Old post, but a major change in WeatherLink.com site (V2) necessitates a change in the API used to get your data.
The WLCOM-plugin has been updated (along with the configuration information). What has primarily changed is that instead of using your weatherlink.com userid/password to retrieve the data, it now requires the password/DeviceID/Key for the data. The password remains the same as for your userid on weatherlink.com. The two new items are available from the WeatherLink, Setup, WeatherLink.com Network dialog in WeatherLink software V6+. Two new settings have to be added to your Settings-weather.php:
// following two settings are from the WeatherLink, Setup, WeatherLink.com network settings dialog
$SITE['WLCOMdid'] = '-your-device-id-'; // userid for Weatherlink.com
$SITE['WLCOMkey'] = '-your-key'; // WeatherLink.com Network configuration Key
values from the dialog as shown in the attached.
Files updated:
WLCOMtags.php
WLCOM-defs.php
include-wxstatus.php (from Base-* distributions)
Use the update tool
https://saratoga-weather.org/wxtemplates/updates.php with a query of 09-Jan-2018, Base-*, WLCOM-plugin
Configure from:
https://saratoga-weather.org/wxtemplates/Settings-config-WLCOM.phpBest regards,
Ken
