Weather Software => Virtual Weather Station => Topic started by: daybreak on December 20, 2020, 11:04:23 AM
Title: VWS and METAR report
Post by: daybreak on December 20, 2020, 11:04:23 AM
Yes I'm still running VWS... :-) :-)  On Friday my METAR reports quit working.  There is nothing on the METAR Observation Report, does anyone have any ideas?  Wait a few days?
On another subject, what software would be good to migrate to?  I only use the html tags from VWS, the history and NOAA reports.
Richard
Title: Re: VWS and METAR report
Post by: Blizzard on December 20, 2020, 02:15:29 PM
Same problem here with Hamweather
Post by: saratogaWX on December 20, 2020, 03:09:45 PM
Both VWS and Hamweather may be relying on http access to tgftp.nws.noaa.gov site which now only accepts https or ftp requests.  Since Ed hasn't updated VWS in multiple years, it's not likely to get fixed, and I think the Hamweather scripts are now out of support too.
It may be time to switch to a different weather software .. CumulusMX is nice, free and supported.  Weather-Display is great with a one-time fee and highly supported.
Post by: Blizzard on December 20, 2020, 04:19:27 PM
Thanks for the information saratogaWX
Since you seem to know those 2 softwares, do they aloow ftp download and upload? Do they both have the possibility to use templates to upload local observations to a website with personalised weather icon and finally, do they allow to download NOAA data and use it to generate a weather icon? Lots of questions, but which software is most likely to offer the same features or more than VWS.
Post by: SoMDWx on December 20, 2020, 04:44:01 PM
The scary thing is that i have all this data since 2006 using VWS and so much on my site is based on this. I am scared switching all of this over to something new....
Post by: saratogaWX on December 20, 2020, 04:54:31 PM
Yes, both CumulusMX and Weather-Display have FTP capability.  Both have multiple templates available.
CumulusMX does not currently use a METAR for sky conditions, but the CU-Plugin for the Saratoga template (and also the Leuven template) add that capability.  Weather-Display can natively use a METAR (in conjunction with a solar sensor) to produce sky conditions/Icon.
Both CumulusMX and Weather-Display produce near-realtime (5 or 10 second) update file and the Saratoga and Leuven templates can use that for more rapid updates on current conditions to your website.
Weather-Display has the most features, and because of that, it may also have a slightly more difficult configuration initially.
CumulusMX uses a local website for customization and has fewer configuration options for an easier initial setup.
You can see what the Saratoga template with Weather-Display looks like here (https://saratoga-weather.org/wxtemplates/USA/wxindex.php) and with CumulusMX here (https://cumulusmx.saratoga-weather.org/index.php)
BTW, I've been running Weather-Display since 2004, VWS since 2007 (for template testing), Cumulus since 2011, CumulusMX since 2015, and WeatherLink since 2004.  My main site uses Weather-Display (and a bit of WeatherLink) for displays.  The other software continues to be used for live testing with my template sets.
Post by: Blizzard on December 20, 2020, 05:35:58 PM
So, all put together, I understand you would recommand Weather Display a bit more. I provide data to a private sponsor so I had to install VVP to split my data between VWS (personal need) and Weatherlink (private company needs). I never really got into Weatherlink, but it doesn't seem to allow NOAA download to generate an icon from another location. Unless you tell me it can, I guess I can get and run Weather Display to quicky replace the icon from amother location VWS allowed to generate (through NOAA data) and slowly move the rest of my site to Weather Display in the upcaming months or keep the 3 softwares running on my computer if I can't get Weather Display to fully operate as VWS. Thanks for your help...
Post by: daybreak on December 20, 2020, 07:13:07 PM
Thanks Ken for the information.  I agree it's time to do something.  But I'm also with SoMDWx that I have 15 years of data that I would like to keep the history.  Do any of these incorporate the data?  Also is it possible for me to run VWS and WeatherDisplay at the same time to make an easier transition over to Weather Display and learning how to use the tags in Weather Display.  Does it work similar to VWS?
Thank you,
Richard
Post by: Blizzard on December 20, 2020, 07:36:03 PM
You can run up to 8 different softwares with Virtual VP Richard, So, not a problem. I run VWS and Weather Link and I will install Weather Display (free trial)to see how it works...
Post by: Blizzard on December 20, 2020, 07:54:38 PM
In order to add to the discussion, I've just noticed by opening the Metar Station txt file that it read: Service Temporarely Unavailable. I don't know if that is meaningful. Also, can we just use the FTP retriever tool to connect to another server to get the NOAA Station file and make it work?
Post by: galfert on December 20, 2020, 08:26:22 PM
My recommendation for anyone running VWS is to get the WLL. Then you can keep running VWS and test out any of the other new software. You can run all software at the same time and they all get data from the WLL....Cumulus MX, Meteobridge, Weather-Display, and WeeWX. All of these now run on a Raspberry Pi too. You can even run multiple instances of the same software.
With the WLL, your old logger meanwhile keeps ticking along and stays connected to VWS. This way you can take your time testing, learning, and deciding on new software. You don't need to commit to any of these alternatives until you have thoroughly tested it.
Then when you are through testing then you can explore data export and import. Again this still doesn't take your existing station down with VWS. All of these software offer data importing and some may be more suited than others to do the data migration from VWS. But data is data and it can be manipulated and converted. In any case this data migration doesn't mess with the original data. If you have years of data to import do it little by little to test.
