nice rainning event yesterday...
My
aim is to check and if needed , to
calibrate the Davis vantage pro rain collector.
Tropo or Stratus will be
permantly installed next to the Davis vantage pro and the readings will be used for following the Vantage pro rain reading accuracy over time
So Davis digital 16.5 cm vs Davis analogue 16.5cm
Tropo 10.1cm vs Stratus 10.1cm
Coleration Davis analogue readings to Tropo and Stratus reading.
Tropo (10.1cm) reading by my eyes
~12.6mm .. The volume measured
~103ml and the formula gives
12.86mm Stratus(10.1cm) reading by my eyes
~13.4mm .. The volume measured
~106ml and the formula gives
13.23mmDavis bucket (16.5cm)
12.86mm volume measured
275mlDavis digital (16.5cm)
12.4 mmIf i calculate the
1ml error of the glassware
Tropo 103 ml or
12.86mm with error (102-104) = (
12.73-12.98)
Stratus 106 ml or 1
3.23mm with error (105-107) = (1
3.11 -13.36)
if i calculate a 3ml error for Davis bucket , since my measuring cylinder is 100ml and for 275mL i empty it 2 timees..three readings
Davis bucket 275ml or
12.86mm err (272-278 ) (
12.72-13)
Going back to my aims
Davis digital
12.4mm vs Davis analogue
12.86mm err(
12.72mm-13mm)
dif.
0.46mm err (
0.32mm-0.6mm)
dif%
3.7% (
2.6%-4.8%)
I may need to do a calibration of +2%
After this rain event considering its unique characteristics such as wind ,rain rate ,it seems my Davis digital
underestimated the total accumulation.
There is no doubt to me that Tropo measures l
ess than the Stratus but the question now is if Tropo readings are more
accurate comparing to the Stratus one in
coleration to the Davis 16.5cm gauge
In this test it seems Tropo reading is more close to the Davis analogue one
I have to wait another 2 or 3 rain events in order to decide if calibration is needed to the digital Davis by taking the averages and which , Tropo or Stratus , will be used as a guide .Actually , both can be used , but which one is more close to the Davis reading (easy to calculate )
Your thoughts ,hints,comments will be appreciated
