Author Topic: New Stuff - Ecowitt Has the Newest Fine Offset Hardware  (Read 58760 times)
Offline Mandrake
Re: New Stuff - Ecowitt Has the Newest Fine Offset Hardware
« Reply #250 on: June 25, 2019, 03:33:12 AM »
If it is made by Fine Offset then the first port of call is to send an e-mail to Lucy at Ecowitt.
support@ecowitt.com
If its still available then Lucy will know!
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Offline Lucy
« Reply #251 on: July 04, 2019, 10:07:24 PM »
Dear all,
We have added the max/min/average value on the graph when viewing the 24H/daily/weekly/monthly/yearly/custom data:
What do you think of the new features?
Your good suggestions are welcomed!
Thank you~
Best Regards,
Lucy
Ecowitt Weather Instruments at: http://www.ecowitt.com/
FB: @ecowittsupport
Twitter: https://twitter.com/ecowittweather
Email: support@ecowitt.com
« Reply #252 on: July 04, 2019, 10:51:17 PM »
Lucy,
Thank you for the update to the graphs! I like the new Min/Max/Avg.
I do have some bugs to report. For most items when hovering with the mouse pointer there is a duplication of the information. See attached image. This happens for just about all the graphs where it lists the item twice.
The second problem is that for some of the Averages the number is cut off on the right side of the window. I tried resizing and I can briefly see the complete Average but it then reverts to being cut off. This seems to happen for Pressure and PM2.5 only it seems. Maybe the units you select makes a difference. Please see same attached image.
Very happy to see the continued innovation with your products.
« Last Edit: December 06, 2019, 01:51:22 PM by galfert »
Offline Lucy
« Reply #253 on: July 05, 2019, 05:01:38 AM »
Lucy,
I do have some bugs to report. For most items when hoovering with the mouse pointer there is a duplication of the information. See attached image. This happens for just about all the graphs where it lists the item twice.
Hi galfert,
Thanks for pointing out the bug. Our engineer is checking that now. Once fixed, we'll let you know. Thank you so much.:)
FB: @ecowittsupport
Offline mauro63
« Reply #254 on: July 05, 2019, 05:51:37 AM »
Hi Lucy,
very good job  ;)
I have exactly same little problems
very useful upgrade!
Mauro
« Reply #255 on: July 05, 2019, 10:09:48 AM »
And just like that the bugs are fixed! Incredible. Amazing problem response time from Ecowitt.
Ecowitt should reach out to Weather Underground and teach them a thing or two.
Thank you Lucy and thank you to Ecowitt and to their great people.
Offline droiddk
« Reply #256 on: July 05, 2019, 11:17:02 AM »
Dear all,
Thank you~
Best Regards,
Lucy
Nice job! Like it!
Regards
Offline Lucy
« Reply #257 on: July 05, 2019, 11:02:22 PM »
Thanks for all your support!  :grin:
FB: @ecowittsupport
Offline Lucy
« Reply #258 on: July 05, 2019, 11:03:36 PM »
Hi Lucy,
very good job  ;)
Mauro
Thank you :grin:
FB: @ecowittsupport
Offline Lucy
« Reply #259 on: July 05, 2019, 11:04:03 PM »
Dear all,
Thank you~
Best Regards,
Lucy
Nice job! Like it!
Regards
Happy to hear that.:-)
FB: @ecowittsupport
Offline Mapantz
    • Wareham Weather
« Reply #260 on: July 08, 2019, 04:03:40 PM »
Soil moisture is showing up as 'Humidity' on the graph.
Offline MacGarage
  • SW Ohio
« Reply #261 on: July 08, 2019, 07:32:59 PM »
I noticed the same with regards to the moisture sensors showing up as humidity:
Ecowitt WH2320E
AcuRite Atlas
Offline Mandrake
« Reply #262 on: July 09, 2019, 03:22:44 AM »
Just checked and my graphs are showing as soil moisture (not humidity) so I guess the wonder techs at Ecowitt have tweaked the system already!
No flies on them!
G1ZFO
Offline Lucy
« Reply #263 on: July 09, 2019, 06:25:07 AM »
It appears they no longer sell the ws68, does anyone know a source for this?
Hi, we're improving the WS68 to perform better now and it might be available on August.
We'll let you know when it's available again.
Sorry for the inconvenience caused.
FB: @ecowittsupport
Offline Lucy
« Reply #264 on: July 09, 2019, 06:29:49 AM »
Thanks, I've asked Lucy and she confirmed. Funny fact, Lucy is also answering question on Fine Offset website... so it's the same company (EcoWitt/Fine Offset?
Fine Offset told me that their HP2550 model is 200$ US + shipping, which is a good deal I think considering the fact that Ambient Wx are not shipping in Canada nor Amazon.com and Amazon.ca don't have this product in stock... It looks like HP2550, WS-2000 and WH2551 are all the same thing am I right?
Merci,
Stratus13
Hi, sorry for the misunderstanding. I work for Ecowitt and Ecowitt cooperates with the Fine Offset. Fine Offset doesn't deal with retail orders, and they will transfer them to our team to handle.
