Web Weather => Weather Website PHP/AJAX scripting => Custom Website Templates => Topic started by: andro700 on April 27, 2022, 03:28:34 PM
I am having issues with my river page. I have to disable warnings in my php.ini file or the page will not load due to so many errors or it takes a long time to load. It is East Masonville Weather script. I have sent him a email and have not gotten a response.
[24-Apr-2022 13:32:11 America/Los_Angeles] PHP Warning: simplexml_load_file(): ./river-LNDW1.txt:1: parser error : Document is empty in /home/goblesweather/www/www/River/river-fetch.php on line 110
Here is the link to this file https://www.goblesweather.com/River/river-LNDW1.txt (https://www.goblesweather.com/River/river-LNDW1.txt) It is not empty.
[24-Apr-2022 13:32:11 America/Los_Angeles] PHP Warning: simplexml_load_file(): in /home/goblesweather/www/www/River/river-fetch.php on line 110
[24-Apr-2022 13:32:11 America/Los_Angeles] PHP Warning: simplexml_load_file(): ^ in /home/goblesweather/www/www/River/river-fetch.php on line 110
Here is the line 110
$xmlData["$riverid"] = simplexml_load_file($xmlFileData);
I have attached a copy of my river-fetch script.
When I click on any of the links to any river the page is blank.
Chuck
You should try the attached update.. it works on PHP 8.1
Are there other files somewhere for a new install?
Looking for river-config.php
Can't tell if river-status.php is needed or created.
Assuming /River/ has to be set for write access.
Anything else needed to setup?
Yes, the file I attached just contains the changed files from the last distribution.
Attached is the last full distribution I have .. just overwrite it with the update above and you'll have a complete set.
Thanks, Ken! [tup] =D> \:D/ =D>
This page hasn't worked for me for quite some time now. But happily thanks to you it's fixed (https://gwwilkins.org/wxriverpage.php)!
I even remembered to reactivate my 'river-fetch.php' CRONS. :-)
You're welcome :)
The last version of the script from eastmasonvilleweather.com was 3.13F in 2015.
I did some fixes in June, 2020 for a 3.13G version, and I've merged in the PHP 8+ fixes for a 3.13H version attached.
I am getting the following errors when I try and run a cron job for the river-fetch.php file. I have the latest H river script. Any clues.
/home/goblesweather/www/www/River/river-fetch.php: line 1: ?php
: No such file or directory
/home/goblesweather/www/www/River/river-fetch.php: line 14: syntax error near unexpected token `"river-config.php"'
/home/goblesweather/www/www/River/river-fetch.php: line 14: `include("river-config.php");
Chuck
I'm not sure what cron command you are using, but you need to run the PHP interpreter and pass it the river-fetch.php file.
It looks like (based on the error message, you're just trying to run the river-fetch.php file directly.
Your cron command should look like:
/usr/local/php81/bin/php -q /home/goblesweather/www/www/River/river-fetch.php
I will check it out. I am running the cron job via my web host.
Chuck
I got it working using Curl and System Scheduler. Don't know why I didn't think of this way sooner. Much less headache than trying to figure cron jobs on my web host site.
Chuck