Part of your software testing and familiarizing should also entail migration of your website if you have one. You can mount a test site internally for testing that will not cost you anything. Or most probable that your existing hosting solution will let you have a different page that is not published that you can use for test.
The WLL is the the most flexible logger because it offers this great flexibility in allowing for all these multiple connections. The WLL does not require a Weatherlink paid plan for you to get all this live data as the live data is provided directly to these various software from the WLL right on your local network. The WLL is like a WeatherlinkIP on steroids and then some, because it also in some ways acts like an Envoy 8x with a logger (doesn't require the display console) and can get data from multiple ISS and transmitters. The WLL can connect to your network via Ethernet or WiFi...your choice. And best of all if any other software comes along and you've already made your decision to run whatever...then no problem...test out that other software and then migrate again at your leisure.
Then when you are done. And don't need VWS anymore, sell the old logger. Sell the display console too if you don't really need the display. That recovers some or all of the cost of the WLL.
Post by: daybreak on December 21, 2020, 08:46:08 AM
What is a WLL?
Richard
Post by: galfert on December 21, 2020, 08:49:18 AM
WLL = Weatherlink Live. It is Davis' newest logger.
Davis 6100
https://www.scaledinstruments.com/shop/davis-instruments/hardware-data-loggers-software/hardware-software-bundles/davis-6100-weatherlink-live/
More info
https://www.manula.com/manuals/pws/davis-kb/1/en/topic/weatherlink-live
https://www.davisinstruments.com/product/weatherlink-live/
Post by: 92merc on December 21, 2020, 08:52:16 AM
WD does have an import feature.  If you have all of your VWS CSV files from all your years, it'll import right in.
Post by: Blizzard on December 21, 2020, 09:22:47 AM
The fact that the NOAA files still get downloaded in the VWS makes me hope that the problem is temporarily. Let's hope, but I'll slowly move towards WD thamks to your recommandations.
Post by: Impala88 on December 21, 2020, 10:43:28 AM
When this has happened before I submitted a ticket on PWS.com.  I was unable to submit a ticket due to an issue on that site.  I did reply to one of their replies to me on my last ticket.  Hopefully, they can get this resolved soon.
Title: Re: VWS and METAR report **UPDATE**
Post by: Impala88 on December 21, 2020, 10:57:20 AM
Update:  I was able to submit a support ticket this morning on PWS.com.  Joe has been very responsive in fixing this issue so I am confident it will be resolved shortly.
Post by: Blizzard on December 21, 2020, 11:22:20 AM
Just to understand Impala88, my NOAA metar setting is set to Hamweather and not NOAA. Is pws.com the place it all comes from? I don't understand why it would change anything. Thanks for explaining.
Post by: SoMDWx on December 21, 2020, 02:05:42 PM
I was able to modify Ken's METAR script to retrieve only the METAR closets to me and display the current sky and weather condition....
It is integrated successfully into my main page....
Thanks Ken for a great script!
Jim
Post by: Blizzard on December 21, 2020, 03:25:00 PM
Jsut to tell you that it is back and running. Gives us/me time to move to WD.
Post by: Otis on December 21, 2020, 03:34:59 PM
I used VWS for years and switched to WD after the degradation of the VWS program (no updates).
92merc is correct, I used the WD import function no problem for years of data.
Note: I still run VWS w/separate console, I still use/like some of the features from VWS however, WD is the driver of my site.
Post by: saratogaWX on December 21, 2020, 03:37:49 PM
Jim
Thanks, and happy you've found the get-metar-conditions-inc.php script useful for your site.
Post by: longmire on December 28, 2020, 08:00:59 PM
I too had a METAR interruption, but bless him, Joe worked with me for a bit and their team launched a special fix to talk to VWS in the "old language" haha. So now- days after the holiday - my system is generating METAR icons just like new.
Joe's the BEST!!! =D> =D> =D> \:D/ \:D/ \:D/ [tup]
Post by: Blizzard on December 28, 2020, 09:25:04 PM
That's great! But, how long can we hope this fix to hold?
Post by: Blizzard on December 02, 2021, 09:28:03 PM
The metar generated sky icon is down running here agin. Does anybody knows what to do or knows how to retrieve data to generate an icon trough a simple script?
Post by: saratogaWX on December 02, 2021, 09:45:17 PM
It's hard to help diagnose the issue without a link to your weather website showing the issue...
Post by: Blizzard on December 02, 2021, 09:55:56 PM
Actually, the issue is in VWS. The metar icon has stopped updating last night
Post by: Impala88 on December 02, 2021, 10:18:16 PM
The Hamweather Metar downloads are not working for me either.  The support form on PWS.com is not working.  I E-mailed support@aerisweather.zendesk.com to see if they could check on it.
Post by: Blizzard on December 03, 2021, 06:46:01 AM
That is what I meant. Thanks and keep us posted plz.
Post by: Blizzard on December 04, 2021, 02:35:17 PM
Back running here :-)
Post by: Impala88 on December 04, 2021, 05:14:23 PM
I believe you are looking for the data here:
http://www.hamweather.net/pub/data/observations/metar/stations/KMSP.TXT
While no longer a fully supported offering, I can confirm that the above data set had an availability issue the past few days. The issue was corrected yesterday.
I hope this helps, and let me know if I may be of additional assistance.
Tony
AerisWeather Support
http://support.aerisweather.com/
Yes, it's working—for now.  It's no longer a fully supported offering so let's enjoy it while it lasts.  :-)
