Note: trouble with registration? See this for more info.
I'm not sure what really needs to be done next. I have VWS running but it cannot see the COM 1 port. I also have WeatherLink loaded up. I'll assume they are fighting each other for COM1?
Do I need to have WeatherLink running with VWS?Do I just run VWS and uninstall WeatherLink?
Thanks Bob. I did just that and I'm up and online! Hurray! I deleted my calibrations and then noted something. I'm still poking around as the options have changed since the communication is now listed a Davis. 1) Is there a place where I can do a reset on the entire VWS?2) My anemometer is not connected to the ISS but rather it is connected to the Transmitter kit and the Envoy is reporting no Wind and the Direction is N. I have this set up in the Davis Console as station ID 1 and 2 and the readings are normal...wind speed changing and direction fluctuating. ID 1 being the ISS and ID 2 being the Transmitter Kit. So my question is where to set this up for the Wireless Transmitter kit in VWS?
OK, then that would tell me that I need to use WeatherLink to set up the Davis Envoy? And then the Envoy, once configured properly, would recieve the two station signals?
Bingo! That was it. Thanks so much for the help. Now I can work with the Davis unit and learn all the new features it has.