Anyway, let's focus on the products and service 8-)
FB: @ecowittsupport
Offline MacGarage
  • SW Ohio
« Reply #265 on: July 09, 2019, 09:50:23 AM »
No flies on them!
Noticed that too...that was quick!
Ecowitt WH2320E
AcuRite Atlas
Offline Lucy
« Reply #266 on: July 21, 2019, 10:08:53 PM »
Dear all:
Our engineers have made some modifications to update the WS View and ecowitt.net:
1. V1.5.0 Firmware Released for WS View(need to update the app first):
Calibration function added for WH31 Multi-Channel T & H Sensor and WH41 PM2.5 Sensor
2. The graph automatically refresh function on the phone for ecowitt.net is also available now.
Please check and let us know your feedback.:)
Thank you!
Best Regards,
Lucy
FB: @ecowittsupport
Offline krojan
« Reply #267 on: July 24, 2019, 03:48:48 AM »
My WH31 sensors are so accurate that I do not have to calibrate. But it works.
The charts for ecowitt.net on the computer refresh very nicely.
When will the ultrasonic wind meter WS80 be sold?
Does the HP3500 station receive data from more than one PM2,5 sensor?
« Last Edit: July 24, 2019, 03:58:25 AM by krojan »
Sorry for my English.
GW1000, HP2551-C, HP3001, HP1001.
Offline Lucy
« Reply #268 on: July 26, 2019, 04:05:03 AM »
Hi, thanks for your feedback.:-)
We'll need some time to prepare the WS80 and we'll let you know when it's available.:)
The HP3500 can only accept one WH41 PM2.5 sensor. If you want to add more, you can consider to add a GW1000. The GW1000 can accept MAX 4X WH41 sensor.
Any other question, please contact us at support@ecowitt.com.
Best Regards,
Lucy
FB: @ecowittsupport
Offline krojan
« Reply #269 on: August 02, 2019, 10:24:33 AM »
WS68 is available again.
Lucy writes about it here: https://twitter.com/ecowittweather/status/1156099745783246848
And here you can buy: https://www.amazon.com/dp/B07JLRQJ12
« Reply #270 on: August 02, 2019, 12:19:02 PM »
Before anyone goes out and gets a WS68 be forewarned!
If you have an Ambient console then WS68 NOT COMPATIBLE.
If you have an Ecowitt console then WS68 WORKS WITH GW1000 and HP3501 CONSOLES.
I don't know why but for some reason none of the Ecowitt sensors work with Ambient consoles. But the other way around is no problem...meaning if you have an Ambient sensor then the Ecowitt consoles will have no problem with picking them up.
Ecowitt,
Please tell us why? What has Ambient done to their firmware that prohibits Ecowitt sensors from working even if the frequency matches?
Offline Lucy
« Reply #271 on: August 03, 2019, 07:23:00 AM »
Ecowitt,
 :roll: Sorry, we have no idea.
FB: @ecowittsupport
Offline Lucy
« Reply #272 on: August 03, 2019, 07:24:23 AM »
Dear all:
We have updated the ecowitt.net just now!
1. Display the daily max/min value on the Dashboard.
2. Add timestamp for the max/min value on the graph.
Please let us know your feedback! (we'll reply after the weekend)
FB: @ecowittsupport
Offline Vette-kid
« Reply #273 on: August 03, 2019, 07:57:12 AM »
Lucy, I really like the website feature.  A couple of observations;
One, I would still prefer to have an app for it as opposed to viewing it in my browser.  In my opinion that just simplifies it and makes it easier for me.
Two; I'd love an option to display a single value for each sensor.  For example, if I want to see current conditions I currently have a graph to look at the last 24hrs or daily.  It's a bit difficult to see the actual current condition at a glance.  Maybe an option to display the current reported values only?  Or if you want to see the monthly Max values, or annual or whatever, have the option for just that value without the graph. If there is a way to do this that I'm missing please let me know.
« Reply #274 on: August 03, 2019, 09:10:31 AM »
If you are using Android there is a very simple easy way to add an icon on your home screen that will pretty much act like any other app icon.
- in Chrome load up Ecowitt.net (I suggest telling the login to remember your password)
- go to 3 dot menu on top right
- select Add to Home Screen
- confirm action to add icon
- look for new icon on your home screen
Many apps that you use are really nothing more than a browser inside of a simple app shell. These are call wrapper apps. Because all they do is access the web and the app is not much more than just wrapping the browser engine into an app for access.
Perhaps there is a way to do this on iOS also. I don't have my test iOS device with me to look now.
What your are asking for is like a Summary Report to the stated period. You want to see a report of max/min and total rainfall for the time frame selected in a nice simple table. For daily it pretty much is the boxes for each sensor at the top of the page. We have that for daily. What we don't have is the tally of weekly, monthly and yearly (and custom) without looking at the graph stamps. The graph stamps don't address total rainfall nor do I see how they could, so the Summary Report could show that.
« Last Edit: August 03, 2019, 09:20:01 AM by galfert »
