger installed in a Davis VP2. I got cumulus communicating with the logger but the "last station update time" does not match either of the times. The times matches the minutes and seconds but is 8 hours behind. This seems to be also causing my records times to be off along with the Sunrise/sunset times. I have checked everything I can find to do with time and rebooted everything involved. Every time matches except for that one. Logger, console, and cumulus all match. Any help would be greatly appreciated.
I found my problem, the time of the RaspberryPi itself was incorrect.
