Author Topic: streaming radio  (Read 25605 times)
Offline cospringswx
    • Colorado Springs Weather
Re: streaming radio
« Reply #25 on: March 18, 2013, 08:14:56 PM »
Thanks. I will give this a try.
« Last Edit: March 18, 2013, 09:16:27 PM by hayskswx »
Ryan
Colorado Springs, CO
www.cospringsweather.com
Davis Vantage Vue
Weather Display Software
Amcrest HD IP Camera
Offline cospringswx
Re: streaming radio
« Reply #26 on: March 28, 2013, 02:25:07 PM »
Can't seem to get this to work with scanner cast. Bummer!
Ryan
Davis Vantage Vue
Offline cospringswx
Re: streaming radio
« Reply #27 on: March 30, 2013, 12:44:21 PM »
Are there any other programs that I can try?
Ryan
Davis Vantage Vue
Offline cospringswx
Re: streaming radio
« Reply #28 on: June 02, 2013, 05:44:58 PM »
Scannercast is running fine and the status is OK for 30 min. However WU says not active. I don't see what I have wrong here. I have both the Name and Description mirrored to match Scannercast. :roll: About to give up on this!
« Last Edit: June 02, 2013, 05:53:45 PM by hayskswx »
Ryan
Davis Vantage Vue
Offline kray1000
  • Purveyor of wry
Re: streaming radio
« Reply #29 on: June 02, 2013, 07:00:46 PM »
I'm not currently finding you on the audiostream listing.  Are you still using the same URL?
Offline cospringswx
Re: streaming radio
« Reply #30 on: June 02, 2013, 08:05:19 PM »
Yes sir. This link  http://audiostream.wunderground.com/hayskstornado/Hays.mp3.m3u still works but I'm not active? Don't make sense.
« Last Edit: June 02, 2013, 08:09:50 PM by hayskswx »
Ryan
Davis Vantage Vue
Offline cospringswx
Re: streaming radio
« Reply #31 on: June 02, 2013, 09:34:03 PM »
Right here
 Mount Point : (/hayskstornado/Hays.mp3) : Click to Listen
Stream Title:   Hays Kansas WX Radio
Stream Description:   NOAA Weather Radio 162.45 (SC 10307)
Content Type:   audio/mpeg
Mount Uptime:   Sun, 02 Jun 2013 21:21:35 -0400
Bitrate:   16
Current Listeners:   1
Peak Listeners:   2
Stream Genre:   Scanner
Current Song:   WunderRadio: #1 Radio App
Ryan
Davis Vantage Vue
Offline kray1000
  • Purveyor of wry
Re: streaming radio
« Reply #32 on: June 02, 2013, 09:37:45 PM »
I've been listening to your feed.  It sounds pretty good... am hearing it in both computer speakers.
Now that your stream uploads seem to be stable, you can, of course, make a link on your web site directly to the audiostream feed without using the WU flash player.
There is a "support" link you can use to contact WU to address the "inactive" issue you are experiencing: http://wiki.wunderground.com/index.php/NOAA_Weather_Radio#Troubleshooting
Offline cospringswx
Re: streaming radio
« Reply #33 on: June 02, 2013, 09:40:03 PM »
Make a link without using the WU flash player?
Ryan
Davis Vantage Vue
Offline kray1000
  • Purveyor of wry
Re: streaming radio
« Reply #34 on: June 02, 2013, 09:41:32 PM »
Looking on your site, you can add something on the left sidebar, like you did for "Gas Prices", for example.
Offline kray1000
  • Purveyor of wry
Re: streaming radio
« Reply #35 on: June 02, 2013, 09:51:58 PM »
Just for shiggles, do you have a screen shot of your weather radio sign-up page?  Sometimes two sets of eyes are better than one.
Offline cospringswx
Re: streaming radio
« Reply #36 on: June 02, 2013, 09:55:22 PM »
Here is where it says NOT active.
NOAA Radio Streams
Your Current Stations
Location    Callsign    Frequency    Title    Description    Active
Hays, KS    WXM35    162.45    Hays Kansas WX Radio    NOAA Weather Radio 162.45    No    Edit    Delete
Ryan
Davis Vantage Vue
Offline kray1000
  • Purveyor of wry
Re: streaming radio
« Reply #37 on: June 02, 2013, 09:59:16 PM »
NOAA Radio Streams
On the audiostream listing, "(SC 10307)" is being added to the Stream Description... by the ScannerCast software perhaps?  But that might be why the string comparisons aren't matching up.
Offline cospringswx
Re: streaming radio
« Reply #38 on: June 02, 2013, 10:05:42 PM »
I don't get it because they are exactly the same.
Ryan
Davis Vantage Vue
Offline cospringswx
Re: streaming radio
« Reply #39 on: June 02, 2013, 10:08:37 PM »
Here is a screenshot of scannercast
Ryan
Davis Vantage Vue
Offline kray1000
  • Purveyor of wry
Re: streaming radio
« Reply #40 on: June 02, 2013, 10:09:01 PM »
I think it might be something that's hard-coded into the ScannerCast software (something that can't be changed by the user).
You can try that support link at WU and see if they can add your stream manually to their list.
Have you tried Edcast recently, and are you still having issues with it crashing on your wx pc?
Offline kray1000
  • Purveyor of wry
Re: streaming radio
« Reply #41 on: June 02, 2013, 10:10:11 PM »
I am curious where the "10307" is coming from.
Offline cospringswx
Re: streaming radio
« Reply #42 on: June 02, 2013, 10:13:58 PM »
Edcast doesn't like my Win 7 home WX PC. I've tried it since I had the problem and it crashed it again.
Ryan
Davis Vantage Vue
Offline kray1000
  • Purveyor of wry
Re: streaming radio
« Reply #43 on: June 02, 2013, 10:15:12 PM »
I know it works great on XP, but that probably doesn't help you much.
Offline cospringswx
Re: streaming radio
« Reply #44 on: June 02, 2013, 10:21:46 PM »
I wonder if anyone with Win 7 has successfully done this.
Ryan
Davis Vantage Vue
Offline cospringswx
Re: streaming radio
« Reply #45 on: June 02, 2013, 10:30:23 PM »
Do I have to install Framework 4 standalone installer as well?
Ryan
Davis Vantage Vue
Offline kray1000
  • Purveyor of wry
Re: streaming radio
« Reply #46 on: June 02, 2013, 10:33:41 PM »
I haven't uploaded streams since switching to Win 7, but I'm sure others have been able to do this.  There are just too many new streams showing up for that to not be the case.
You might try using a different version of the lame encoder, one that is compatible with your system, either 32-bit or 64-bit.
Offline kray1000
  • Purveyor of wry
Re: streaming radio
« Reply #47 on: June 02, 2013, 10:34:40 PM »
I'm not even sure what that is, so I'm going to go out on a limb and say no.
Offline cospringswx
Re: streaming radio
« Reply #48 on: June 02, 2013, 10:36:47 PM »
OK.I was reading about Scannercast and that it was mentioned to use.
« Last Edit: June 02, 2013, 10:38:27 PM by hayskswx »
Ryan
Davis Vantage Vue
Offline cospringswx
Re: streaming radio
« Reply #49 on: June 02, 2013, 11:07:49 PM »
Thanks Kevin with the help on this. I have pulled the plug to the radio until I can get this figured out.
Ryan
Davis Vantage Vue
